Old 01-24-2009, 11:03 PM   #1
jcw
jcw is on a distinguished road
Default More on clutch hydraulic system fixing...
On my quest to save some money and learn something I decided to fix my manual SW2 clutch hydraulic system that was getting hard to shift.
The culprit was a leakage at the hydraulic damper and it was caused by bad oxidation of the only non plastic part of the system. Hygroscopy played its part - the whole damper is made of steel and corroded internally after 9 years. Here's a picture of it with the diaphragm already cleaned - it had thick rust deposits underneath the rubber O-ring:
I fine sanded the diaphragm, reassembled it and did the bleeding following mavmav instructions:
http://www.saturnfans.com/forums/sho...d.php?t=65662#
As a result I had a nice rebuilt system - you can tell you don't have much air in the system when it becomes very difficult to push the slave rod into its cylinder by hand.
During re-installation, using the instructions from Saturn FSM for 1995 S-Series nicely published by 3danh:
http://www.saturnfans.com/forums/showthread.php?t=60471
When trying to reinstall the actuator into clutch housing, one of the plastic hydraulic lines broke, ruining the whole repair.
Here's the main reason for this post: I think that in discordance with Saturns's S-Series clutch FSM you have to reverse the order of both removal and installation of the damper and actuator. In doing so, you have much more flex available with the hydraulic lines, probably preventing possible line breakage. On removal first remove damper and then the actuator. On install first insert the actuator and then secure damper.
Anyway, I put my tail between my legs, got the Advanced Auto Parts PF9001 replacement system ($102 versus $185 OEM), and I'm happy again (The PF9001 is made in USA by Perfect Clutch).
jcw is offline   Reply With Quote
Old 01-25-2009, 10:04 AM   #2
DonP
Default Re: More on clutch hydraulic system fixing...
FWIW: About $123 plus shipping from www.saturnparts.com
Neat information. Thanks for the post.
Old 01-25-2009, 02:04 PM   #3
Yes, that is exactly how you have to both remove and install it or it will break. Sometimes it pays to not read and follow the manual.
Nice work on disassembling the damper. I think the later iterations are a welded assembly however.
If I did not have 3+ inches of global warming to scrape up this AM I would go look at how the ones here are built.
How To: Clutch Hydraulic system with pics ShawnV How-To Library 26 08-17-2016 03:25 AM
Q about hydraulic clutch system MikeNW S-Series Tech 13 12-22-2011 09:11 AM
Clutch Hydraulic system for sale MikeNW S-Series Tech 0 05-18-2008 11:44 PM
Help ! Air in Hydraulic Clutch System GlennWerner S-Series General 2 12-06-2007 10:54 AM
Clutch hydraulic system problems clemtwist S-Series General 4 04-03-2006 08:31 PM
