Old 07-25-2015, 10:04 PM   #1
dude33333
dude33333 is on a distinguished road
Default Axle replacement
I went to pick your part today for front axles for my 1996 sl2 5sp with ABS.
Out of the dozen or so saturns there was not a single one with abs. I decided to take a set anyways, and practice removing them some I was there. Unfortunately I didn't thouroughly inspect them till after I removed them, there were some small dry cracks on one of them so I left it there. But it was good experience and I got some odds and ends I needed so not a complete loss.
Anyways, wondering if this remanufactured pair of axles made in USA would be a wise investment or if I should keep looking for used?
http://m.ebay.com/itm/2-Front-LEFT-a...615?nav=SEARCH
Also, since I'll have it all apart and need tires and alignment anyways, the rubber on the tie rods was visibly cracked, should I just order new tie rods? What else while I'll be takin it all apart?
Thanks.
Add to dude33333's Reputation
Rate the quality of this post and help dude33333 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dude33333 is offline   Reply With Quote
Old 07-25-2015, 10:18 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Axle replacement
$71 isn't a bad price for a set of 2 re-manufactured ones.
I opted last Dec for a set of 2 NEW napa ones, but they were about $71 each.
Whatever you do, be sure to replace that end (thrust washer or nut was it?) with a new one.
Old 07-25-2015, 10:26 PM   #3
Odd that they says '94-'02 for ABS axles...ABS axles stayed the same '91-'02...it's the non-ABS axles that are stupid small '91-'93...lol
For the effort involved I'd either get low mileage JY axles or brand new axles; though with my usual penchant for buying parts cars I'd just use a known good one from storage... O
Yes, be sure to use a new nut. Like head bolts they're single use, might get away with twice. Unlike Subaru the nut deform's under torque and may not hold 100+ft/lbs a second time (Subaru's have a notch on the end to fold a flange on the nut into to lock it in place similar to a cotter pin).
Old 07-26-2015, 12:01 AM   #4
dude33333
ok so definitely new axle nuts and washers. Maybe i should just do a big rockauto order for axles, nuts and washers, and tie rod ends?
Ive been trying to look up reviews of "detroit axle" and theres not a whole lot on them.... their website says theyve been in business over 20 years...
Old 07-26-2015, 12:03 AM   #5
dude33333
hmmm actually i found that they are formerly dearborn axle, which has pretty poor reviews where I can find them
Old 07-28-2015, 01:26 AM   #6
dude33333
Any other opinions on axles...
Used vs new vs remanufactured
Keeping in mind I DO have ABS but I'm not a fan of it.
Old 07-31-2015, 01:28 PM   #7
toggenburg
toggenburg's Avatar
IMO, abs stops a vehicle further down the road than does conventional braking systems. My suburban has had the ABS relay removed for the last 10 years.
Old 07-31-2015, 02:36 PM   #8
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Check out Rockauto
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 08-08-2015, 03:19 AM   #9
dude33333
I just ordered some "Surtrak" axles from rockauto. there were some a little less and a little more, but these have a lifetime warranty so I'll give them a try. also ordered some bushings came out to $122 with shipping
Old 06-12-2016, 10:47 PM   #10
97blueSL2
97blueSL2 is on a distinguished road
Ok, sorry to re-vitalize an old thread, I have a 97 SL2 in need of a right front axle replacement, largely due to my stupidity Anyways, my car is non-ABS, but all the CV shafts I can find at the yard or parts stores are all ABS. Does that matter?
And as far as changing them, most people say it's fairly easy, are their any hidden things to watch out for.
1997 SL2 5 speed, 257,057....might be waving the white flag.
Add to 97blueSL2's Reputation
Rate the quality of this post and help 97blueSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97blueSL2 is offline   Reply With Quote
Old 06-13-2016, 01:37 PM   #11
ABS will work on non-ABS - can't buy non-ABS these days
http://www.saturnfans.com/forums/sho...d.php?t=179692
How to replace axle with pics (ignore the part about the axle seal - you have to remove the axle to replace the seal, just focus on the parts dealing with the axle)
http://www.saturnfans.com/forums/sho...d.php?t=157297
Old 06-16-2016, 04:54 PM   #12
97blueSL2
Cool, thanks for the help. It probably wouldn't hurt to replace the seals, but at this point I just want the car out of my garage!! It's been a ongoing project for almost two months. Replacing the axle was not anticipated, but when you get careless with a sawzall while cutting out a seized lower control arm bolt...well you get the picture.
Old 06-17-2016, 01:38 PM   #13
Gotcha - I wasn't suggesting you replace the axle seal, just included that second link for the pics, in case you needed instructions or pics. You never know what someone's level of mechanical experience is, unless they state - but it sounds like you know what you're doing
Old 06-24-2016, 01:20 PM   #14
97blueSL2
Well I sorta know what I'm doing. I'm pretty much self taught when it comes to automotive. I can change parts pretty proficiently, but i'd struggle with a complex electrical diagnosis. I've been an aircraft mechanic for 13 yrs. There are lots of "little things" that automotive manuals or technical info seem to leave out, stuff that is only learned through years of experience. But thankfully the Saturns are somewhat easy to work on with the help of this forum.
Old 06-24-2016, 03:58 PM   #15
Well I sorta know what I'm doing. I'm pretty much self taught when it comes to automotive.. . . . I've been an aircraft mechanic for 13 yrs. There are lots of "little things" that automotive manuals or technical info seem
You know more about what you're doing than I do
Also self-taught, and learned from here and YouTube, on auto repairs. At a certain point, you hit a "wall" when trying to do things according to Chilton's. Thank goodness for this forum and the internet. I did take an electronics class once, but that was back when you bought music on pressed vinyl discs. About all I remember is, "Bad boys rape our young girls but Violet gives willingly -Get Some Now"
(before someone gets "triggered," it was a mnemonic for the color bands on resistors and I'm sure it is no longer used, this was decades ago:
Black brown red orange yellow green blue violet gray white
Gold, silver, none)
Axle Replacement Part xlerate Vue General 1 11-01-2013 11:55 AM
Driverside Axle replacement PDF? strikers Vue General 1 04-11-2010 06:10 PM
CV Axle replacement nitsua y zarc S-Series Tech 1 12-26-2007 09:04 PM
03 Vue Axle Replacement Question Staleek Vue Tech 8 11-25-2007 03:05 PM
Front axle replacement. cloud819 S-Series General 5 11-20-2005 09:08 AM
