Old 09-21-2009, 02:29 AM   #1
pepsi911
pepsi911 is on a distinguished road
Default 2003 ion quad coupe stalls
hello, i own 2 saturns at the present time, a 2001 ls200 and a 2003 ion sedan. i have an opportunity to buy a 3rd which is a 2004 ion quad coupe. here is the problem, the car starts and idles fine but as soon as you shift the car into drive or reverse it stalls. the car will restart, but continues to stall when you try to shift it into gear. also, there seems to be a problem with the windshield wipers and i am not sure if this is related or not. the car was in an accident (light front end hit - no air bags deployed) and repaired. could this be a ground problem, a tcm problem (reflash). has anybody experienced this sort of problem. any information will be greatly appreciated.
pepsi911 is offline   Reply With Quote
Old 09-22-2009, 10:21 AM   #2
79sc2
79sc2 is on a distinguished road
Default Re: 2003 ion quad coupe stalls
Most likely the car has the infamous VTi transmission.
If you can....walk away from the car and look for an 05 and up QC.
The problem may stem from the trans dragging the engine down until it stalls....
Do yourself a favor........walk away and tell the person selling the car "No thanks".......
You don't need the headache.....
79sc2 is offline   Reply With Quote
Old 09-22-2009, 10:55 AM   #3
2006 ion2
2007 ION-2 Sedan
the VTI trans usually just won't move the car, but I suppose it could be that.....
and I agree, if you buy an ion with a CVT, buy it for very little assuming you are going to have to put an aisin 5 speed auto in it, or just find a nice sedan if you can't afford a newer car.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 09-22-2009, 01:15 PM   #4
SaturnTech122
SaturnTech122 is on a distinguished road
i had one with a similar issue, would stall when you turned the headlights on, was a loose chassis ground up by the drivers side headlight
Certified Saturn Technician
SaturnTech122 is offline   Reply With Quote
Front sway bar for a 2003 Ion2 Quad Coupe hunter10 Ion Tech 5 03-06-2007 12:08 PM
For Sale: 2003 Saturn Ion Quad Coupe Level 2 ferragame Classifieds 1 02-27-2006 03:47 PM
Changing the gear ratios in a 2003 Quad coupe? bgsneeze Ion General 9 11-24-2005 10:36 AM
2003 Ion Quad Coupe between5and7 Ion General 3 04-25-2005 11:34 AM
Trading in my 2003 ION Quad Coupe mich_car_guy Ion General 7 12-24-2003 09:12 AM
