Old 09-26-2007, 11:29 AM   #1
eXmortal
eXmortal is on a distinguished road
eXmortal's Avatar
2001 SC1
Default TAAT transmission
Hi all,
I have a problem, my automatic transmission gets some problems (needs a serious repair), so I decided to change it.
I've found looking good used transmission from S-series sedan 2000 year. But this transmission is from sedan SOHC auto.
Does this transmission the same as in my SC1 SOHC 2001 Canadian ?
As I got to know from different internet sources, TAAT transmission is used in all S series. It not changed from 1996 to 2002. Is it true?
Maybe anyone already changed AT in own auto?
Thanks,
Vlad
2001 Saturn SC1
1.9L SOHC
usautoclub.by - American Cars Amateurs Club in Belarus
Add to eXmortal's Reputation
Rate the quality of this post and help eXmortal reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eXmortal is offline   Reply With Quote
Old 09-26-2007, 11:50 AM   #2
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
Default Re: TAAT transmission
You will be fine as long as you use an auto transmission from another SOHC engine(SL, SL1 or SC1).
Current Fleet:
97 Black Gold SC2 Manual
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
00 Yamaha SUV1200 Waverunner
Add to blackeagle1's Reputation
Rate the quality of this post and help blackeagle1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blackeagle1 is offline   Reply With Quote
Old 09-26-2007, 12:14 PM   #3
eXmortal
eXmortal's Avatar
2001 SC1
Thanks.
I know that, but wanna to now once more, just in case
Is any difference between AT for SOHC and DOHC engine (S-series) ?
2001 Saturn SC1
1.9L SOHC
Old 09-26-2007, 12:26 PM   #4
blackeagle1
2000 SL2
The gearing is different for the DOHC transmission. The DOHC transmission is geared more for performance while the SOHC transmission is geared for fuel economy. From what I understand, the PCM will set codes if you use the wrong one.
Current Fleet:
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
Old 09-26-2007, 12:31 PM   #5
eXmortal
eXmortal's Avatar
2001 SC1
thanks.
Once more questions: Where can I find any electronic manual for TAAT transmission? There are no information in Haynes repair manual. There are only described steps to change trans assembly module.
2001 Saturn SC1
1.9L SOHC
Old 09-26-2007, 12:38 PM   #6
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
eXmortal: welcome and greetings to Belarus!
one possibility for information:
on eBay they offer various Saturn service manuals in CD and DVD form
that would avoid having to ship a bulky set of manuals overseas
if you have specific diagnostic code problems just post them up here and we can help out
good luck!
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-26-2007, 01:01 PM   #7
eXmortal
eXmortal's Avatar
2001 SC1
There are no transmission error codes available
My saturn is over 360K kilometers, so I think that trans assembly wears out.
Fluid is fine, and I've just change it.
Problem is that I have heavy snatching while switching the gears, especially when down from 4 to 2.
2001 Saturn SC1
1.9L SOHC
Old 09-26-2007, 01:45 PM   #8
eljefino
eljefino's Avatar
1995 SW1
Gear slamming is sometimes a valve body problem or an electrical one, and the transmission internals can still be in good shape.
Changing the valve body, the rectangular thing on top of the case, under the battery, is rather easy.
Though I do understand if you happen upon a nice low mileage transmission, changing the whole thing for peace of mind.
A thorough check of all the electrical connections to the trans as well as battery and alternator health is also a good idea.
Add to eljefino's Reputation
Old 09-27-2007, 04:29 AM   #9
eXmortal
eXmortal's Avatar
2001 SC1
eljefino
Thanks, I'll check all the connections related AT.
But there are not only shifting problem in my AT. It needs change friction clutch disks ASAP. I feel some abnormal scrolls during change gear from 1 to 2 and 2 to 3. So I don't thing that is electrical problem.
Does anyone has such problem?
There are no special services where I can repair my Saturn available in Minsk.
So I need to make repair by myself.
2001 Saturn SC1
1.9L SOHC
Old 09-27-2007, 05:48 AM   #10
BarnOwl
BarnOwl's Avatar
eXmortal it's probably not your problem but, it could be and it's cheap. Get your charging system and battery checked. Sometimes the first symptom is weird shifting.
Oh and just in case it wasn't made clear. A DOHC automatic transmission cannot be made to work on an SOHC car. The PCM detects the gearing difference and will not shift.
Add to BarnOwl's Reputation
Old 09-27-2007, 06:33 AM   #11
eXmortal
eXmortal's Avatar
2001 SC1
BarnOwl thanks.
I'll check my electrical system this weekend. About DOHC AT I understand.
I found SATURN TAAT - ATSG TECHNICAL MANUAL on ebay.
For example http://cgi.ebay.com/ebaymotors/SATUR...spagenameZWD1V
Is it good manual? Does anybody use it?
Thanks.
2001 Saturn SC1
1.9L SOHC
Old 09-27-2007, 09:22 AM   #12
BarnOwl
BarnOwl's Avatar
Originally Posted by eXmortal View Post
BarnOwl thanks.
Thanks.
I haven't looked at that manual. I have a set of FSMs but, I have seen several recommendations for it on here. So, it's probably pretty good.
Old 09-27-2007, 07:58 PM   #13
eljefino
eljefino's Avatar
1995 SW1
That manual looks pretty good to me. If you're hardcore enough to tear into your tranny... that's great!
Know that the firmness and timing of the shifts is controlled by the computer driving the solenoids in the valve body, it is not a traditional mechanical transmission with governors, accumulators, and little check balls.
There is a fuse labelled "LPS" for "Line Pressure Solenoid", if it is pulled you will have incredibly harsh shifts. If you're surious about how your trans works pull this and go for a short drive.
Old 05-02-2008, 07:41 AM   #14
eXmortal
eXmortal's Avatar
2001 SC1
Well. I've changed my old broken transmission to another one at last. So long time were spent for transport used trans from USA to Belarus.
But I have another problem: we set another transmission, change oil (Mobil ATF320) and start to drive. At first car is driven fine, but through half an hour check engine is set, and car can move correctly forward. It twitching? but not move.
P1816 error code is available, what should I do with it? Should I replace Trans Range Switch with another one?
For example like this http://www.ctpowertrain.com/servlet/...S-RANGE/Detail
Thanks
2001 Saturn SC1
1.9L SOHC
Old 05-05-2008, 06:04 AM   #15
BarnOwl
BarnOwl's Avatar
It's late but, since no one answered, I'll give it a shot. Two things to check for. Is the ground connection (black and white striped wire) connected to the range switch? I managed to get the wire caught between the engine and tranny when I went back together. Second is your cable adjusted properly?
Old 05-07-2008, 12:01 PM   #16
eXmortal
eXmortal's Avatar
2001 SC1
Originally Posted by BarnOwl View Post
Is the ground connection (black and white striped wire) connected to the range switch? Second is your cable adjusted properly?
I don't understand what wire? There 3 connectors at TRS.
Could you post a picture what you mean? thanks.
2001 Saturn SC1
1.9L SOHC
Old 05-08-2008, 06:34 AM   #17
BarnOwl
BarnOwl's Avatar
I can't find a pic and I my wife's already driven off in the only Saturn I have right now with an automatic. I'll try to explain. The thing that the shift cable connects to is the transmission range switch. There are three wire harnesses that connect to it. One has a single black and white striped wire and it goes on with a spade connector. It's the one the closest to the driver's side. If that's not connected or it's screwed up somehow, you'll gets some strange codes.
Old 05-08-2008, 07:37 AM   #18
eXmortal
eXmortal's Avatar
2001 SC1
Thanks, I understand. I have a strange thing, I tried to adjust range switch, as I read in alldata. At first I set D mode and found continuity between connector A and B, after that I tightened switch to case bolts. continuity is present, but when I switch to another mode and return to D - there are not continuity. It is very strange. I disassembled switch module and find that connector that influence to continuity in D mode has very small length. I have another broken range switch, connector is the same. I don't understand how it work.
2001 Saturn SC1
1.9L SOHC
Old 05-15-2008, 09:57 AM   #19
eXmortal
eXmortal's Avatar
2001 SC1
Every is fine. transmission works fine. We fount a trouble
I have problem with exhaust system. Catalytic convector is blocked, so exhaust gas cannot be passed through it. EGR valve was opened by out pressure and exhaust gas incomes to input collector. Currently we blocked EGR valve and make outlet before catalytic convector.
Now I'll waiting a new catalytic convector from USA. I bought Walker part.
Shipping is not so fast, it will spent wore than 2 weeks, there are no parts available in local stores for saturn at all
2001 Saturn SC1
1.9L SOHC
rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help mordo2 S-Series Tech 5 05-23-2016 09:28 AM
Taat Transmission problem re hum funnyfarm S-Series Tech 9 09-04-2009 08:36 AM
TAAT transmission (or not) k1rod S-Series Tech 4 10-23-2008 01:14 PM
Taat ctrow S-Series Tech 4 09-23-2008 11:47 AM
looking for an exploaded view of a Saturn Taat transmission. mordo2 S-Series Tech 13 09-02-2006 12:48 AM
