#1 |
![]() Join Date: Jul 2005
I have a 2002 Saturn SL 1, 1.9 SOHC. The intake manifold gasket is leaking. Can anyone tell me what a garage would charge to replace? Also, if someone has done this themselves, how difficult and time consuming is it? Thanks
#2 |
![]() Join Date: Jan 2004
2004 ION-2 Quad Coupe
Kinda difficult. You have to remove the fuel rail stuff like that around it. Garages can do it but its around 3 hours and $250 - $600. There is a broad range in cost due to labor per hour charge and some saturn dealerships may charge the reduced cost because its a common thing. They know shortcut ways.
Edward |
#3 |
![]() Join Date: Sep 2005
1993 SL2
4.5 hrs. labor plus approx. $35 parts (about $400 at the dealer)
They can be kinda a pain to do put not too bad. The intake does not need to be completly removed inorder to repalce that gasket. Take loose the upper motor and tranny mount and rock the engine forward and up. They can be done in an hour but give yourself a day if you try it yourself. |
#4 |
![]() Join Date: Aug 2005
2002 L-Series 3.0L Sedan
1994 SC2
Looked in my Haynes manual, and the job doesn't look too bad. Drain coolant, relieve fuel pressure (easy), disconnect a lot of hoses and wires, unbolt the power steering pump and put it aside, remove fuel rail. Then off with the manifold.
To get at the brace under the manifold, you raise the car and remove right wheel and splash guard. Haynes advises this late in the game, but I would do this first, for draining the coolant and because I like working with the car up high so I don't have to bend over so much. Tool-wise, you'll need a set of metric sockets, screwdrivers, and pliers. There's only one torque spec (for the manifold, 114 in. lbs.). There are no complicated settings for anything as you re-assemble. For the small hoses and wires, you could label with masking tape and a small marker. Numbering each side of the connections as you undo them is a good method. Allow lots of time, like a weekend, in case you have to run out for tools, or if nuts are sticky and you want to let them sit with penetrant on them (PB Blaster is great). I think I could do this in 2-3 hours, and I am not a great mechanic. I would say that level of difficulty is about the same as a doing disc brakes with rotors. Buy a manual. Using a digital camera might be nice if you have one, but is not essential. If the job is $300 at a shop, with the savings you can add to your tool collection and have a couple hundred to spare ![]() P.S. According to Haynes, undoing the transaxle mount is not necessary for SOHC motors. |
#5 |
1993 SL2
Not necessary but I personaly find it easier to work on if it is removed because you gain a couple of inches to get your arm in there and clean the head and intake. And it is only one 13mm. My opnion only done 20-30 of them though.
#6 | |
1994 SC2
![]() Quote:
#7 | |
![]() Join Date: Jan 2001
![]() Quote:
Totally unnecessary...all of the engine harness connectors are unique...they will only plug into the sensor they were designed to fit into. When you lay the harness back out, the connectors will damn near fall into place where they should be. Take your time and you won't have any trouble. |
#8 | |
![]() Quote:
Bookmarks |
00-02 SOHC Intake Manifold Gasket Replacement How-to | rc1488 | S-Series Tech | 111 | 06-29-2020 11:58 PM |
99 SOHC Intake Manifold Gasket Replacement | Floggingamy | S-Series Tech | 0 | 05-21-2008 02:52 AM |
Intake manifold gasket replacement? | SaturnManiac | S-Series Tech | 9 | 03-15-2008 06:59 PM |
The Joy of Intake Manifold Gasket Replacement | MiSaturn | S-Series Tech | 0 | 01-27-2008 11:20 AM |
2001 Intake Manifold Gasket Replacement | between5and7 | S-Series Tech | 0 | 11-10-2006 04:38 PM |
