Old 01-28-2010, 02:58 PM   #1
SaturnTech122
SaturnTech122 is on a distinguished road
Default 1996 5spd wont go into gear
Been a while guys I got laid off from saturn on dec 11th shortly after that my s car stopped shifting inot gear, 96 sl2 manual. So when the cars off the shifter moves freely through all gears no resistance, when I turn the car on I can't shift it clutch pedal feels softer than usual. When I lay onto the clutch pedal with all I got I can manage to get it into gear. No fluid leaks at clutch pedal is a slight droplet of fluid at bellhousing. Installed new engine and clutch/pressure plate 15k ago due to worn thrust bearing. I don't beat the car so the clutch isn't too concerning? I'm thinking slave failure? Its original w 125,000 miles any ideas would be helpful
SaturnTech122 is offline   Reply With Quote
Old 01-28-2010, 05:46 PM   #2
Default Re: 1996 5spd wont go into gear
Master or slave, possibly. Doesn't matter which, since you replace the whole hydraulic system at once.
What happens when you put the clutch down with the engine off, put it in gear, and THEN turn the key? Does the car immediately lurch?
Here's the definitive How-To on diagnosing clutch/hydraulic issues: http://www.saturnfans.com/forums/showthread.php?t=94634
Here's hoping you find gainful employment soon.
Old 01-29-2010, 01:00 PM   #3
SaturnTech122
Default
If I put the clutch in put into gear and start it does not lurch
Old 02-06-2010, 04:54 AM   #4
captsam
captsam is on a distinguished road
captsam's Avatar
1997 SW2
Same happened to me, it was the hydraulics. You'll have to replace the whole system, top and bottom. Wasted my clutch too, so it had to go the same time.
captsam is offline   Reply With Quote
No 2nd gear on a 5spd? tferman S-Series Tech 11 11-04-2008 11:57 PM
car wont go into gear rxzone S-Series Tech 1 08-22-2007 09:09 PM
5spd gear ratio CanMan S-Series Tech 2 05-21-2007 08:08 PM
wont go into first gear dads saturn S-Series General 24 06-02-2006 06:33 AM
Wont go in 2nd Gear! anniesmallwood S-Series Tech 2 11-15-2002 11:42 PM
