Old 03-29-2018, 08:26 AM   #1
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Default Cant Unlock Door
I cant open the door on my 96 SL1 (power door locks) inside or out.
With the outer panel removed how would you open the latch?
Thank You
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 03-30-2018, 01:38 AM   #2
PrestonIII
PrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura about
1994 SL2
1994 SL2
Default Re: Cant Unlock Door
I may be missing something, but how are you going to get the
outer skin off without opening the door?
Once the skin is off, you can follow the rods from the outer
door lock tumblers down to the latch assembly. I'm betting
that an outer door lock rod is unhooked from the latch, thus the
key does nothing. My car was like that when I purchased it,
and I still haven't fixed it (keyless entry). If it's a back
door, the child safety lock may be engaged, and the outer
handle rod is dislodged. Any one or more of the rods
can be dislodged with a locksmiths tool as he tries to
"jimmy" the door from outside to get it open. That's
exactly what happened to my own car.
If the lock rod is unhooked, you'll have to either take apart
the other door to use as an example, or come up with a
picture of the assembled latch with rods. There are likely
4 rods that hook to it. Inner and outer door handles, and
inner and outer door locks. Pay close attention to the outer
door lock rods on front doors, and outer door handle rods
on rear doors.
Add to PrestonIII's Reputation
Rate the quality of this post and help PrestonIII reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-30-2018, 01:45 AM   #3
PrestonIII
1994 SL2
1994 SL2
Or do you mean that the latch is stuck closed while the door is open, and you
can't get the door to latch closed?
Old 03-30-2018, 10:56 AM   #4
OU812
1996 SL1
I was in an accident and the outer panel was sheared off and the door wont open. Im only assuming at this point its the latch until i really inspect it.
Old 03-30-2018, 12:44 PM   #5
Saturn Night
If you were in a collision, that damaged the chassis area of the latch/striker, it may be jammed. It is still possible to open the door, it just may not actually shut.
Your outer door handle area should have a rod that travels to the latch, for releasing it. You will have to pull it up.
As far as unlocking the latch, there is a rod from the lock assembly you will want to trace.
RKE Door unlock problem TvSteve S-Series Tech 2 10-30-2015 04:30 PM
Driver door unlock mgrafstein S-Series Tech 0 07-09-2012 08:39 PM
95 key will not unlock drivers door drg95 S-Series Tech 2 06-27-2007 12:42 PM
Door Unlock acit_marcl L-Series General 7 06-01-2006 04:42 PM
Door unlock trouble arunsam3000 S-Series General 0 11-20-2005 07:03 PM
