Old 07-25-2015, 08:28 PM   #1
1996SW2
1996SW2 is on a distinguished road
1996SW2's Avatar
Default neutral safety switch adjustment
Replaced the switch on my 1996 SW2. Got it set to continuity in drive. Shifted through all gears while at rest. Continuity checked out again. Started in park and neutral but not reverse or other gears. Reverse lights worked. Took it for a spin and right away wouldn't shift out of first. Dropped it into 2nd then back to drive and shifted fine. Went to readjust and can't get continuity to save my life. I am using an older volt meter set at 200. All I have read here says put gear selector in drive but chiltons says neutral. Frustraded. It is an aftermarket BWD part no S26033
Add to 1996SW2's Reputation
Rate the quality of this post and help 1996SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SW2 is offline   Reply With Quote
Old 07-25-2015, 08:53 PM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: neutral safety switch adjustment
Most folks here say you are better off with an OE JY part.
http://www.saturnfans.com/forums/sho...81&postcount=3
Add to Chazberry's Reputation
Old 07-25-2015, 09:06 PM   #3
1996SW2
1996SW2's Avatar
I've read that. I'm wondering if it isn't my old multi meter. The probes are a lil tacoed and it's hit tge wrong side of positive or negative once or twice
Old 07-25-2015, 09:32 PM   #4
Chazberry
Chazberry's Avatar
1995 SW2
Try opening up your original switch and see if you can tell what went bad.
http://www.saturnfans.com/forums/sho...d.php?t=203541
Old 07-25-2015, 09:37 PM   #5
1996SW2
1996SW2's Avatar
Already swapped out for warranty. This is second time I've done this. First time was over a year ago. Same issues but once in a while had to start in neutral. Gavit it the finger and just drove it that way. Tags r up so need it to pass emissions. They don't seem to like check engine lights.
Old 07-25-2015, 09:39 PM   #6
1996SW2
1996SW2's Avatar
Just got home with a new multi meter. Se how it goes
Old 07-25-2015, 10:36 PM   #7
There is a very detailed setup for that switch that prescribes which way to rotate it to get continuity, will not work unless directions are followed and most of the aftermarket manuals are wrong. The correct instructions are in my photo gallery.
Old 07-25-2015, 11:04 PM   #8
1996SW2
1996SW2's Avatar
Post Re: neutral safety switch adjustment
That's what I did. Knucklehead question of the day...what if any of the three wiring harnasses should or shouldn't be attached during adjustment process?
Old 07-25-2015, 11:19 PM   #9
Chazberry
Chazberry's Avatar
1995 SW2
You remove the single ground wire from one of the 2 terminals you are going across to check continuity. The other 2 connectors can stay connected.
Old 07-25-2015, 11:26 PM   #10
1996SW2
1996SW2's Avatar
Check and check......Ugh
Old 07-26-2015, 10:07 AM   #11
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Here is a Richpin video
www.youtube.com/watch?v=vjwxw8A08Sw
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 07-26-2015, 12:01 PM   #12
1996SW2
1996SW2's Avatar
I'll check that out after work.
The new multimeter told me I had continuity but it still read 1.2ohm. Starts and shifts as it should, reverse lights work but still throwing code. Think I need a JY part. Any places tgat sell OEM stuff?
Old 07-26-2015, 12:49 PM   #13
Chazberry
Chazberry's Avatar
1995 SW2
Which code are you still seeing?
1.2 Ohms is normal - you are gonna see a little contact resistance.
You would want OE PN 21022303 . . .
http://www.amazon.com/s/ref=nb_sb_no...ds=GM+21022303
http://www.gmpartsdirect.com/results.cfm
Old 07-26-2015, 03:54 PM   #14
1996SW2
1996SW2's Avatar
Not sure. No reader. Will stop after work and get it read.
Old 07-26-2015, 07:13 PM   #15
1996SW2
1996SW2's Avatar
Same Code P0706
Old 07-26-2015, 07:29 PM   #16
According to the FSM if you turn the switch the wrong way (away from the engine rather than towards) you'll get P0706, which sounds like turning it the wrong way breaks the switch
Old 07-26-2015, 07:42 PM   #17
Chazberry
Chazberry's Avatar
1995 SW2
Same Code P0706
Check your ground connection. Put one meter lead on a good chassis ground. Disconnect the ground lead from the TRS Switch and put your other meter lead into that connector. See how much resistance you have.
Old 07-26-2015, 07:58 PM   #18
Puts the mechanical slop on the wrong side.
Old 07-26-2015, 08:29 PM   #19
1996SW2
1996SW2's Avatar
I did find some chafing and a touch of exposed wire on the single lead. I'll splice in a new lead and see what happens. Too damn hot right now to mess with it.
Old 07-27-2015, 12:38 AM   #20
1996SW2
1996SW2's Avatar
I did find some chafing and a touch of exposed wire on the single lead. I'll splice in a new lead and see what happens. Too damn hot today to mess with it.
03 Vue Neutral Safety Switch TonsFun Vue Tech 1 04-14-2012 05:09 PM
Neutral safety switch help Highmile S-Series Tech 2 12-15-2009 02:15 PM
Neutral Safety Switch????? Clickety_Clack S-Series General 10 12-03-2008 10:24 PM
Neutral Safety Switch Adjustment (Please Help) hipstershaun S-Series Tech 4 01-20-2007 07:57 PM
Transaxle Range Switch\Neutral Start Safety Switch lonelywolf8588 S-Series Tech 2 07-20-2006 08:55 AM
