Old 11-07-2005, 04:31 AM   #1
Big__Daddy
Big__Daddy is on a distinguished road
1996 SC1
Default Trouble Code and Service Engine Light
About a week ago I turned on my car (96 SC1 MT) and noticed that about after 20 seconds my Service Engine light came on(the one with a little wrench on it's left). So at first I thought maybe it's the computer letting me know it's due for an oil change; but as I started driving toward school I noticed that the Upshift Lamp wasn't coming on. So I hooked it up to a scan tool and got back the code: P1650 DRIVER 2-INPUT VOLTAGE HIGH.
I also did a search online for the code for GM and found; DTC P1650: Control Module Out-put B.
Guys help me out with any ideas. What could it be? Everything in the car works fine. Everything sounds fine. All my sensors and gauges are functioning perfectly, except for the upshift lamp.
If the bulb for the upshift lamp blew, would that cause the Service Engine to go off? I've checked most of the fuses in both boxes and they seem to be fine. I'll probably recheck all of them again. But thats my problem guys: My Service Engine Light comes on everytime 20 seconds after I turn the car on and won't go away. You have the codes, so if anyone has had experience with them please help. I'd appreciate the feedback.
Add to Big__Daddy's Reputation
Rate the quality of this post and help Big__Daddy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Big__Daddy is offline   Reply With Quote
Old 11-07-2005, 08:47 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Trouble Code and Service Engine Light
I think it will. I'm not sure what code it will give though.
Add to BarnOwl's Reputation
Old 11-07-2005, 09:27 AM   #3
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
How is it running?
If the plugs and wires are old, I would replace them.
Most common problem is a miss on plug 4, which causes the wrench light to come on.
Don't have any idea about the light option.
Add to alleninpa's Reputation
Old 11-07-2005, 01:42 PM   #4
Big__Daddy
1996 SC1
Originally Posted by alleninpa
How is it running?
It's running perfectly. All 4 plugs and wires are brand new.
Do you guys think that the upshift lamp just burned out? But if that was the case, would that give me the P1650 code?
Old 11-07-2005, 02:46 PM   #5
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
What plugs did you use?
Old 11-07-2005, 03:40 PM   #6
Big__Daddy
1996 SC1
BOSCH Premium Wire Set, and BOSCH Platanium +4 Spark Plugs.
The car is running fine, idle is perfect, no unusual vibrations.
Old 11-07-2005, 03:59 PM   #7
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
You may want to replace them with NGK v power plugs.
I have a set of Bosch platanium that worked for a little while...
Old 11-07-2005, 07:05 PM   #8
Admiral Beez
Admiral Beez is on a distinguished road
Admiral Beez's Avatar
2000 SL2
If I wanted to replace my own spark plugs (2000 SL2) do I need a torque wrench? I have a long socket that can likely do the job. My car's burning about a quart of oil every 1,000 miles; so I need to keep my plugs in good shape, but don't want to spend $ at the dealer if I can do it myself. Comments? Thx.
Add to Admiral Beez's Reputation
Rate the quality of this post and help Admiral Beez reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Admiral Beez is offline   Reply With Quote
2001 SC1 Service Engine soon Light Code P0446 ateball S-Series Tech 13 12-10-2009 04:10 PM
Trouble Code and Service Engine Light Big__Daddy General Saturn Discussion 1 11-10-2005 10:15 PM
Service Engine Soon Light – Error Code P0133 Filo S-Series Tech 5 02-16-2005 03:49 PM
Trouble Code 49 on Service Engine Soon Light 93sl1 S-Series Tech 10 11-19-2002 10:19 PM
Check Engine Light - Invalid Trouble Code AxeMan S-Series Tech 24 10-17-2002 06:29 AM
