Old 11-05-2019, 09:56 AM   #1
pp270
pp270 is on a distinguished road
Default Power Steering Pump Location
I have a 2008 Saturn Aura 2.4L and am trying to find the location of the power steering pump. I understand its electric. Might someone post a picture?
Also on the alternator does the wire that plugs into it a separate wire harness or part of a larger one?
Add to pp270's Reputation
Rate the quality of this post and help pp270 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pp270 is offline   Reply With Quote
Old 11-05-2019, 02:19 PM   #2
Default Re: Power Steering Pump Location
This may help; http://www.saturnfans.com/forums/sho...d.php?t=196498 If you have electric power steering, the electric motor is part of the steering assembly under the steering wheel. It will be obvious when you look by the brake pedal. Honda may be the first with electric power steering in the S2000. The motor was mounted on the steering rack and pinion assembly. GM, I think, has electric power steering motors inside under the steering column.
Old 11-06-2019, 03:48 PM   #3
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
imaddicted2u's Avatar
2008 AURA XE
Here is a video, for a Malibu but it's pretty much the same.
https://www.youtube.com/watch?v=P6oqoLEdPYo
Old 11-06-2019, 11:08 PM   #4
pp270
Thanks for the video that helps. I noticed one of my wheel sensors wires was broken. Would that have any affect on the power steering causing it not to work?
Old 11-06-2019, 11:23 PM   #5
imaddicted2u
2008 AURA XE
For safety, I wouldn't think they would take away power steering for a broken wheel speed sensor but never know since a broken wheel speed sensor or wire will disable ABS, Traction control and Electronic stability control.
Old 11-07-2019, 12:13 AM   #6
imaddicted2u
2008 AURA XE
There was a special coverage for the EPS added. It was for 10 years or 150,000 miles.
https://ww7.oemdtc.com/4286/loss-of-...pontiac-saturn
Old 11-07-2019, 12:24 AM   #7
imaddicted2u
2008 AURA XE
6:55 in this Alternator change video shows the alternator plug wires go in to a larger harness.
https://www.youtube.com/watch?v=0vBFjrs0ras
2008 Saturn Vue XR 3.6L Power Steering Cooler location phaxmohdem 2008 Vue 2 11-06-2018 07:22 AM
Power steering pump small leak - slow death, or change pump now? Upstate Saturn S-Series Tech 19 11-20-2014 05:08 PM
Photo of new power steering pump leaking from hole in casting. Bad pump? tgferg67global S-Series Tech 1 11-10-2010 06:11 PM
power steering pump rinoa1@cfl.rr.c L-Series General 0 07-26-2010 06:47 PM
Need quick help - replacing power steering pump and water pump on V6Ö. Emanresu2 L-Series General 6 05-18-2006 05:38 PM
