Old 01-19-2012, 11:08 PM   #1
MikeHarrison
MikeHarrison has a spectacular aura aboutMikeHarrison has a spectacular aura about
2007 ION-2 Sedan
Default Crunching sound from front suspension in cold weather
When the outside temperature is near freezing or below, going over a dip in the road, or anything that causes the front end to drop, will cause a momentary crunching sound. To some, it might sound as though the tires are hitting the inside of the wheel wells, but after driving several miles, the crunching noise goes away, as though something has 'warmed up.'
This is a 2007 Ion 2 4-door with 30,000 miles. Never been in an accident.
Any ideas?
Add to MikeHarrison's Reputation
Rate the quality of this post and help MikeHarrison reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MikeHarrison is offline   Reply With Quote
Old 01-19-2012, 11:24 PM   #2
Default Re: Crunching sound from front suspension in cold weather
Front sway bar to frame bushings are the most likely cause of the noise. Common winter problem in the IONs.
Add to ssicarman's Reputation
Old 01-19-2012, 11:28 PM   #3
MikeHarrison
2007 ION-2 Sedan
Is there any damage being done? Should I have them looked at?
Old 01-19-2012, 11:53 PM   #4
Tethys
Tethys is on a distinguished road
Tethys's Avatar
It couldn't hurt to have them checked. My current Ion makes this sound when it's cold out and my '04 did it, too. The only difference I've noticed is my '06 doesn't go through bushings as often as my '04 did.
2015 Buick Verano Turbo
5 - 2006 Ion 3 Sedan, Manual, Storm Grey
4 - 2004 Ion 2 Sedan, Manual, Electric Blue
3 - 1996 SL2 Manual, Medium Red
2 - 1991 SL1 Manual, White
1 - 1991 SL Manual, Grey
Add to Tethys's Reputation
Rate the quality of this post and help Tethys reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tethys is offline   Reply With Quote
Old 01-20-2012, 11:08 AM   #5
MikeHarrison
2007 ION-2 Sedan
I'll have the bushings inspected.
Thanks! Much appreciated.
Old 01-20-2012, 07:58 PM   #6
Zosozeppelin
Zosozeppelin is on a distinguished road
Zosozeppelin's Avatar
2006 ION-3 Quad Coupe
How often have you changed yours? I bought mine used at the dealership at 53k and they replaced them when I test drove it. I'm at 85k now.
Elizabeth
'06 Level 3 Quad Coupe. 140K as of 5-3-15. Traded for 2015 Chevy SS. Gone but not forgotten.
Current: 2017 2LT/RS 50th Anniversary Camaro
Add to Zosozeppelin's Reputation
Rate the quality of this post and help Zosozeppelin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zosozeppelin is offline   Reply With Quote
Old 01-20-2012, 08:07 PM   #7
MikeHarrison
2007 ION-2 Sedan
Haven't changed mine at all. Bought the car new in Dec 2006; it has just over 30,000 miles on it.
Old 01-20-2012, 08:52 PM   #8
Tethys
Tethys's Avatar
Zoso, my current Ion went ~80K on its original front bushings. I had them changed out in late October. I bought the '06 new with just 6 miles on its odometer. The '04 Ion, also bought new, went through at least two sets and I only had that car for approximately 35K before trading it in on this one.
Old 01-20-2012, 09:02 PM   #9
MikeHarrison
2007 ION-2 Sedan
Does this mean that GM recognized a bushing problem in the earlier models and have improved on them, or did you drive your newer Ion in 'less stressful' conditions?
Old 01-20-2012, 09:28 PM   #10
Zosozeppelin
Thanks! Mine haven't acted up since they were replaced 30k ago, but I'm figuring it in as regular maintenance since they're so problematic.
Elizabeth
Old 01-20-2012, 10:03 PM   #11
Zosozeppelin
I doubt they ever changed the design. Those GM engineers are lazyyyy. Kidding, but I would assume they didn't since we hear about them being worn across all model years so often.
Elizabeth
Old 01-20-2012, 10:28 PM   #12
Won't damage anything. Just really irritating.
Old 01-20-2012, 11:46 PM   #13
2006 ion2
2007 ION-2 Sedan
I've had mine changed once already, and my car has 39000 miles on it already. there really isn't much room for improvement on the current design for the sway bar or control arm bushings. the design is fundamentally flawed in the case of the control arms, and the rubber is at fault with the sway bar bushings.
poly bushings are ideal for the sway bar, and should last a lot longer, and poly bushings will be better on the lower control arm, but there's no fixing the design.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 01-21-2012, 12:17 AM   #14
Zosozeppelin
You only have 39k on your car? You either live in the city or you never drive!
Elizabeth
Old 01-21-2012, 09:30 AM   #15
2006 ion2
2007 ION-2 Sedan
I wouldn't call it a "city", but it's been driven almost every day since I bought it 5 years ago, including many 700+ mile (one way) trips and more 50-100 mile trips than I can remember. I plan my trips to be as efficient as possible, consolidate runs, ect... But I also periodically just go for a drive on a country road and drop the hammer between the increased power and the sway bar in the back, this thing loves the twisties, and I love to drive it, I just try to be smart and not pay a ton for fuel.
2007 Saturn Ion 2
Old 01-21-2012, 04:08 PM   #16
Zosozeppelin
That's a good idea. I consolidate my trips, but for me to go ANYWHERE I have to drive at least 13 miles. It doesn't help that I'm commuting this semester to school. I was supposed to be carpooling but the person I'm doing it with skips too much
Elizabeth
Cold weather = Very loud suspension rastriffler Sky Red Line 7 01-05-2011 10:24 PM
Dragging sound in cold weather mrbeankc Ion General 4 01-29-2009 12:24 PM
Cold weather suspension really creaks and groans Blue Goose Vue General 4 03-24-2005 02:04 PM
Crunching sound from front end rumbob Vue General 3 10-10-2004 11:00 AM
Cold Weather ....Ticking Sound hugh L-Series Tech 4 01-13-2002 10:48 AM
