Old 02-17-2006, 11:00 PM   #1
adhhaahok
adhhaahok is on a distinguished road
adhhaahok's Avatar
1993 SC2
Default Need To Know The Correct Tire Inflation
So, i got 17" wheels with 205/40's on them. they have a max press of 49 PSI. the shop that mounted and balanced them said that 40 in the front and 35 in the back was where it needed to be. they are currently at 45 in the front and 40 in the back. he said that if i have them at 49 all around, they will wear very quickly in the middle of the tires. anyone have any recomendations for me? thanks a lot guys.
Anthony
If you baby your car, it will baby your wallet...If you abuse your car, it will abuse your wallet.
1993/1995 SC2. You decide. http://www.cardomain.com/ride/2234915
Add to adhhaahok's Reputation
Rate the quality of this post and help adhhaahok reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adhhaahok is offline   Reply With Quote
Old 02-17-2006, 11:06 PM   #2
1995 SC2 is on a distinguished road
Post Re: Need To Know The Correct Tire Inflation
I would go with what the Tires say!
Add to 1995 SC2's Reputation
Rate the quality of this post and help 1995 SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1995 SC2 is offline   Reply With Quote
Old 02-17-2006, 11:58 PM   #3
Sky King
Sky King's Avatar
Default Re: Need To Know The Correct Tire Inflation
Well the tire guy is right about them wearing in the center if they are overinflated. The high pressure causes the tire to "bluge" and the car rides on the center of the tire. The opposite is true about underinflation. The tires will wear primarily on the edges. You have to keep in mind that you have a light car and it won't take too much pressure to be overinflated.
I was about to say refer to the tire inflation placard in the car but I am not sure how applicable that would be with the non stock tires.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-18-2006, 03:37 AM   #4
Uzzy
Uzzy's Avatar
2002 SC1
For this one I would listen to the guys at the tire shop. The listing of 49 psi is the maximum safe, not the recommended pressure, that varies with the application. I recently got the same size tire, and just go 35 all the way around.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 02-18-2006, 04:03 AM   #5
wolfman
wolfman's Avatar
You'll need to do some math. Figure out the size of the CONTACT patch of the tread of the new tires (in sq. inches) and compare it to the size of the contact patch of the OEM size tires. (in sq. inches) Then do the math.
Example:
OEM contact patch = 12 sq. inches (3 X 4) standard inflation is 33 psi. 33 x 12 = 396
"New" contact patch = 20 sq inches (4 X 5) 396/20 = 20 PSI
That is your starting point as far as what is needed to support the weight of the car. The rest is a matter of "tuning" to what makes the TIRE perform the way you want it to. 45 and 40 is WAAAAYYY too MUCH, and will make the car ride like a tank, handle like a skate board, and center wear the tires like nobody's business.
Add to wolfman's Reputation
Old 02-18-2006, 09:30 AM   #6
spencerforhire
spencerforhire will become famous soon enough
spencerforhire's Avatar
2001 SC1
Old school tire inflation test- A short burnout on a smooth patch of concrete; look for even tire contact. If too light in centre of stripe, increase inflation untill even. I guess on a FWD car you could apply e-brake and check all 4 at once!
Add to spencerforhire's Reputation
Rate the quality of this post and help spencerforhire reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerforhire is offline   Reply With Quote
Old 02-18-2006, 09:48 AM   #7
Razorbak
Razorbak's Avatar
You'll be waiting for a long time to see a burnout from those rear tires. But I'm sure the diff pin will be happy.
Add to Razorbak's Reputation
Razorbak is offline   Reply With Quote
Old 02-19-2006, 01:29 PM   #8
spencerforhire
2001 SC1
I think you missed the point; if the e-brake is on,the car will drag the rear wheels enough to see the rear contact patch as well.
Old 02-20-2006, 01:12 AM   #9
eRic 02sc2
eRic 02sc2's Avatar
the correct tire pressure would normally be 30 psi front and 26 psi rear. however, if the 205/40-17 tires you bought don't have a load index of at least 87 then you probably need more air in them than the normal amount. you should contact the tire manufacturer and tell them that your Saturn OE tires were 195/60-15 with 30 psi front and 26 psi rear and they had a load index of 87 and ask them what they recommend. let them know your Saturn weighs about 2400 lbs. the pressures marked on the sidewall of the tires are the MAX pressure that the tires can handle, not a suggested pressure for any particular vehicle. what is the load index and speed rating of the tires you got? it should be something like 87H or 91W or 85S or something like that with a number and letter together. the stock tires for example are 195/60-15 87H. what brand and model tires did you get?
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 02-20-2006, 01:45 AM   #10
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
30 in the front 26 in the rear. Check the sticker on your door. Always go by that unless the rating on the door is higher than the max on the tire.
Carmen
1998 2.4L swapped Plymouth neon is my ride.
Add to bigc791's Reputation
Rate the quality of this post and help bigc791 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigc791 is offline   Reply With Quote
Correct Tire inflation 2002 L200 Mercrewser L-Series Tech 2 12-24-2009 02:00 AM
Epistle on Proper Tire Inflation hufhouse L-Series Tech 2 09-18-2007 02:58 PM
Tire inflation question... Arnel General Saturn Discussion 1 09-29-2005 10:38 PM
2002 SL1 tire inflation recommendations.. SpencerportNY S-Series General 10 07-06-2005 03:59 PM
Tire INflation metgol S-Series General 11 10-16-2004 02:34 AM
