Old 05-16-2018, 02:25 PM   #21
Default Re: Took a gamble, bought a tech2 clone (Tech2Win)
Originally Posted by Mark_b View Post
I saw some people doing 64bit installs but I have this old laptop and I have some work for it right away. I want to get up and running fast like you did.
My sonís 96 is still throwing a P0302 Cylinder 2 Misfire Detected. But there is no miss.
I have seen where people on here have done a crank angle sensor relearn and fixed this on a 96.
Not sure if that will fix it but I want to give it a shot.
Crank relearn usually fixes it or reprogram to the latest firmware as there is a misfire detection sensitivity error in the early 96 firmware.
Old 05-16-2018, 03:29 PM   #22
RobertGary1
RobertGary1 is just really niceRobertGary1 is just really niceRobertGary1 is just really niceRobertGary1 is just really niceRobertGary1 is just really nice
1996 SC2
What actually causes it to need to relearn? I've removed the timing chain on my 96 and belt on my 2006 and never did the relearn but never had issues. When I re-time the chain shouldn't it be the same as before I previously shut the car off? How does it know the timing chain was off?
-Robert
RobertGary1 is online now   Reply With Quote
Old 05-16-2018, 03:40 PM   #23
Mark_b
Mark_b has a spectacular aura aboutMark_b has a spectacular aura aboutMark_b has a spectacular aura about
1996 SC2
It does not know the timing chain was off.
I replaced the crank angle sensor.
A new crank shaft or a new motor could cause the need for a relearn.
Sometimes you can replace CAS and not do a relearn but our 96 is throwing a code for no reason.
Time to try a relearn.
Add to Mark_b's Reputation
Rate the quality of this post and help Mark_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark_b is online now   Reply With Quote
Old 05-17-2018, 03:20 PM   #24
craftsman70
craftsman70 is on a distinguished road
You only have to buy subscription to program modules.
They now have a $40 for one car for 2 years. (This lets you program modules for one VIN)
https://www.acdelcotds.com/acdelco/action/subscribehome
I'd add that you don't have to buy the subscription to program new modules. CDROMs with all of the GM modules can be found easily on the internet. I use a tech2 clone and a CD to program a new BCM last year.
Add to craftsman70's Reputation
Rate the quality of this post and help craftsman70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
craftsman70 is offline   Reply With Quote
Old 05-17-2018, 03:32 PM   #25
Most of the recent firmware has escaped to the internet. Before paying off GM/FORD etc. it is worth a good internet search.
Old 05-17-2018, 03:52 PM   #26
The reason for a relearn when the crankshaft or the CKP(crankshaft position sensor) is manufacturing tolerances in making the pickup and/or the crankshaft notches. The misfire detection is comparing the time of the last notch to the next one and when it detects s decrease in angular velocity greater than threshold it counts as a misfire. Small changes require several repetitive occurrences in a given time period and large ones are an immediate code.
The 96 was originally set to a very tight tolerance later relaxed in firmware updates.
Old 05-18-2018, 12:19 AM   #27
RobertGary1
1996 SC2
Thinking about getting the vxdiag pro. Twice the price but does GM and Ford as I understand it.
-Robert
Old 05-18-2018, 08:08 AM   #28
If you have late model multiple make vehicles that makes a lot of sense dollar wise.
Old 05-22-2018, 09:12 PM   #29
rk80
rk80 is on a distinguished road
Originally Posted by Zeebins View Post
About a week ago I added a cruise to my car but I needed the computer to be programed so it would actually work. I went to one chevy dealer that claimed they could do it but ended up not being able to. I then called 5 others in the area and none of them where able to (or wanted to) turn on cruise either.
I saw that Kaervak recently bought a Tech2 clone that looked liked it fully worked as a real Tech2. $300 is a little steep of a price to pay though for something I may only ever use for turning on cruise control. I did some searching around for some cheaper alternatives and I came across this on the Corvette forms, A Tech2Win adapter. It's essentially the software of a tech 2 running on a windows computer and connects to the car through either a USB or wi-fi adapter. It was $120 on amazon, a lot cheaper than a full hardware Tech2 clone and the dealers I was calling where somewhere around $120 for a minimum shop time charge, so it seemed worth trying out.
It was delivered earlier today and in the box was the OBD2 adapter, a micro usb cable, and a CD of software. The software it came with included, GM MDI Manager, VX Manager, Tech2Win, and VMPlayer. I installed all of them except for VMPlayer as it's only needed if you'll be running the other software from inside a virtual machine.
Once the software/drivers where finished installing, The Tech2Win software was able to recognize the adapter and connect to the car. After going though some menus I got to the option programing and was able to turn on cruise control. Went out for a test drive and I can confirm that cruise control now works.
This this is a pretty cool device and probably the most advanced scan tool i'll ever own. As far as I can tell, anything that a real Tech2 can do, this thing can also do. If anyone has any questions about the Tech2Win feel free to ask me
I've taken some photos and posted them to an imgur album as well as to an album on this site incase anything ever happens to imgur.
link to imgur album - https://imgur.com/a/mpaJxgn
Will this communicate with a 2002 VUE?
Add to rk80's Reputation
Rate the quality of this post and help rk80 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rk80 is offline   Reply With Quote
Old 05-22-2018, 10:51 PM   #30
Zeebins
Zeebins is a jewel in the roughZeebins is a jewel in the roughZeebins is a jewel in the rough
Zeebins's Avatar
Yes, it will. It should work with all GM cars made between 1991 and 2013. Although, it used an OBD2 connector to communicate with the vehicle so it's probably more like any 1996-2013 car.
In England, they drive on the left side of the road. In New England, we drive on what's left of the road.
1997 SL2, 107K miles ~ My first car, trying to make it count
Add to Zeebins's Reputation
Zeebins is online now   Reply With Quote
Old 05-22-2018, 10:55 PM   #31
Mark_b
1996 SC2
It will work with GM cars 2013-2018 you have to use the GDS2 software that is included.
Old 05-22-2018, 11:26 PM   #32
Zeebins
Zeebins's Avatar
Is the GDS2 software it's own program? I don't remember seeing that on my CD
Old 05-23-2018, 07:13 AM   #33
Mark_b
1996 SC2
You have to install VMware on 64bit machine. Then extract the compressed image free winzip7 can extract it. Then run VMware open new VM point it to the extracted image. There are some YouTube videos showing how to do it but they don't show you have to extract the image.
Old 05-23-2018, 09:56 AM   #34
RobertGary1
1996 SC2
Mine seems to be working. Only issues Iíve had are.
1) the mdi program wonít run; just gives an error. But I donít know why Iíd need to run it.
2) the connector is physically too fat for the Vue. The trim prevents it from plugging all the way in. You could remove the trim around the plug or I just ordered an odb2 extension cord on amazon.
3) I had a lot of problems installing software originally because i downloaded it from the links they sent. Ignore those. Mine came with a usb stick that has all the software and it works. I have the pro. I think the non-pro comes with a cd
Iíve got both tech2 running and Ford ids. I donít think there is anyway to test the gm programming ability without buying a subscription first from acdelo to download the software. I assume when you download you select feature (cruise, transmission etc) and that is how you change configuration in the module.
-Robert
GM Tech2Win software RobertGary1 S-Series Tech 7 05-01-2017 12:28 PM
autozone starter gamble failed RobertGary1 S-Series Tech 18 04-13-2016 07:17 PM
I have a Tech2 barbierij S-Series Tech 2 07-16-2015 03:06 PM
What is possible with access to a Tech2? saleenman S-Series Tech 6 12-12-2012 09:14 PM
Tech2 blen_to Astra Tech 4 10-04-2011 03:28 PM
