Old 07-24-2015, 08:25 PM   #1
robert98374
robert98374 is on a distinguished road
2002 SL
Default engine idles funny
i have a Saturn and it normally idles at a stop at 1000 rpms however it started to make a clunking sound in the engine and my rpms dropped to 500 rpms my inter lights dimmed and the car almost staled out. ti only lasted a second and the rpms went back up to just under a 1000rpms and the car was fine.
Add to robert98374's Reputation
Rate the quality of this post and help robert98374 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robert98374 is offline   Reply With Quote
Old 07-26-2015, 11:49 AM   #2
Steve44
Steve44 is just really niceSteve44 is just really niceSteve44 is just really niceSteve44 is just really nice
Steve44's Avatar
1999 SL1
Default Re: engine idles funny
You need to have your starting/charging system tested. It sounds like you may have an alternator problem.
The SL1...The Lucky Car
The SL2..The awesome deal.
The #3 Silver SL2 FIVE SPEED!
World's biggest fan of doing it the easy way.
Add to Steve44's Reputation
Rate the quality of this post and help Steve44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-26-2015, 02:34 PM   #3
Bildo Baggins
Bildo Baggins is a jewel in the roughBildo Baggins is a jewel in the roughBildo Baggins is a jewel in the rough
Just the one time or more? Could be a lot of things. See if any codes were thrown.
Bill from Extreme Southern North Carolina
'97 Satty SL2
280Kish miles
Add to Bildo Baggins's Reputation
Rate the quality of this post and help Bildo Baggins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bildo Baggins is offline   Reply With Quote
Old 07-27-2015, 01:33 AM   #4
cdxhizors
cdxhizors has a spectacular aura aboutcdxhizors has a spectacular aura about
2002 L-Series 2.2L Sedan
Mine has done this since I bought it a few years ago. Most my s series do it. I have voltage meters for my amps(sound system) and when the idle drops for a second the voltage drops to 12.7 and immediately back to 14.5 like normal. I've chased it forever and finally pushed it off as the alternator is cycling on or something which causes a momentary load and the engine quickly catches up. I don't know about the sound though you're hearing??
Add to cdxhizors's Reputation
Rate the quality of this post and help cdxhizors reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cdxhizors is offline   Reply With Quote
Old 07-27-2015, 08:34 AM   #5
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
I had a similar problem a few months ago. Eventually my car started
misfiring (dont know if original problem was related) ultimately i had to
replace the ign. control module and coils and havent had a problem since.
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 07-27-2015, 08:51 AM   #6
Bildo Baggins
If I had to guess, I would go with the ICM/Coils or some other related as being intermittent due to corrosion or beginning to fail.
Once in a great while I will get a stumbling after engine has reached temperature and it will clear itself in pretty quick order and then be fine. It is so seldom and always clears up that I cannot isolate. I've cleaned EGR, TB, and replaced wires, plugs, thermostat, etc.
ECTS is good also.
Only remaining variable is fuel pump but it keeps on pumping and this symptom is years old.
'97 Satty SL2
280Kish miles
Old 07-27-2015, 09:30 PM   #7
lancer54
lancer54 is on a distinguished road
One thing I notice, is that if I am stopped somewhere, my old S would do this with the higher mileage engine whenever the fan would kick on. I think it has to do with the end rush current 'taxing' how much power is required to start the fan up when it reaches the temperature causing the fan to kick on.
Assuming that you are at 1000 rpm and sitting after driving, the temps are up enough to where the fan may kick on.
Pay attention next time it happens, to see if it is the fan kicking on while you are sitting! Let us know!
Add to lancer54's Reputation
Rate the quality of this post and help lancer54 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lancer54 is offline   Reply With Quote
New engine idles, won't rev Colorredvue L-Series General 1 03-14-2013 11:57 PM
Engine idles rough Gnfanatic S-Series Tech 49 06-25-2009 12:11 PM
Idle/Throttle/ECTS/Radiator? - Engine Revving High/Idles funny. thawkth S-Series General 3 05-15-2009 12:54 AM
engine idles all over the place worknfolk S-Series General 4 09-05-2007 01:16 PM
98 SC2 idles funny, dies, oil in spark plug well, fixed that, still dies, etc. Kpendrgn S-Series Tech 18 02-03-2007 10:58 PM
