Closed Thread
Old 07-19-2004, 10:13 PM   #1
wolfman
wolfman's Avatar
Default The FINAL word about oil additives (I hope)
A worthy addition to the FINAL word about ENGINE oil thread. Oil additives. First a LINK to the best site about oil, oil filters and oil additives bar none http://www.bobistheoilguy.com/images/lucas/lucas.htm (the reason I recommend NOT USING Lucas products)
Bottom line there is no magic bullet.
OIL ADDITIVES:
FRICTION MODIFIERS: Slick 50, Prolong, Duralube etc... These use proprietary ("secret") formulas that use molebdium disufide, Teflon and any number of a variety of goop to "improve" the lubrication (slipperyness) of oil. DON'T USE THEM IN YOUR ENGINE! Many of the ingredents can actually cause DAMAGE long term. (NOTE: Friction modifiers CAN be a good thing in MANUAL gearboxes and differentials BUT, you must be VERY CAREFUL what you add. Many manufactuer's actually use additives right from the factory for these applications but NEVER in engines.
VISCOSITY IMPROVERS: Motor Honey, STP etc THICK goop added to oil that basically thickens it up. These work, BUT, AGAIN, DO NOT USE THEM. If you want thicker oil, just buy thicker oil! These can be a very bad thing in areas of COLD WEATHER as they can restrict oil passages, pumpability and start up lubrication.
SEALERS AND SEAL "SWELLERS": "CDxx, "High Mileage" oils, Oil "Stop leak" products etc.. These use a chemical additive to actually soften and/or swell seals (such as valve guide seals) in an engine to reduce oil leaks and burning. These also work, BUT, should NOT be added more than ONCE with an oil change. (Continued use can actually soften seals to the point of failure!) Long term use can result in deposits that can actually clog up oil passages. They "may" stop a MINOR rear main seal leak but are NOT a permanent solution. If you have a leak, it needs to be fixed. They can reduce oil burning PROVIDED it is caused by worn valve guide seals, but again is NOT a permnanent fix.
SOLVENTS AND OIL SOLVENT MIXES: Marvel Mystery Oil, any product that says "Quiets noisey lifters", SeaFoam etc.. These products contain highly refined and very THIN lubricating oils and a variety of petroleum and non petroleum based solvents. These also work. By introducing solvent into to the oil stream (or fuel stream) to break up, soften or disolve carbon, varnishes and other deposits and can help to "clean" out an engine internals and quiet lifters clogged up by such deposits. They are also not a "cure all" but can net good results if used according to instructions. Products such as MMO have proven themselves over the years to be safe and reliable as well as versitile. These likewise are NOT a "cure all" but can pull a marginal lifter or engine full of neglectful gunk back from the brink if combined with more frequent oil changes to flush out the goop they disolve. DO NOT use "5 Minute Motor Flush" or similiar products. These are basically just Kerosine and result in filthy highly diluted oil running through the oil system for way too long (even 5 minutes is too long IMHO) you also will NOT be able to drain it all out afterward so it will continue to contaminate and thin the fresh oil you pour in and clog the new filter.
ENGINE "IMPROVERS": Restore, Tune Up in a Can etc..These products actually contain various suspended METALS, seal swellers, solvents and lubricating oils. Some folks swear by them. The jury is still out. In my opinion anything particle wise is not a good thing in oil (that's why you have an oil filter) One thing I DO KNOW for certain is that NOTHING you add to your oil is going to undo the wear of tens of thousands of miles...that's what rebuilds are for.
BOTTOM LINE. NOTHING (to date) you can pour into your engine oil will make up for high mileage, mechanical problems or general wear or neglect. There are products that can help bring a NEW or minor problem back to normal, as well as some that can help keep things running good when used in moderation AND as part of the cars REGULAR MAINTENANCE SCHEDULE. Save the money you would spend on additives and spend it on maintenence and repair. That's the absolute bottom line.
Add to wolfman's Reputation
wolfman is offline
Old 07-19-2004, 10:22 PM   #2
wrg813
wrg813 is on a distinguished road
Default
Much knowledge Wolfman... I applaud. If I'm wrong on the summing up let me know. If your engine uses oil at a moderate consuption rate, top it off and be on your way. The fact that it uses oil is not a major problem, but if you drive low on oil, that will be your downfall.
Add to wrg813's Reputation
Rate the quality of this post and help wrg813 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wrg813 is offline
Old 07-19-2004, 10:44 PM   #3
wolfman
wolfman's Avatar
Default
BINGO!
wolfman is offline
Old 07-19-2004, 11:15 PM   #4
wrg813
Default
I think this information should be "Important". Alot of people come here to ask about oil consumption. I think Wolfman has given a complete summary on how to try to reduce and/or prevent it. Let us know Charlie.
wrg813 is offline
Old 07-20-2004, 01:04 AM   #5
ttreibel
ttreibel is on a distinguished road
ttreibel's Avatar
2006 ION-2 Quad Coupe
2002 SL1
Default
Thanks for a very well written and well thought post.
1995 SL1 oil burner school commuter looks nice...1997 SL1 Gold 5-speed with new junk yard wheels and tires just got 40.4 MPG....2002 SL1 sometimes 45 MPG on a spring highway drive
Add to ttreibel's Reputation
Rate the quality of this post and help ttreibel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ttreibel is offline
Old 07-20-2004, 02:04 AM   #6
sierrap615
sierrap615 is on a distinguished road
sierrap615's Avatar
Default
good info as always wolfman. but i have a quick question ( as always). what do you think of using ATF before an oil change to flush the system?
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
Add to sierrap615's Reputation
Rate the quality of this post and help sierrap615 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sierrap615 is offline
Old 07-20-2004, 03:07 AM   #7
wolfman
wolfman's Avatar
Default
Don't do it. ATF is essentially a lubricant enhanced hydraulic fluid that was never meant to see combustion level temperatures, it's (ATF) additive package may actually be incompatable with engine oil and make for some ugly chemical reactions. If you want to do a little supplimental cleaning of the engine's innards, add a 12oz or 16oz bottle of MMO (Marvel Mystery Oil) to the dirty oil (even if you have to overfill it to do so) about 300-400 miles shy of the next oil change. That will safely do what you seek, for the same or even less cost.
wolfman is offline
Old 07-20-2004, 06:27 AM   #8
jeep4523
jeep4523 is on a distinguished road
1994 SL2
Default
Another thing about those stop smokes.....they also tend to contain chemmicals that will make the smoke still come out, but it's not as colored (basically makes it burn clear-er I guess you could say).
We sell them at the store and we keep telling people it won't solve **** (any of it) besides an MMO piston soak, and they still buy it....
Democracy is two wolves and a sheep voting on what to have for dinner. Liberty is a well armed sheep contesting that decision.
Add to jeep4523's Reputation
Rate the quality of this post and help jeep4523 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jeep4523 is offline
Old 07-20-2004, 09:16 AM   #9
Luke
Luke's Avatar
Default
Fm Wolf
First a LINK to the best site about oil....
I've been checking that site for almost two years, and have found it invaluble......
Well done article, Wolf..
Add to Luke's Reputation
Rate the quality of this post and help Luke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Luke is offline
Old 07-20-2004, 10:06 AM   #10
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
Default
Actually ATFs are compatible with the same temps as engine oils because they are mostly the same base stuff: oil - either petroleum or synthetic. HOWEVER ATFs have a lot different additive package which is not intended to work in an engine and as Wolf says DON"T PUT ATF IN YOUR ENGINE.
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bill Murray is offline
Old 07-20-2004, 12:39 PM   #11
eljefino
eljefino's Avatar
1995 SW1
2000 SL1
Default
You didn't include Auto-RX, an expensive substance with religious application instructions and mostly positive reviews on BITOG.
It's supposed to gently clean all that ails your motor over a period of 1500 miles without upsetting anything.
Add to eljefino's Reputation
Rate the quality of this post and help eljefino reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eljefino is offline
Old 06-06-2005, 02:18 PM   #12
LV Hospice RN
LV Hospice RN is on a distinguished road
Default Re: The FINAL word about oil additives (I hope)
and if you believe some of the members posts, it cures not only oil burning, but diarrhea, acid reflux and impotency!!!
While some members swear by it, to me, the jury is still out...
1. none of the evaluations i have seen have been objective...mostly just people saying, i used it, engine much cleaner, runs smoother, and gas miliage improved 2.342%!
2. i would love to see before and after compression numbers...no one has done this...just a statement that the "oil rings" have been cleaned...again, with no proof...
3. "They" say its cleans the engine. Yet no one took before and after pics of inside of valve covers and valve train...this is relatively easy to do, yet no pics to "prove" auto RX works...
I personally thinks Auto RX does what its supposed to do...take money from your pocket and put it in the company till that sells it...
Just IMHO, YMMV
darrell
sin city
"Where are we going...and what am i doing in this handbasket?"
Add to LV Hospice RN's Reputation
Rate the quality of this post and help LV Hospice RN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LV Hospice RN is offline
Old 06-06-2005, 02:57 PM   #13
Jeff P
Jeff P is on a distinguished road
Jeff P's Avatar
I'm not an Auto-RX Kool-Aide drinker, but you are quite incorrect about the lack of "evidence" for the product. Check this link out for the results of a very thorough test of the product. The first post includes both before and after compression #s and pictures.
This link has a guy who measured compression before and after.
Here's one where a Saturn owner reports that it stopped a rear main seal leak.
That wacky site is full of what you could call anecdotal evidence for the stuff - people who swear their car runs smoother/better/better mpg/reduced emmissions/etc. Of course most of them don't bother to do compression tests or take pictures of the valvetrain. There are also quite a few very knowledgeable folks, like actual engineers who do nothing but design oil, who vouch for the stuff.
It certainly doesn't cure impotency or diarrhea, but I think it's safe to say it probably does clean out an engine pretty well
jeff
Add to Jeff P's Reputation
Rate the quality of this post and help Jeff P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeff P is offline
Old 06-07-2005, 12:17 AM   #14
LV Hospice RN
jeff
The one that posted compression figures say it went from 460-480 to 480-500...but doesnt mention was the numbers taken under the same condition, i.e. engine hot or cold, etc...any variable could cause a small change...
The other claims it "cleans the engine" and "removed" the varnish...but again, just word of mouth...no pictures...just, "it performed miracles for me"...
It seems with hundreds of use, SOMEONE would have documented the changes...did the UOA...if it truly worked the Company that makes its would pay an independent lab to do the tests..none of that is present...
Remember, Slick 50, STP, and a host of other "lubricates" have/had a huge following...but there is little evidence it works...Keep the snake oil in vehicles owned by snakes!!!
Just IMHO, YMMV
darrell
sin city
Old 10-28-2005, 10:22 PM   #15
callmethewander
callmethewander is on a distinguished road
callmethewander's Avatar
1992 SL1
1994 SC2
OK OK, Information overload! please some advice. My '94 SC2 with 55,000 miles "consumes" (as porsche people like to put it, haha) about a qt. of mobil1, which i just switched to at 50,000 mis, every 500-600 miles. Should i; switch back to dino, do some kind of treatment, wait and see if it improves with the mobil1, rebuild (i hope not to), or any other suggestions. This is my 3rd saturn, i just donated my first one with over 200,000 mis, '92 SL1, and my daughter is driving the '95 SL1, but i like the SC2 the most and would like to enjoy it for a long time, but a qt. of mobil1 every 500 mis gets expensive (i know it's a lot cheaper than some other options!) so any input would be appreciated.
thank you all
Add to callmethewander's Reputation
Rate the quality of this post and help callmethewander reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
callmethewander is offline
Old 07-20-2004, 01:02 PM   #16
Bill Murray
1997 SC1
1997 SC1
Default
At 67 bucks a quart, you're certainly correct on the first part!
Old 07-20-2004, 02:32 PM   #17
Jeff P
Jeff P's Avatar
Default
Ha. It is expensive. I believe the standard price is $25 for a 12 oz bottle (I'm awful with english units, is that $67/qt?) though between the discount for ordering more than one and a "discount code" I found on some Porsche site, I was able to get 4 bottles for ~$60.
Running one treatment in our '00 Civic right now, it's got about 96k miles and I'm switching it over to Mobil 1, figured a good cleaning beforehand couldn't hurt. My '92 also has some in it right now, unfortunately the tranny trouble is keeping it off the road.
Like eljefino said though, that stuff appears to be the real deal.
jeff
Jeff P is offline
Old 07-20-2004, 02:56 PM   #18
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default
Many old timers swear by adding about a pint of kerosene to an old engine's crankcase prior to changing the oil will clean the the gunk out. I balked at the idea of adding something as volatile as fuel to a running engine's crankcase.
Any thoughts on this?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline
Old 07-20-2004, 03:15 PM   #19
Jeff P
Jeff P's Avatar
Default
Wolfman had a comment on that buried in the original post:
"DO NOT use "5 Minute Motor Flush" or similiar products. These are basically just Kerosine and result in filthy highly diluted oil running through the oil system for way too long (even 5 minutes is too long IMHO) you also will NOT be able to drain it all out afterward so it will continue to contaminate and thin the fresh oil you pour in and clog the new filter."
Jeff P is offline
Old 07-23-2004, 08:23 PM   #20
SylenThunder
SylenThunder's Avatar
2003 VUE 2.2L
Default
EXELLENT POST!!!!!
Yeah.... and some of those "leak stoppers" just inflate your existing seals (which are crap) and after a few oil changes they (your seals) begin to deteriorate faster than they did before because the expansion tears them apart.
Also always use caution with thicker oils. make sure you engine can handle the extra stress. I blew a head that way once.
2004 FWD, Vti, 2.2L
Custom CAI
Add to SylenThunder's Reputation
Rate the quality of this post and help SylenThunder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SylenThunder is offline
Closed Thread
Thermostats: The Final Word 3.8TransAM S-Series Tech 9 12-05-2006 04:41 PM
E85 compatibility-(the final word?) TurboTuna Relay Tech 11 09-13-2006 07:50 AM
THe FINAL word (I hope) on oil for an "S" series Saturn wolfman S-Series Tech 19 08-14-2005 08:42 PM
The Final Word (for now) Whelan Mods and Performance 0 09-25-2001 04:23 PM
the FINAL word in intakes Whelan Mods and Performance 6 05-28-2001 03:11 AM
