Old 08-12-2009, 02:12 AM   #1
l98_700r4
l98_700r4 is on a distinguished road
Default LS1 transaxle side cover
Hi,
I'm replacing the TCC solenoid on my 2000 LS1, along with it I'll be replacing the PCS since I've read that they fail frequently.
I have the transaxle side cover loose, but I cannot seem to get it out. I found the "remove front subframe" step in alldata and I'm preparing to do that, but I thought I'd ask a couple questions.
If I was to remove the battery bracket that is spot welded to the frame (and reattach it later with rivets) would that get me enough clearance to remove the cover from the top?
The alldata procedure mentions that a frame alignment tool is used when removing the front sub-frame. I don't have this tool, so how far off can I really get with the frame alignment if I'm able to run in all of the bolts?
Would it be enough to simply lower the driver's side of the subframe and let the passenger side stay bolted up?
Thanks much!
l98_700r4 is offline   Reply With Quote
Old 08-12-2009, 10:51 AM   #2
SaturnTech122
SaturnTech122 is on a distinguished road
Default Re: LS1 transaxle side cover
slightly lower subframe on only the side, be careful not to drop the clips that hold the solenoids in would be a catastrophe
Certified Saturn Technician
SaturnTech122 is offline   Reply With Quote
Old 08-14-2009, 04:13 AM   #3
l98_700r4
Thanks for the info!
So do I even need to loosen the bolts on the opposite side? I assume I couldn't affect the frame alignment that much if I'm only lowering one side, I did scribe markings around the bushings just to be sure.
The solenoid clips just pry out of the valve body I think? Are there any springs behind either solenoid that have a tendency to fly out (or anything else that likes to go flying)?
Thanks!
2000 LS1 Rear drivers-side door is stuck in the lock position sjoyce54 L-Series Tech 3 01-08-2008 10:58 PM
how to remove drivers side axle from the transaxle? lucky13 S-Series Tech 5 12-27-2006 02:36 AM
WTB: 2000 LS1 Drivers Side Headlight 1995-SL1 Classifieds 1 08-31-2005 02:10 PM
Transaxle rear cover removal whitelightning S-Series Tech 8 06-01-2004 09:30 PM
LS1: Water Trapped in Driver Side Wiper Well. Jerry L-Series General 11 10-20-2000 03:20 PM
