Old 07-25-2010, 12:54 AM   #1
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2000 SW2
Default How-to remove and replace intake manifold + gasket
Here's a how-to vid on removing the intake manifold on a 2001 sl2. I got this car and a coolant line on the intake manifold was broken off. I had a spare intake and I swapped them out.
http://www.youtube.com/watch?v=HHsGBRmZd5w
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-25-2010, 02:02 AM   #2
off-track
off-track has a spectacular aura aboutoff-track has a spectacular aura aboutoff-track has a spectacular aura about
off-track's Avatar
Default Re: How-to remove and replace intake manifold + gasket
Another good one Shawn! I hadn't realized that the Gen III's intakes were so different! from the earlier ones.
Going for the 2010 Richpin award? Slow the pace a little. Maybe it's a difference between MA and CO state of mind? Of course, I'm just rib'n.
1997 - SL2, barebones, 161k, Auto - Rebuild complete and.. burnt a valve 20k later Arrgh!
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
off-track is offline   Reply With Quote
Old 07-25-2010, 10:24 AM   #3
ShawnV
ShawnV's Avatar
2000 SW2
haha - naw. I just had the opportunity to make a how-to with this job becaus I don't recall seeing one. Plus I'm not a mechanic so when I say things like "I unplugged this electrical connector, whatever it is" you should know that I'm not going for any awards
Plus, I've taken a whole lot from this site and I want to contribute as best I can with my limited knowledge. Making how-tos is a way for me to do that.
Old 07-26-2010, 11:23 AM   #4
iuam
iuam is on a distinguished road
Is it absolutely necessary to move the engine forward to remove the intake? did you have to loosen the transmission at all to move it? Is there any torque specs and sequence of tightening the intake bolts back on?
Add to iuam's Reputation
Rate the quality of this post and help iuam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
iuam is offline   Reply With Quote
Old 08-19-2010, 01:10 PM   #5
ShawnV
ShawnV's Avatar
2000 SW2
I think it was necessary to move the engine forward. I had a terrible time getting the intake back in. I only loosened the engine from the passenger side, but if I were going to do this repair again I would strongly consider removing the driver dogbone to allow more wiggle room.
I'm not sure what the torq specs are on the intake.
Old 08-19-2010, 02:47 PM   #6
The How To Library to the rescue:
(not sure these are the bolts you asked about or whether we're talking SOHC/DOHC - or even what year, as the torque specs changed on some things over the years - so I quoted several and the link so you can check yourself. If you put your year and model, you can sometimes get a more specific answer)
http://www.saturnfans.com/forums/sho...ntake+manifold
Originally Posted by wolfman
Intake Manifold Retaining Nuts 22
Intake Manifold Support Bracket to Engine Bolt
DOHC
LH Side 22
RH Side 41
SOHC 22
How to Remove intake manifold 03 vue v6 willieblaze Vue Tech 34 07-28-2010 09:31 AM
How to Remove intake manifold 03 vue v6 willieblaze Community Center 2 12-24-2008 03:41 AM
How to Remove intake manifold 03 vue v6 willieblaze Ion General 4 12-21-2008 12:00 PM
SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket? jcw S-Series Tech 4 05-09-2008 03:42 AM
Can I replace an Intake Manifold Gasket on my own? Hamster S-Series Tech 3 02-15-2006 06:53 PM
