Old 09-23-2015, 09:01 AM   #1
scw2
scw2 is a glorious beacon of lightscw2 is a glorious beacon of lightscw2 is a glorious beacon of lightscw2 is a glorious beacon of lightscw2 is a glorious beacon of lightscw2 is a glorious beacon of light
scw2's Avatar
1999 SC2
Default wipers coming on randomly
My 1997 sw2 recently started having its wipers coming on by themselves. The car has 208,000 miles on it now. What causes this to happen?
Add to scw2's Reputation
Rate the quality of this post and help scw2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scw2 is offline   Reply With Quote
Old 09-23-2015, 09:19 AM   #2
38TransAM
38TransAM has a spectacular aura about38TransAM has a spectacular aura about38TransAM has a spectacular aura about
1996 SL2
Default Re: wipers coming on randomly
Make sure the drains on the cowl area are free and clear if it accumulates here it can get the circuit board and wiper motor wet.
If that all checks out more then likely its the circuit board failing. At least u know the motor is good
Think reman stuff is around the 70-80$ mark, unless u can happen upon a low mileage one at the junkyard.
Saturn OEM GM reman. engine NO LONGER AVAILABLE (SOLD OUT)
96 SL2 still kicking at 186k???(for sale, needs brake line)
99 HCE 63k Now at 97k and new GM reman engine, 132k
Add to 38TransAM's Reputation
Rate the quality of this post and help 38TransAM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
38TransAM is offline   Reply With Quote
Old 09-23-2015, 09:49 AM   #3
rollin_96
rollin_96 is on a distinguished road
1996 SL1
1994 SL2
I am experiencing the same problem and I'm pretty sure its the switch. I changed the wiper motor last week, cleaned out the drains and the problem persist. I'm going to order the multifunction wiper switch next. I'll let you know how it went. Probably next weekend.
Tweaked FSM http://www.mediafire.com/?ofliygqpep460un
Add to rollin_96's Reputation
Rate the quality of this post and help rollin_96 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rollin_96 is offline   Reply With Quote
Old 09-23-2015, 01:50 PM   #4
scw2
scw2's Avatar
1999 SC2
Ok ill check out the drains. i was thinking the switch might have an issue also, seems like if i hit a hard enough bump the wipers turn on
Old 09-23-2015, 02:01 PM   #5
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
That happens to me now and then in the winter for some reason.
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 09-23-2015, 09:29 PM   #6
1993
1993 is on a distinguished road
had that happen to a few saturns. It was the wiper motor assembly..
Add to 1993's Reputation
Rate the quality of this post and help 1993 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1993 is offline   Reply With Quote
Old 09-23-2015, 10:27 PM   #7
Bildo Baggins
Bildo Baggins is a jewel in the roughBildo Baggins is a jewel in the roughBildo Baggins is a jewel in the rough
Mine went through a stage of coming on in a left turn. Certain I was not hitting switch. Went away on its own. Really weird when it happened.
Bill from Extreme Southern North Carolina
'97 Satty SL2
280Kish miles
Add to Bildo Baggins's Reputation
Rate the quality of this post and help Bildo Baggins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bildo Baggins is offline   Reply With Quote
Old 10-10-2015, 07:00 PM   #8
rollin_96
1996 SL1
1994 SL2
Ok sorry it took so long, I had a heck of a time trying to find a 5.5mm nut driver locally, had to order it online. I swapped out the switch on my 96 this morning, so far its been working as intended. But only time will tell. My symptoms were it was on high at all times. No intermittent, No low, No mist, No off but the washer worked. I also had a problem with my 94 wipers some years back. On my 94 it was the motor they simply refused to park. They either parked mid-windshield or refused to park at all. The switch worked on all settings on the 94. The one thing i should have done first was check for resistants on the wires up at the motor before i replaced it
Old 10-10-2015, 07:33 PM   #9
Bildo Baggins
Thanks for resolution update. Need more of that here.
'97 Satty SL2
280Kish miles
Weird whistle noise. Brake light coming on randomly rgrafton S-Series Tech 6 10-31-2014 07:39 AM
Radiator fan comes on randomly Packrat1 S-Series Tech 8 12-08-2012 12:47 AM
Car randomly turns off Dave3 S-Series Tech 11 10-03-2012 05:28 AM
ABS coming on when coming to a stop on dry roads tbasse01 Vue Tech 16 03-08-2011 08:11 PM
04 Ion Randomly Stalls jazzman244 Ion Tech 3 06-24-2009 01:30 PM
