Old 03-09-2014, 08:04 PM   #1
I awesome
I awesome is on a distinguished road
Default Problem with car, need help! :(
Hello everyone! This is my first post, though I've been lurking as an unregistered user for a long while and finally got the guts to ask for help, lol.
So my 99 Saturn sl1 started to use coolant and oil really fast and the temp goes over half way mark if we stay idled for to long.
It has about 207k miles on it, but the engine and trans was swapped with a 2002 model that had 137k on it about 10k miles ago
It also makes a weird noise when I accelerate sometimes. It sounds like pouring water from one bottle to another. Oh yeah, there is some oil that looks like it's leaking out of the two left and right caps of the top of the engine.
Do you guys got any idea what could be wrong?
Add to I awesome's Reputation
Rate the quality of this post and help I awesome reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
I awesome is offline   Reply With Quote
Old 03-09-2014, 08:54 PM   #2
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
Default Re: Problem with car, need help! :(
What does the coolant look like?
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 03-09-2014, 09:09 PM   #3
eb121209
eb121209 has a spectacular aura abouteb121209 has a spectacular aura about
eb121209's Avatar
Clogged heater core.
Add to eb121209's Reputation
Rate the quality of this post and help eb121209 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eb121209 is offline   Reply With Quote
Old 03-09-2014, 11:01 PM   #4
Signmaster
As for leaks, the only way to find out is to clean things up and get them dry, and find out where it leaks. It's way easier than guessing, and points you to any problem spots. As for the caps on the top of the engine... a little more information would be helpful. I suspect that you might be talking about the bolts for the cam cover, but I'm not sure.
The cars are also known for burning oil, so check it frequently. There is a good chance that much of what you are losing is going through the engine. Externally, it really doesn't take much oil at all to make a mess. Even a minor leak over time will make the engine look bad.
As for the cooling, it's normal for the temp to rise when not moving or moving very slowly for extended periods of time. Until the fan kicks on, the only cooling is the movement of the car. The fan won't turn on until you are past the 1/2 way mark, and in some cars not until almost at the 3/4 mark. If your car has AC you can trigger the fan by turning on the AC as well, but it only works above ambient temps in the 40+ range.
Old 03-10-2014, 02:05 AM   #5
eb121209
eb121209's Avatar
I prefer doing this, even though my car has NEVER overheated. I'm just anal about my temp gauge getting too high. I usually will turn on my AC if I know I'll be idling for a while.
Old 03-10-2014, 02:10 AM   #6
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
You can even install a manual fan switch using nothing more than a couple pieces of wire and a switch. The wires run from the fan relay to the switch, then to a ground. Costs less than $10, and is completely harmless to the car and is completely reversible. I did it to my car in under 10 minutes in an AutoZone parking lot.
It isn't necessary, but it's an option.
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Clearfield":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
1993 White SW2 5spd "Steve": 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Old 03-10-2014, 03:29 AM   #7
eb121209
eb121209's Avatar
Was thinking about doing that "but then I got high". Jk
Actually, I got lazy.
Old 03-10-2014, 09:56 AM   #8
I awesome
Thanks for the replies!
A green color.
The heater works fine though. Do you know how I would go about getting this fixed?
I cleaned it up and after driving it for a few hours, the top part where the bolts are got a lot of oil stained down it.
It also looks like someone tried to seal it with red stuff, but most of it is gone.
I never knew they burn oil , lol. Though I still feel like I'm going through coolant way to fast.
Old 03-10-2014, 10:39 AM   #9
TXSaturn02
TXSaturn02's Avatar
I rarely ever see this (temp gauge go above 1/2) happen. Maybe because I'm rarely in stop and go traffic and because it is often warm enough to need to run the AC. Another reason to run the AC is that it keeps the parts lubricated which helps keep a healthy AC unit. My original AC has never been serviced and still blows very cold.
New owner As of 01/01/18: 225,000 Miles
As of 06/15/18: 49,365 Miles
Old 03-10-2014, 10:41 AM   #10
TXSaturn02
TXSaturn02's Avatar
ALL older cars burn oil, from wear. Get in the habit of checking to see how much yours does. Mine doesn't burn much, but I baby my car.
The coolant? Yeah, you shouldn't be losing much, if any - you have a leak.
Old 03-10-2014, 11:03 AM   #11
Signmaster
A green color.
Can you tell us where the oil leak is based on this photo?
As for the coolant leak the most common areas are the radiator end tank (in the area under the top hose on the drivers side), the water pump (the most forward bottom pulley you can see on the passenger side), or the coolant reservoir where you add coolant. It's also possible for the heater core to fail and this will often smell inside the car, as well as leave wet spots in the carpet in the center console forward area.
Chances are if you can find the leaks someone hear can tell you how to fix them. Some are really easy, some are a bit harder, but none of the common problems are really hard jobs. There are often videos or "how to" write ups with photos to help you along.
If you top off the coolant and let it come up to temperature while looking for leaks chances are you can find the leak while the engine compartment is still fairly clean.
Old 03-10-2014, 11:06 AM   #12
Sounds like you need to replace the valve cover gasket, that will help with some of the oil loss.
http://shop.advanceautoparts.com/p/f...1-r/10030279-P
Take off the coolant reservoir cap & start the engine. Excessive bubbling (in the reservoir) indicates a head gasket or head crack problem, if it looks like it's just moving/flowing then it's fine. Check for the typical radiator crack & leaking water pump while you're under the hood. If it's the water pump there is generally water marks on the hood liner above the serpentine belt area as well as water being flung at you if you stand in front.
This appears to show (going by the name, haven't watched it) where the radiator typically leaks: https://www.youtube.com/watch?v=SlqekpKOXJQ
It's on the driver side, below the hose to the head and above the automatic trans fluid port (stock manual trans radiator won't have the port but cracks in the same spot).
Problem: Weird no-start-shift lock problem vstringbassist Ion Tech 8 12-09-2012 12:55 AM
Acceleration problem...gets stuck...possibly transmission? Or a gas problem? Dingo Warrior S-Series General 34 03-29-2009 12:20 PM
Irratic temp guage problem & CC problem 98dingo S-Series Tech 14 07-19-2007 10:43 AM
i found out want was the lack of power problem and shifting problem gypsy35 S-Series General 4 01-06-2006 07:49 AM
RADIO problem? and door lock problem please help 95sl2urbo S-Series Tech 15 01-11-2004 08:25 PM
