Old 05-23-2020, 11:02 AM   #1
IONic_2004
IONic_2004 has a spectacular aura aboutIONic_2004 has a spectacular aura aboutIONic_2004 has a spectacular aura about
IONic_2004's Avatar
2004 ION-2 Quad Coupe
Default 2004 vue 2.2 p0480
im having a problem with my low speed cooling fan. problem it runs non stop whenever the engine is running. key on engine off it doesnt run. i have checked the fuses the relays and even swapped the relays with the high speed relay. i replaced the coolant temperature sensor, cooling fan resister located behind the driver headlight (i replaced the correct one not the DRL resistor) what happens is the cooling fan is always running. i checked and got code P0480, if i clear the code the fan shuts off and turns back on a few seconds later. i know clearing the code doesnt fix the problem but when the code comes back it comes back as a pending code, then the next key cycle it triggers the CEL
i did some research on this forum and removed both relays and jumped terminals 30 and 87 on both low speed and high speed and the fan runs when doing this
i also read the AC pressure switch might have something to do with it so i unplugged it and didnt change anything. im out of ideas so if anybody has any other suggestions? im not that good at electrical diagnosis but with this Covid-19 stuff i have been laid off and cannot really afford to take to a shop which is usually what i do when stuff becomes too much for me which is why any help is appreciated
i do own a multimeter. the vehicle is a 2004 VUE 2.2 5 speed
2004 Saturn Ion Redline
2004 Saturn VUE
2002 Chevrolet Trailblazer
1980 Ford Pinto Prostreet
IONic_2004 is offline   Reply With Quote
Old 05-25-2020, 08:15 PM   #2
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Default Re: 2004 vue 2.2 p0480
The DTC P0480 is for the ECM detects an open on the low speed cooling fan relay control circuit. I suspect the ECM is switching on the high speed fan because the low speed control circuit has an open.
Recheck the 20 amp cool low fuse. also check that both legs of the fuse fits tight in to the fuse block terminals. (an old fuse with one leg cut off makes a good terminal tightness tester). You can also remove the fuse block then inspect all of the terminals on the bottom of fuse block and in the harness connector. If you are over 40 use reading glasses and a flash light. inspect for burnt terminal and or melted plastic. When reinstalling the fuse block don't forget to tighten the (3) 7mm bolts.
Dreaded P0480 and P0481 code bitterman Vue Tech 12 01-06-2020 02:08 PM
Saturn L200 P0480 error Aleka L-Series Tech 8 05-18-2016 08:18 PM
P0420 and P0480 Codes barnold Vue Tech 9 03-02-2016 02:15 PM
04 saturn vue dtc code p0480 babygirlnes Vue Tech 8 10-07-2011 08:58 PM
05 Saturn Code P0480 smokyvue Vue Tech 15 05-20-2009 01:35 PM
