Old 02-01-2008, 09:31 PM   #1
for my wife
for my wife is on a distinguished road
Default 1998 Saturn SL2 Manual Transmission Cable broke
As the name implies, this is for my wife and her beautiful Saturn SL2 manual transmission.
I believe the cable has broke, and need to get a new one, the other part of this is that I have been doing research on the internet about it, and have heard about a black clip that breaks...
I drove the car home in what i thought was 4th gear...the shift lever is basically free, so it doesn't change gears...
I am new to ordering Saturn parts and feel the 180 dollars the "genuine" saturn dealership wishes to charge me is rediculous. Like every other middle class american, i want to save money, and do the work myself.
Does anyone have any ideas?
thanks!
For my wife
Edit, after posting i realised there are a ton of postings about this issue....sorry for teh double post...new to the forums....
Last edited by for my wife; 02-01-2008 at 09:33 PM. Reason: found mutiple posts about the issue.
for my wife is offline   Reply With Quote
Old 02-01-2008, 10:56 PM   #2
rearviewmirror
rearviewmirror is on a distinguished road
rearviewmirror's Avatar
Default Re: 1998 Saturn SL2 Manual Transmission Cable broke
Look up the parts on here... http://saturnparts.net/
rearviewmirror is offline   Reply With Quote
Old 02-02-2008, 03:49 AM   #3
virnin
virnin is on a distinguished road
virnin's Avatar
thanks!
For my wife
Be sure to take off the center console and check that the bushing on the end of the cable didn't just break, allowing the cable end to slip off the pin on the shifter. As you may have read, it's the most common failure and is solvable by a number of inexpensive solutions. I'm leaning towards the Delrin replacements because I've seen how much tougher Delrin is compared to nylon. The console is held in by only four screws, one on either side at the very front and two under the storage tray or armrest in the back, so it's not very traumatic to lift it up out of the way. Be careful of the wiring for the lighter and the lamp for the cupholder.
virnin is offline   Reply With Quote
Old 02-02-2008, 05:48 AM   #4
WingsOfSaturn
WingsOfSaturn's Avatar
Welcome to the forum.
Common issue. Search on "shift linkage bushing" for a multitude of posts. Fix ranges from the $10 Toyota wiper bushing to the $200 Saturn cable replacement. My Toyota wiper bushing has been operating well for a year and a half now. And you get 5 of them for $10. I have 4 spares that I have never used.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 02-02-2008, 09:40 AM   #5
Motorhead62
Motorhead62 is on a distinguished road
Motorhead62's Avatar
2008 AURA XE
2001 L-Series 2.2L Sedan
Wrench Re: 1998 Saturn SL2 Manual Transmission Cable broke
Trust me on this, buy the genuine Saturn cable and pay the higher cost. The shifter cables come in a set and are joined at the firewall grommet. When you get the cables you will see why it costs so much.
The cheap cables are junk!!! I changed the cables on my SL and the shifter works better now then when it was new. I don't recommend putting a band aid on it. Just my 2 cents.
Chris
AKA "Motorhead62"
2008 Aura XE EcoTech 2.4
2001 L200 EcoTech 2.2
1993 SL1 1.9L
1967 Chevelle "496" BBC
1967 El Camino "388" SBC
1967 C-10 "463" BBC
www.C-DPerformance.com
Motorhead62 is offline   Reply With Quote
Old 02-02-2008, 12:04 PM   #6
WingsOfSaturn
+1 on the aftermarket cables. If you have to change the cables get them from Saturn. The aftermarket ones are made in China or someplace and are prone to breaking.
But if just the bushing is broken replace it. Bushing is not available at Saturn. They have to sell you the whole cable assembly.
Also check the cable linkage at the tranny end. Sometimes the retaining clip will fall off.
95 SL2 MT 220K+
Manual Transmission Shifter Cable modification from stock brandj1 Vue Mods 4 03-06-2011 10:33 AM
1998 Saturn SL2 Transmission problem jpoell01 S-Series Tech 7 09-04-2009 01:56 PM
Will a 1997 saturn sc1 manual transmission work in my 1998 manual sl2? CARLiTO_ S-Series Tech 1 08-19-2008 08:52 PM
S-Series Shift Cable Solution (Manual Transmission) cazzylee S-Series Tech 15 06-23-2007 04:33 PM
1998 Saturn SL1 5 speeds - Shift cable bushing broke PKTLEUNG L-Series General 2 06-08-2007 06:47 AM
