Old 12-04-2006, 07:30 PM   #1
3.8TransAM
3.8TransAM is on a distinguished road
1992 SL1
Default Thermostats: The Final Word
92 SL1 160k oil burning pile of #$&^%^
Anyhow.
Here is real data, since 98% of people here dont bother to actually test anything with real results.
All data is from 20deg F ambient daytime temp
Autozone thermostat(rated at 185deg F)
Hot at idle runs at roughly 82deg C. Maximum observed was 85 after prolonged idling. Driving temp was around 82-83deg C.
Stant thermostat(rated at 195, says 87deg C on it)
Hot at idle was 99-100deg C. Maximum observed was 101-103 after prolonged idling. Driving temp was 99-101 deg C
Saturn thermostat(supposedly 192-195F rating)
Hot at idle was 95deg C. Maximum observed was 97 deg C after prolonged driving and idle. Driving temp was 95-96 deg C.
In retrospect, use the stock SATURN thermostat, especially in cooler climates.
Has best warmup tendencies from my observations.
AZ t-stat runs too cool in anything other than warmer weather above 50deg F. Also opens early and tends to make warmup take longer. Wouldnt hesitate to use it in hotter climates.
Stant runs too hot. I dont even recommend it if you live where its low temps all yr round. At 20deg F ambient it is within 2 deg C of kicking the fans on. Would only recommend if everything is in tip top shape and your going for the ultimate mileage beater.
None of the tested t-stats tended to vary more than 3 deg C, so they were all working, just not quite right.(too hot or too cold)
The not too hot, not too cold winner, is the factory Saturn t-stat.
All data taken using a Snap On MT 2500
later
Jeremy
PS :Edit" Sorry I used the "Final Word" and its not Wolfman's realized it after the fact, still contains good valid data.
The car that is to dumb to die: 92 SL1
Fill the oil check the gas
Favorite quote while merging with traffic in the SL1 "I'm gonna die!"
Add to 3.8TransAM's Reputation
Rate the quality of this post and help 3.8TransAM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
3.8TransAM is offline   Reply With Quote
Old 12-04-2006, 09:44 PM   #2
GregS&L
GregS&L is a jewel in the roughGregS&L is a jewel in the roughGregS&L is a jewel in the rough
GregS&L's Avatar
2001 L-Series 3.0L Sedan
Default Re: Thermostats: The Final Word
Good empirical data ^^^.
Replaced the thermostat in my daughter's 95 SL several years ago with the Saturn OEM unit - believe the OEM unit was made in Germany. Felt I had to replace because the temp gauge was only going up to the 1/4 mark, even in summer.
After replacement, the gauge now normally goes between 1/4 and 1/2 consistantly. The heater works better also. Well worth the effort.
Good post, thanks.
Add to GregS&L's Reputation
Rate the quality of this post and help GregS&L reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GregS&L is offline   Reply With Quote
Old 12-04-2006, 10:15 PM   #3
eljefino
eljefino's Avatar
1995 SW1
Where'd you get the stant? I think I got one at advance auto and I get a cruise temp of 206'F. Great for mileage and heat but a bit on the warm side of comfortable.
Cruise temps really are the only way to test these things as you get tons of airflow.
Add to eljefino's Reputation
Old 12-04-2006, 10:33 PM   #4
DonP
How many of each type did you test?
What is the average unit-to-unit variation in actual operating point vs rating among samples of the different models?
Add to DonP's Reputation
Old 12-05-2006, 01:31 AM   #5
wolfman
wolfman's Avatar
And I have been critisized for recommending ONLY OEM parts for some particular repairs...
Add to wolfman's Reputation
Old 12-05-2006, 03:39 AM   #6
3.8TransAM
1992 SL1
I tested about 10 of each to verify.
Avg was about 4.89238762184657389230 deg C between them.
What do u think this is a laboratory? I wanted to make my car run not too hot and not too cold. I wanted it just right. Dont u read childrens stories? lol
Crappy winter warm up and heat made me run around with the scanner. Verified them one at a time and posted the results as shown. Its consistent with what most here have posted, but no one ever bothers to actually test and provide data. Since I had it and verified it I posted it.
Also, to who asked about cruising temps, I did post them. check out where it says driving temps. this was on 40-50mph back roads and some 70 mph highway driving.
Wolfman, I figured if anyone would appreciate it, you would. Now I want to know why these garbage boxes are so damned finicky compared to everything else out there. lol
later
Jeremy
Old 12-05-2006, 10:26 AM   #7
DonP
With a few exception, t-stats tend to be rated in 5 degree steps. Values in the Stant catalog include: 205, 195, 190, 185, 180, 170, and 160, with a few odd-ball numbers (183, 186, 188). Literature states that the heat motors in t-stats are 100 percent tested for calibration. Makes me think that they are manufactured with a view to providing a specific heat rating, then tested, and binned/labeled by the actual operating temp.
Thus a 195 might be any unit that operated between 200 and 192.5; over 200 and less than perhaps 210 might be rated a 205, 190 pight be any one that operated betwen 187.5 and 192.5, and so on.
Interesting that at idle, presumably with no air flow through the radiator except than when the fan is running, the engine never reached the temp for fan turn-on. Perhaps the below freezing 20 degree F ambient temp was the reason.
Old 12-05-2006, 12:52 PM   #8
eljefino
eljefino's Avatar
1995 SW1
Yes, anecdotes by themselves are rather useless but get a few people with scantools and you might spot a trend.
3.8 transam and I are the only ones to have plugged in, gotten precise data, and posted, so far.
There was a poster some time ago trying to get better MPG; if we can prove the stant is an econo-thermostat that might be useful info.
Old 12-05-2006, 03:51 PM   #9
DonP
Measured cruise (open road) temps can reflect the influrence of other factors in addition to the t-stat operating temp, such as effective aperture through the t-stat when open, efficiency of the radiator, condition of the core, ambient air temperature, air flow thorugh the radiator, engine load, whether or not A/C is on, heater on/off, and so on. Tests in the same car reduces the variables.
Of interest of course is the overall system operation in the car during intended use. 3.8TranAm's post onhis tests provides useful data points for which he deserves thanks.
FWIW: The Stant catalog has a special page on Saturn t-stats with instructions (attached). At least they take our market segment serious. I believe that Stant and Gates are owned by the same parent company (Tomkins Industrial and Automotive group) - wonder if their t-stats are now off the same or shared production lines?
Old 12-05-2006, 04:41 PM   #10
Tiger
Tiger's Avatar
My philosophy is if in doubt use OEM parts...or, follow Wolfman's recommendations here...
http://www.saturnfans.com/forums/sho...+PARTS+WOLFMAN
I am very happy with my OEM thermostat. Made in Germany. Makes my car feel a little like a Mercedes...
Add to Tiger's Reputation
E85 compatibility-(the final word?) TurboTuna Relay Tech 11 09-13-2006 07:50 AM
The FINAL word about oil additives (I hope) wolfman S-Series Tech 29 11-12-2005 12:20 AM
THe FINAL word (I hope) on oil for an "S" series Saturn wolfman S-Series Tech 19 08-14-2005 08:42 PM
The Final Word (for now) Whelan Mods and Performance 0 09-25-2001 04:23 PM
the FINAL word in intakes Whelan Mods and Performance 6 05-28-2001 03:11 AM
