Old 01-21-2006, 12:10 PM   #1
Jy's97sc2
Jy's97sc2 is on a distinguished road
Jy's97sc2's Avatar
Dazed Transmission Drain Plug?
I'm tring to change my tranmission filter for my 97 SC2, can someone tell me where the drain plug is and how to change it???????
Jy's97sc2 is offline   Reply With Quote
Old 01-21-2006, 12:29 PM   #2
racerdain
racerdain is on a distinguished road
racerdain's Avatar
1993 SL2
Default Re: Transmission Drain Plug?
Should be on the backside of the transmission right by where the convertor housing bolts up to the main half of the transmission.
Mike Moore
Saturn of Tiffany Springs
Parts Manager
racerdain is offline   Reply With Quote
Old 01-21-2006, 02:02 PM   #3
Saturn-Eh!
Saturn-Eh!'s Avatar
When you get under the car, it will be vary easy to spot. It's on the passenger side bottom of the differential housing (the part of the transmisison where the axle shafts go in). 15mm wrench.
Saturn-Eh! is offline   Reply With Quote
Old 01-21-2006, 02:51 PM   #4
Luke
Luke's Avatar
And on my '95SL2, it's on the driver's side,(((>just below and back, where the transmission filter sits, and is facing towards the passenger side<))).
As you don't have a fumoto valve setup, you'll have to lift the right front of the car, to get under.
Remember, you'll have a considerable initial flow when the bolt is removed. I'd suggest that you just loosen the plug,
and let it drain out, with the plug not removed. It's be slow, but you'll not end up with fluid all over the place.
Luke is offline   Reply With Quote
Old 01-21-2006, 05:29 PM   #5
Razorbak
Razorbak's Avatar
It should look something like the pic below (although this is from a manual transaxle, not an auto)...
Razorbak is offline   Reply With Quote
Old 01-21-2006, 07:38 PM   #6
peppermrj
peppermrj is on a distinguished road
peppermrj's Avatar
http://www1.autozone.com/servlet/UiB...3d8019973e.jsp
peppermrj is offline   Reply With Quote
Old 01-21-2006, 09:33 PM   #7
wolfman
wolfman's Avatar
You mean like the detailed DIRECTIONS in the HOW TO LIBRARY??????
Old 01-21-2006, 09:34 PM   #8
wolfman
wolfman's Avatar
Old 01-22-2006, 12:11 AM   #9
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
http://www.saturnfans.com/forums/showthread.php?t=65426
http://www.saturnfans.com/forums/showthread.php?t=44842
jambra1 is offline   Reply With Quote
Old 01-22-2006, 01:03 PM   #10
peppermrj
peppermrj's Avatar
The instructions in the "How to" library are much more specific.
The instructions at the Autozone link have handy reference photos.
Old 01-23-2006, 07:15 AM   #11
bobbyrae
bobbyrae has a spectacular aura aboutbobbyrae has a spectacular aura about
1993 SL2
If you are only changing the filter, you really don't care about the drain plug, and even if you did, you don't need to CHANGE it. Maybe I am taking you too literally.
Bobby Rae
Alameda, CA
1993 SL2 A/T, 80k miles, 22/33/43 mpg
1982 Accord 5-speed, 303k miles, 23/32/40 mpg
bobbyrae is offline   Reply With Quote
Old 01-23-2006, 07:34 AM   #12
BarnOwl
BarnOwl's Avatar
Ummm the tranny fluid should be changed every 30,000 miles.
Where are the Transmission filter and drain plug located ? browntown3 S-Series Tech 2 11-11-2008 04:27 PM
Transmission drain plug outlet stripping out Saturn_ol'timer S-Series Tech 7 07-04-2008 12:31 AM
Transmission Drain Plug Torque SuzyQ S-Series Tech 3 02-09-2008 02:39 AM
Where is the transmission drain plug? meredith S-Series Tech 8 08-30-2006 02:05 AM
Transmission drain plug crack humannuman S-Series Tech 11 02-25-2003 12:16 PM
