Old 02-16-2007, 04:21 PM   #1
spikerizzo
spikerizzo is on a distinguished road
spikerizzo's Avatar
Default Correct Air Pressure in Tires
I have 235-60-70 Duelers. The recommended pressure on the tire sez max. 44psi. What do you guys recommend?
Also what tourqe(sp?) should the lug nuts be for the 17x7 inch wheels?
Thanks peeps
spikerizzo is offline   Reply With Quote
Old 02-16-2007, 04:43 PM   #2
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Default Re: Correct Air Pressure in Tires
Did you read the sticker what the factory recommends? I believe it's by the drivers side rear door. After the rear suspension recall I believe they recommended a higher pressure.
I have Turanza tires and I use 35-40 lbs in all 4 tires. I found 35-37lbs to be a good compromise between handling and ride in my tires.
Old 02-16-2007, 04:56 PM   #3
zukgod1
zukgod1 is on a distinguished road
zukgod1's Avatar
Thanks peeps
What the hell kinda tire size is that? "235-60-70"
dan
98 SL2. A work in progress!
zukgod1 is offline   Reply With Quote
Old 02-16-2007, 06:33 PM   #4
gstien
gstien is on a distinguished road
70's?
That's like a Monster Truck Tire!
We aren't serious, so don't get mad here!
I found my tires at 30lbs a few days ago, and I'm going to inflate them to about 35, as per the sticker on the door.
gstien is offline   Reply With Quote
Old 02-16-2007, 06:43 PM   #5
body-snatch-her
body-snatch-her is on a distinguished road
body-snatch-her's Avatar
There is really no definitive "one size fits all" answer regarding tire pressure. It always involves trade offs between wear characteristics, road hazard vulnerability, fuel economy, handling and ride comfort, etc. Different drivers put different priorities on each of these items. In general, higher pressure will help increase fuel economy but a give rougher ride, and increase (road hazard) puncture risk. Each tire make, model and size has an ideal pressure for balanced treadwear, but may not provide a good balance of the other factors. Beyond this since each different vehicle model applies different forces (i.e. weight) so the ideal varies considerably, which is at least partly why tire manufactures don't recommend pressures (except for maximums). The recommended pressure derived from the door sticker is a good starting point for the make/model/size of tires Saturn put on at the factory (perhaps modified by the recall). Change to different tires and all bets are off, but the sticker would still be a reasonable starting point. Trial and error over an extended period is really the only way to find out what is best for you! Good Luck!
FWIW, I've found it easiest to start with higher pressures and slowly bleed air out of cold tires as required rather than having to progressively pump air in! That's just me though!
I'll leave it to someone else to address the lug torque question...
"Together we WILL destroy the planet! (Evil Plot 2-B)"
body-snatch-her is offline   Reply With Quote
Old 02-16-2007, 06:45 PM   #6
Ritz
Ritz's Avatar
Thanks peeps
35psi (cold tire pressure...not after you've been driving)
Cheers,
Old 02-16-2007, 07:02 PM   #7
spikerizzo
spikerizzo's Avatar
Thanks peeps
Ooooops! sorry I meant 235-60-17 tires.
Thanks Peeps.
Old 02-16-2007, 07:12 PM   #8
nakman
nakman is on a distinguished road
nakman's Avatar
The ratings on the sidewall are the maximum allowed by the tire. Always refer to the vehicle/manual for air pressure requirements. For example, the Duellers are used for different vehicles which have various handling and load requirements. One vehicle may require lower psi to work with its suspension etc.
Not sure about the torque specs? Anyone?
2007 VUE FWD 3.5L, Storm Grey
2008 Honda Accord, 2.4l, auto, Black
(Pic is the 03 VUE, 4 banger, 5 spd, gone but not forgotten)
nakman is offline   Reply With Quote
Old 02-16-2007, 07:49 PM   #9
mellissam
mellissam will become famous soon enoughmellissam will become famous soon enough
mellissam's Avatar
2006 VUE 2.2L
100lbs
'Silven'
K&N / Sheep seats / Run Brds / Roof Rack / Fog Lps / Trailer Hitch / Air Horns / LEDs / Power Inv. / Cool Blues
mellissam is offline   Reply With Quote
Old 02-16-2007, 10:29 PM   #10
hasitha
hasitha is on a distinguished road
Originally Posted by mellissam View Post
100lbs
35 psi (cold) and 100 lb-ft
hasitha is offline   Reply With Quote
Tire Pressure for Non-OE tires 20VUE06 Vue General 11 09-12-2009 09:21 AM
Air pressure for new tires/rims? angelaw S-Series General 10 03-31-2008 10:35 PM
Correct tire pressure for L Series? usa4624 L-Series General 4 02-05-2006 03:40 PM
Correct tire pressure for 205-40-17 on 93 SL1 GmG S-Series Mods 4 06-19-2004 01:17 PM
Air pressure vik S-Series Tech 6 08-07-2002 11:38 AM
