Old 07-18-2015, 05:31 PM   #1
Leot3
Leot3 is on a distinguished road
Default 1997 Saturn SC1 sparking from valve cover?
Long time viewer first time poster. The past couple days my 97 sc1 has been dogging in the top of 4th and 5th gear. Driving home yesterday it gave one big shutter and service engine soon light poped up. Had it read today and P0303 or 3rd cylinder misfire. I swapped out plugs and wires. Coils are clean. After starting it i look under the hood to see the right screw holding down the valve cover sparking from under it. I'm at a complete loss. Any good ideas?
Add to Leot3's Reputation
Rate the quality of this post and help Leot3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leot3 is offline   Reply With Quote
Old 07-19-2015, 06:40 PM   #2
TomM96
Default Re: 1997 Saturn SC1 sparking from valve cover?
>>> Nice Symptom !
Maybe try check 'new' wires with ohmeter... sounds like electrons have easier path to cover than plug.
Plugs frequently 'short' ; never heard one 'open'.
"New" cheap wires act weird initially because the terminal ends are sometimes not contacting the wire or the 'post'....
That's why some us bought Magnecor - less time wire fussing.
Add to TomM96's Reputation
Old 07-19-2015, 06:48 PM   #3
Leot3
It gets worse. I finished messing around with it today and now it runs like crap. The orginal studdering and hesitating it was doing at the top of 4th or 5th gear is now in every gear. Im honestly at a lose.
Old 07-19-2015, 08:42 PM   #4
TomM96
If it makes you feel better:
I installed a cheap wireset ... had to 're-do' the job three times -- involved application of pliers to squeeze the terminal-tubes to make contact on the coil towers.
After that they worked fine for 50/60kMi. ('97 SW2)
Old 07-19-2015, 08:47 PM   #5
Leot3
So as I give up on fixing it and get in it to drive down to the corner garage it starts right up. Runs great through every gear. No studdering what so ever. I stop the the auto parts store and have them read the check engine that came back up after the repair. P0300. The first one i got was p0303. As im pulling out of the parking lot. Light goes away. Car runs like a dream. Should i still be concerned? Anyone else have the first test run after plugs and wires that rough only for it to be fine? I give up even trying to understand it.
Old 07-20-2015, 10:14 AM   #6
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
I had a po300 a few weeks ago. It turned out i needed a new ign. control
module and a coil car runs fine now.
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 07-20-2015, 06:00 PM   #7
TomM96
Leo...
I think it may be good running for a while. Both new plugs and new wires can cause an unexpected/counterintuitive misfire for a little while. I think the connections are sort of "burning in" a connection path through oxide coatings on the towers/plugs.
Not really sure -- did not evidence with Magnecor wireset.
Suggest enjoy while it works, probably 20-40kMi.
1997 sl2 plastic valve cover ERICSSL2 S-Series Tech 6 08-15-2013 01:20 PM
Aluminum Valve Cover on 1997 SL2 MikalCarbine S-Series General 4 05-08-2013 09:16 AM
1997 DOHC valve cover leaks travelgator S-Series General 6 10-02-2007 10:22 PM
1997 Saturn SL2 valve cover travelgator S-Series Tech 2 10-02-2007 10:09 AM
1997 SC-1 Valve Cover macadu S-Series Tech 9 06-17-2005 12:29 AM
