Old 11-11-2008, 03:30 PM   #1
mmaynard
mmaynard is on a distinguished road
Default 2003 Saturn Vue Windshield Wiper ?
The squirter on my front windshield barely works. I thought I was out of fluid but found it to be full. When trying to clean the windshield it only squirrts out an inch or two which is of no help. The back works fine. Someone said it sounds like the motor. I would think it is were the motor no solution would come out. Any suggestions?
THANKS AGAIN.
Add to mmaynard's Reputation
Rate the quality of this post and help mmaynard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mmaynard is offline   Reply With Quote
Old 11-11-2008, 03:57 PM   #2
VTchemist
VTchemist's Avatar
Default Re: 2003 Saturn Vue Windshield Wiper ?
Could be clogged nozzles. Is there any debris or encrustation on the nozzle tips? You could try poking a sewing needle into the nozzle. That may clear up a blockage.
Also, you can access the passenger's side nozzle pretty easily. Remove the black plastic cover by taking out the plastic fasteners (note; pry up the center portion of each fastener with a flat head, it is attached to a small plastic rod that seats the fastener, then you can pull it out).
Have a friend depress the windshield washer button. If it has a weak stream, then your problem may be further downline. It could be the pump is clogged by debris in your fluid container. Rinse it out with a garden hose. You can also backflush the pump (kinda) through the detached passenger hose.
If your pump is good, and the stream to the windshiled is weak, you may be having problems with your nozzles. I had to replace both on my 03 VUE. They are about $5 each at the dealership.
Hope this helps.
Add to VTchemist's Reputation
Rate the quality of this post and help VTchemist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-12-2008, 10:41 AM   #3
1saxman
Here's what I do, but you need compressed air. Raise the hood and find the union in the washer supply line near the reservoir - just pull the connection apart. Starting with the passenger's side, use a small-tip blow gun and blow air directly into the nozzle. You will see fluid being expelled from the open hose near the reservoir. Repeat on the driver's side. Now, to clear the pump and short supply line of anything that may be in there, just turn on the key and hit the washers to blow anything out. Re-connect the supply line and you should be done. I have to do this on my wife's VUE several times a year, and I have no idea why. It is what it is.
Add to 1saxman's Reputation
1997 saturn sl1 windshield wiper problem scartmill S-Series Tech 1 06-21-2009 03:43 PM
Removing Wiper Blade - 2003 Vue stephen67 Vue Tech 5 01-07-2009 08:59 PM
Some 2007-08 Saturn Outlooks Recalled for Faulty Windshield Wiper Linkages Charlie Outlook General 4 08-31-2008 09:08 AM
Windshield Wiper Blade Smearing on Windshield softwheat Aura General 7 02-13-2008 10:44 AM
Windshield wiper Frankiewray S-Series Tech 5 08-27-2007 04:10 PM
