Old 05-30-2015, 12:07 AM   #1
whitesc1
whitesc1 is on a distinguished road
1998 SC1
Dizzy Aftermarket Stereo Problem
Just got a Pioneer stereo for my 1998 Saturn SC1. I wired everything up right and was testing it out, everything looked good, I turned the headlights on and the interior lights flickered, and the stereo shut off. My first thought was I blown a fuse. Could that be what it is? Because I remembered once I took out the fuse for the door chime, then the stock stereo didn't work. The door chime works and the aftermarket stereo doesn't. Somebody help me out cause i'm confused and it's pissing me off .
Add to whitesc1's Reputation
Rate the quality of this post and help whitesc1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
whitesc1 is offline   Reply With Quote
Old 05-30-2015, 12:48 AM   #2
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
Default Re: Aftermarket Stereo Problem
Sure sounds like a blown fuse to me. The first one to check is the actual radio fuse. It should be a 10A fuse located behind the kick panel/cover that is on the lower left-hand side of the front passenger area.
And as for the chime fuse, I believe that fuse is indeed necessary for the radio to function. But you state your chime still works so that fuse should be okay.
There is another fuse associated with the radio in the UHJB. It should be a 30A fuse named IGN4. But I think if that one was blown, nothing would happen when you turned the key in any position.
Let us know what you find.
Add to bachands's Reputation
Rate the quality of this post and help bachands reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bachands is offline   Reply With Quote
Old 05-30-2015, 07:11 AM   #3
saturnman99
saturnman99 is on a distinguished road
It sounds like to me the battery is almost dead OR the alternator is bad.If it was a blown fuse the stereo wouldn't come on at all.What the aftermarket stereos do is if there is a big voltage drop they will shut off same goes for to much voltage. Hope this helps.
Add to saturnman99's Reputation
Rate the quality of this post and help saturnman99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnman99 is offline   Reply With Quote
Old 05-30-2015, 03:21 PM   #4
whitesc1
1998 SC1
I'll swing by the junk yard real quick and get a fuse and if it's not it then I'll get another 10a fuse for the stereo. I'll let you know how it goes.
Old 05-30-2015, 03:24 PM   #5
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Sounds to me like you need to double check your radio wiring connections. Your dimmer or illumination wire is connected to something it shouldn't be.
2007 Ion 2 Quad Coupe 5-speed manual 179K miles
2007 Chevy Equinox LT 190K miles
Add to ruley73's Reputation
ruley73 is online now   Reply With Quote
Old 05-30-2015, 03:50 PM   #6
whitesc1
1998 SC1
Yeah, most likely gonna be a wiring problem, cause the door chime works and just like bachands said, if the IGN 4 fuse was blown, nothing would happen, everything still works but the stereo, so i'm gonna double check my wiring. I'll let y'all know.
Old 05-30-2015, 08:27 PM   #7
Tiger
Tiger's Avatar
When wiring your stereo I hope you are not having the power go through Pin F5. Here is what can happen and how to fix it:
http://www.saturnfans.com/forums/sho...d.php?t=173989
I happen to have a good fuse panel for a 98/99 with power lock fuse deleted and a pristine Pin F5. I had to get one with a fuse for power locks.
Part of wiring a new stereo means some way to power it so the power does not go through Pin F5 or you run the risk of being towed.
Add to Tiger's Reputation
I need stereo wire diagram for 04 Ion level 1 need advice on aftermarket stereo ddemier7 Ion General 3 10-20-2014 12:25 AM
06 Saturn Vue aftermarket stereo problem illinoisboy82 Vue Tech 0 07-20-2013 01:55 AM
Aftermarket Stereo Problem lpchick316 Ion Mods 7 10-24-2008 09:09 PM
94 SC aftermarket stereo roblun S-Series General 3 04-10-2007 10:49 PM
Problem installing aftermarket stereo Proxima S-Series General 12 07-15-2004 12:02 AM
