Old 06-26-2016, 10:33 AM   #1
cityhawk
cityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to behold
cityhawk's Avatar
1993 SW2
Default help! key stuck in acc position.
I parked my 1993 SW2 in preparation to go for a run and was sitting with the windows open texting before getting out of the car. I went to turn the key to ON to close the windows and the key won't budge.
The radio isn't working so perhaps it's stuck somewhere just before the accessories-on position.
Saturns:
1993 SW2 MT 205,000 hard Boston city miles ("Rozzie")
Gone but not forgotten:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
1966 Corvair Monza convertible
1928 Ford Model A Tudor Sedan
Add to cityhawk's Reputation
Rate the quality of this post and help cityhawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cityhawk is offline   Reply With Quote
Old 06-26-2016, 10:42 AM   #2
cityhawk
cityhawk's Avatar
1993 SW2
Default Re: help! key stuck in acc position.
Here's a picture of the lock... for what it's worth.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 06-26-2016, 10:51 AM   #3
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
Try gently tapping on the key while turning it. I would suggest you replace the cylinder assembly asap.
1992 SC
1994 SW2
1997 SW2
others in my yard
Add to johnny95sl2's Reputation
Rate the quality of this post and help johnny95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnny95sl2 is offline   Reply With Quote
Old 06-26-2016, 11:13 AM   #4
cityhawk
cityhawk's Avatar
1993 SW2
Tried that. Nothing. Only thing I have in the car to tap with is a toy phone.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 06-26-2016, 06:18 PM   #5
96satsl2
96satsl2 is on a distinguished road
Try turning the steering wheel as youbturn the key the steering wheel lock could be in stupid mode
Add to 96satsl2's Reputation
Rate the quality of this post and help 96satsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
96satsl2 is offline   Reply With Quote
Old 06-27-2016, 10:53 AM   #6
Highcloudy
Highcloudy has a spectacular aura aboutHighcloudy has a spectacular aura about
1998 SL
When this happens to me, i take a screwdriver and tap it against the back of the key. Loosens it up for me.
Add to Highcloudy's Reputation
Rate the quality of this post and help Highcloudy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Highcloudy is offline   Reply With Quote
Old 06-27-2016, 01:57 PM   #7
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
I have the same problem intermittantly so i quickly turned the wheel all the way to one side and immediately turned the key and it turned off.
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 06-27-2016, 05:54 PM   #8
cuetip
cuetip is just really nicecuetip is just really nicecuetip is just really nicecuetip is just really nicecuetip is just really nice
1997 SW1
Sounds like you locked the wheel. Try turning the wheel to the left or right slightly while trying to turn the key to OFF. If it doesn't budge going in one direction, try the other. Rinse and repeat until it's unlocked.
Add to cuetip's Reputation
Rate the quality of this post and help cuetip reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cuetip is offline   Reply With Quote
Old 06-27-2016, 07:24 PM   #9
RobertGary1
If you have broken tumblers you'er going to have to take the cylinder out the hard way. This is why you want to lube the cylinder yearly. And always use fresh keys. When they keys start to round off toss them.
-Robert
Old 06-28-2016, 10:12 PM   #10
I-4
I-4 will become famous soon enough
I-4's Avatar
Fluid Film is your friend for this. It has kept mine going. And I think that I am on my third key.
Add to I-4's Reputation
Rate the quality of this post and help I-4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
I-4 is offline   Reply With Quote
Old 07-02-2016, 02:41 AM   #11
cityhawk
cityhawk's Avatar
1993 SW2
Thanks for the tips folks. I ended up having to get the car towed home. After taking apart the column (thanks 700+SL2 in a conversation on the S-series Facebook page), I was able to get the cylinder out. I could then start the car, but couldn't shut it off. It seems the housing is jammed as well. The cylinder had a piece broken off and possibly this jammed the housing. I got a new cylinder on Ebay and I have ordered a new housing. In the meantime I removed the switch from the left side of the column and just use any key in the slot of the switch to turn it on and off/start it etc.
The cylinder is aftermarket. I don't know if I can get GM to change the tumblers for my original factory key code. If not, I'll just have to use two different keys.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 07-02-2016, 09:06 AM   #12
If you buy the cylinder kit on Amazon it comes with sets of wafers and you can re-key your new cylinder. These are for a gen-3 but will sufice for the older car, just fewer parts.
Ignition switch and housing pictures.
http://www.saturnfans.com/forums/sho...9&postcount=50
Lock keying
http://www.saturnfans.com/forums/sho....php?t=182379#
Ignition Switch Replacement.
http://www.saturnfans.com/forums/sho...d.php?t=143680 see post 50
Old 07-26-2016, 02:35 PM   #13
cityhawk
cityhawk's Avatar
1993 SW2
So, I have all the parts, but I have another problem.
The two halves of the steering column cover are held together mostly with screws that have a head size of 5.5mm (7/32" fits). However, the hole closest to the foreground in the photo requires a very deep socket (close to 2 inches) to get at the head of the screw. I ended up breaking it to get it off and glued the shaft back together (it broke at the bottom of the shaft in this photo (actually the top of it since it's upside-down in the picture). I duco-cemented it back together for now and would like to get at the screw so I can take it apart properly to assemble it on the car.
Does anyone have experience with this? I'm thinking I have to use a nut driver since the 1/4" shank for even a deep socket isn't far enough from the tip of the socket... I ground the shank down on my bench grinder of a 7/32" deep socket, but it still wasn't long enough to reach.
I figure that a 7/32" or 5/5mm nut driver with thin walls and a long stem would work. Unfortunately, 5.5mm and 7/32" isn't a common size so I can't find them at the local hardware store (I'm lucky to find 5mm and 1/4").
I saw some on obscure websites when googling, but I thought I'd ask anyone here if they have experience taking this apart and where they got the tool to do it.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 07-26-2016, 03:36 PM   #14
floridasl22002
I too broke my sons' column shroud for exactly the same reason. That said with the bottom part bolted up to the column, the top shroud 'clipped' on top. It wasn't all that secure, but didn't move about. My son ran with it like that until I fessed up and admitted I'd broken it!
I got another shroud set form the JU, but instead of using the hex screws that require the deeeeeeep socket, I used self tapping screws instead. Using a thin philips screwdriver, I don't have stressful issues and the whole thing buttons up fine.
It's a screwy system that Saturn used here.
Old 07-26-2016, 07:52 PM   #15
TORX head screws will work better than Phillips and the normal TORX head deck screw fits fine. You can buy the proper TORX bit that is long enough to reach. Or you can buy that elusive 7/32"(5.5mm) nut driver as it is a standard size for electronics equipment fasteners. The cost for either approach will be about the same.
Old 08-05-2016, 05:34 PM   #16
cityhawk
cityhawk's Avatar
1993 SW2
I got this, which did the trick fine.
https://www.amazon.com/gp/product/B001IULR26
Now I need to get the time to take the housing off of the steering column so I can put it all back together.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 08-05-2016, 06:04 PM   #17
Those work and they are top of the line tools.
Win reg removal when window is stuck in up position. ~ 99 SL1 mdbrill S-Series General 1 10-29-2014 02:01 PM
Key stuck in lock position! Woodpecker S-Series Tech 15 06-16-2012 06:49 PM
Key stuck in ACC position, 95 SL1 tralmek S-Series General 6 07-28-2010 05:57 PM
Ignition Key Stuck in Start Position micosan S-Series Tech 7 06-07-2009 11:35 AM
Key Stuck In OFF Position //Shifter Stiff in P CND_SC1 S-Series Tech 13 08-06-2006 12:01 AM
