Old 09-07-2012, 02:11 PM   #1
mannishdawg
mannishdawg is on a distinguished road
Default TAAT mainshaft cover issue
I have a 1997 SC2 that I recently replaced the valve body.And I checked the mainshaft nut and they are nice n tight all that extra work for nothing!! but I am having a problem getting the mainshaft cover back on tight. I get it to within an inch of closing but it wont budge after that. I dont want to bend the 2 tubes so I'm not forcing it. Is there a trick to getting the mainshaft cover in place?
Add to mannishdawg's Reputation
Rate the quality of this post and help mannishdawg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mannishdawg is offline   Reply With Quote
Old 09-07-2012, 06:51 PM   #2
HandsOn
HandsOn is on a distinguished road
1997
Default Re: TAAT mainshaft cover issue
Hi mannishdawg. Sorry to hear of your problem.
I can't help unfortunately, but am very interested in the solution.
And it also gets your question back to the top of the page for a few minutes.
Maybe someone with intimate knowledge of all the little pitfalls can chime in and help.
Good luck.
Paul
Add to HandsOn's Reputation
Rate the quality of this post and help HandsOn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HandsOn is offline   Reply With Quote
Old 09-07-2012, 10:52 PM   #3
wolfman
wolfman's Avatar
Maybe a silly question... but is the transaxle in or out of the car?
Add to wolfman's Reputation
Old 09-07-2012, 11:07 PM   #4
saturntechdave
saturntechdave is on a distinguished road
1993 SL2
Tubes from end cover fit into bushings inside of shafts, My best advice is to jiggle cover while gently stabbing tubes into place. Usually the cover just falls into place after fiddiling with it for a minute or so, just don't force it Saturn said that bushings could be dislodged or the pins that retain the tubes into the cover could be bent or broken if forced.
Add to saturntechdave's Reputation
Rate the quality of this post and help saturntechdave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturntechdave is offline   Reply With Quote
TAAT End Cover CAUTION Ball Joint Removal (SA9132S; see also Input/Output Shaft Nuts) onehoop S-Series Tech 5 11-24-2009 04:16 PM
valve cover bolts issue RainieBrit S-Series Tech 8 06-23-2008 12:47 AM
TAAT Reverse rolling bangs-thuds? Is it Rev slam or different issue? MichelleG S-Series Tech 8 03-31-2008 04:22 PM
Valve cover gasket issue the_new_raceman S-Series General 2 03-07-2005 04:00 PM
01 LW200 rear bumper cover issue PaulGraz L-Series General 8 07-30-2003 09:30 PM
