Old 08-25-2009, 07:40 PM   #1
jesposito45
jesposito45 is on a distinguished road
Default 2005 Ion Driver Window Problem
My driver window will not go down. All other windows work properly. I replaced the main switch that controls all windows from the driver's side as well as checked both fuse boxes. Window still does not work. Any suggestions on what else to try?
jesposito45 is offline   Reply With Quote
Old 08-26-2009, 12:03 AM   #2
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
Default Re: 2005 Ion Driver Window Problem
No just keep buying parts untill you spend your money on the correct one. Don't test to see what works or not just buy more parts. Maybe if you buy a power mirror switch that will take care of your problem.
SaturnSdn is offline   Reply With Quote
Old 08-26-2009, 12:07 PM   #3
2006 ion2
2007 ION-2 Sedan
test the motor, check the wiring, and check the regulator. does the window try to go up?
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 08-26-2009, 04:45 PM   #4
SaturnTech122
SaturnTech122 is on a distinguished road
old fashioned driveway method: Remove inner door panel, tap the window regulator motor with moderate force while pressing on appropriate window switch, if motor begins to work you most likely have bad spots in the motor windings. the correct way would be to remove connector from window regulator motor and check for power and ground with a test light, if both are good then you need a motor if not it must be a wiring issue as you have already replaced the switch
Certified Saturn Technician
SaturnTech122 is offline   Reply With Quote
Driver side window problem Denis Twosaturn S-Series General 5 10-20-2009 11:52 AM
Front driver side window problem 97 SL2 vigormusic S-Series Tech 4 10-30-2006 02:20 PM
Problem with Driver Side Window firstsaturn05 S-Series General 6 10-30-2005 09:34 AM
What to Do? What would you pick 2005 L Series or 2005 ION 3?? read on SilverPlumGirl Ion General 6 03-07-2005 12:53 PM
What to Do? What would you pick 2005 L Series or 2005 ION 3?? read on SilverPlumGirl L-Series General 2 03-03-2005 09:36 PM
