Old 01-07-2020, 05:55 PM   #1
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Default New 3 wire horn not working
So i bought a new original horn, when i plugged it in it didnt work, so i played with it, i backed the wiring harness out a little bit to where it wasnt locked in and it worked for a little while then it stopped I tested the wiring for power and continuity and it all checks out could it be a case of bad contact with the pins in the horn
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 01-07-2020, 11:06 PM   #2
toggenburg
toggenburg's Avatar
Default Re: New 3 wire horn not working
If you've verified & reverified 12vdc to the horn and out to ground, then where did you buy the horn at, and will they replace it under 'warranty'?
Another 3 to 2 wire horn conversion thread ryanguy426 S-Series Mods 7 05-12-2019 07:52 PM
I need a good working 3 wire horn Beak3er82 Classifieds 2 06-16-2017 10:38 AM
How to correctly wire 12v 40amp relay for air horn system from 3 wire horn connector? demoncamber S-Series Mods 2 06-20-2013 01:44 PM
need a 3-wire horn... sc2dave Classifieds 2 05-17-2005 12:37 PM
Please help!!! how do i wire the aftermarket horn ton0831 General Saturn Discussion 2 03-18-2005 08:34 PM
