Old 11-14-2011, 12:41 AM   #1
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
Default How-to: Remove and replace saturn transmission
Here's a how-to video series on how to remove and replace your automatic transmission.
The manual is essentially the same, except for the clutch hydros and the shifter cables.
The first video was shot with my MTB helmet cam and the sound is a bit low.
Part 1:
http://www.youtube.com/watch?v=PCD4P9YlE7g
Part 2:
http://www.youtube.com/watch?v=Kau4C5xsjZw
Parts 3:
http://www.youtube.com/watch?v=blESDqNh7rc
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 11-14-2011, 01:54 AM   #2
off-track
off-track's Avatar
Default Re: How-to: Remove and replace saturn transmission
Another great effort Shawn! I saw a couple of minor things skipped but probably nothing worth mentioning? Kudo's on doing it by yourself. I'd certainly get my son to help if I needed to swap one.
Too bad on the sound in the first one. The wife btch'd about the BONG of you pulling it out of the wheel well. It did make the sub vibrate quite a bit.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 11-14-2011, 01:25 PM   #3
ShawnV
ShawnV's Avatar
Thanks! Please do add anything that you think would be helpful!
I do all my saturn work alone and I forgot to mention that a auto tranny swap takes me about 5 hours, depending on how much time it takes to un-mate and re-mate the tranny.
Oh and I'm glad your bass is working!
Old 11-14-2011, 03:01 PM   #4
td1238
I've said this before, but noone believes me. If the brake lines are in good condition, it's a lot easier to unbolt the master brake cylinder and bend it up and towards the fender. Then lift the trans up and out of the car. Might not be possible with an autotragic, but is very do-able with the manual.
Add to td1238's Reputation
Old 11-14-2011, 03:21 PM   #5
ShawnV
ShawnV's Avatar
Hmm.. I've never done it like that, but how can it be easier working against gravity with a transmission rather than with gravity? Have you removed the tranny through the wheel well for comparison?
Old 11-14-2011, 03:38 PM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
We have a Saturn transmission removal video as well. We did it a little diffrent.
http://www.youtube.com/watch?v=BP-ByO5J37w
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 11-29-2011, 11:43 PM   #7
dano2201
dano2201 is on a distinguished road
1998 SC1
I just did the r & R to the tranny in my 1998 SC1, to replace clutch. I hadn't done anything like that in 30 years. went pretty smooth, except for getting the right tools to do some of the job. INstallation went good, infact too good. Everything was falling in place too easy. Went to put fluid in it and it leaked out as fast as i was putting it in. Turns out I sliced the left output shaft seal. Got everything apart for that job, now I don't have a seal driver to get the new seal in place. anyone got leads as to wear I can get the proper seal driver? If you is familar with that seal, you'll know that it is domed out, making it impossible to use the trusty ole 2x4 as a driver.
Thanks for any information,
dano
Add to dano2201's Reputation
Rate the quality of this post and help dano2201 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dano2201 is offline   Reply With Quote
motor mount remove and replace jjdrinane S-Series General 9 03-18-2011 10:32 AM
Radio not working right? Remove/replace fuses! David 93 SL2m Vue Tech 0 01-02-2011 05:04 PM
How do you remove / replace hub bearings on Saturn SC1 2002? travisj027 S-Series Tech 2 12-25-2008 08:37 PM
Remove, Replace or Repair Oil Pan on 2006 Saturn Ion 2.2L d77reno Ion General 0 09-08-2007 05:36 PM
How do i remove the door panels to replace the speakers carkid87 Miscellaneous Tech 1 05-02-2004 12:09 PM
