Old 09-27-2009, 09:13 PM   #1
caps54
caps54 is on a distinguished road
2008 AURA XR
Dizzy My Airbag System light stays on!!
Hi,
I need some help with my airbag system. I fixed a front end damaged Ion 2 2007. I replaced the air bag, clockspring, seatbelts and even the small yellow plug with the black lock tabs. The only thing I have not replaced is the SDM module under the center console. I took it to the GM dealer, they found an error code DTC B1000 – “Replace the control module setting the DTC as current. Refer to Control Module References for replacement, setup, and programming. Did you complete the replacement?” This is what was listed in the GM manual. The dealer says I need a new module. $500.00
I saw these ads stating they can reprogram the SDM module to new settings. Do these programs work? Can I get one from a junk yard as long as it has the same part number? I'm running out of ideas!
caps54 is offline   Reply With Quote
Old 09-30-2009, 11:12 AM   #2
SaturnTech122
SaturnTech122 is on a distinguished road
Default Re: My Airbag System light stays on!!
Your dealer is correct, a unclearable 1000 code requires module replacement... whenever the air bags deploy the module usually needs to be replaced and reprogrammed
Certified Saturn Technician
SaturnTech122 is offline   Reply With Quote
Old 09-30-2009, 10:06 PM   #3
caps54
2008 AURA XR
Do I need to buy a new one! $500.00 Or can I get one out of another car?
Old 10-04-2009, 10:42 AM   #4
G.M.
G.M. is on a distinguished road
G.M.'s Avatar
from another car will work. but you already know you should buy new.
turbo saturn - 400 club
www.sixthsphere.com
http://www.cardomain.com/ride/3895969/1998-saturn-s-series-sl2-sedan-4d
G.M. is offline   Reply With Quote
Old 10-04-2009, 06:34 PM   #5
RoadIon
RoadIon will become famous soon enough
2007 ION Red Line
2007 ION-3 Sedan
Sounds like someone is trying to get a wreck looking good for resale without a care to the lives of the new owners.
RoadIon is offline   Reply With Quote
ABS Light / Battery Light Stays ON + starter issues 97 SL1 IanDorety S-Series General 3 08-25-2009 11:08 PM
Airbag light stays on jricc Vue Tech 5 06-03-2007 09:37 PM
Airbag light stays lit Barb1681 S-Series Tech 3 12-29-2006 12:23 PM
Airbag system question tjd83 S-Series Tech 17 12-05-2006 11:04 AM
Oil light stays on mrbluesky S-Series General 12 03-31-2006 03:33 PM
