Old 03-17-2009, 10:43 AM   #1
CT Aura XR
CT Aura XR is on a distinguished road
2007 AURA XR
Default XR Transmission Fluid Change-Drain Plug Location
Hi,
I'm looking to drain and change the fluid on the 6T70 but I can't seem to locate what looks like an obvious drain plug. Does anyone have a picture or can they provide a verbal description of which bolt the drain plug is?
I've used these pictures and gotten under the car to no avail:
See images 27779 and 27781 at this website - since I can't link to it.
CT Aura XR is offline   Reply With Quote
Old 03-17-2009, 12:05 PM   #2
CT Aura XR
2007 AURA XR
Post Re: XR Transmission Fluid Change-Drain Plug Location
Complete picture paths are here(use the Saturn Fans url as a prefix):
/photos/showphoto.php/photo/27779
/photos/showphoto.php/photo/27781
Old 03-17-2009, 12:28 PM   #3
Phaeton Driver
Phaeton Driver will become famous soon enough
2007 AURA XR
Default Re: XR Transmission Fluid Change-Drain Plug Location
Originally Posted by CT Aura XR View Post
Hi,
Automatic transmissions seldom have drain plugs. The usual method to drain them is to remove the bottom access panel and filter. There may be up to 15 screws holding the plat in place. You need a new gasket and filter to put is back together (filter may be a clean and reuse type) when necessary.
Best to take it to a transmission shop or oil changer because it makes a big mess if you don't have the right equipment to catch the fluids.
I have no direct experience with these Aura transmissions but I would be surprised if they have a drain plug.
Phaeton Driver is offline   Reply With Quote
Old 03-17-2009, 04:57 PM   #4
CT Aura XR
2007 AURA XR
The 6 speed with the 3.6L is "all new" and doesn't have a pan to drop or a removable filter. Dealer confirmed it's just a drain and refill. The 3.5L transmission is different, more as you described.
Old 03-17-2009, 09:25 PM   #5
Kooler King
Kooler King is on a distinguished road
Kooler King's Avatar
2008 AURA XE
GM stopped using drain plugs on automatic transmissions back in the early '70s.
Kooler King is offline   Reply With Quote
Old 07-12-2009, 08:04 AM   #6
CT Aura XR
2007 AURA XR
Happy Drain Plug Location and Drain and Refill Info for 6 Speed Transmission
The dealer pointed out the plug location to me. It is about 4" from the front of the transmission and about 1" from the outer (driver's side) edge. Easily accessible without jacking the car up. It takes an 11mm socket. It came off easily, not much torque required.
A little over 5 quarts of fluid drained out so I would suggest having 6 quarts on hand before starting the procedure.
My car had about 55,000 miles on it when changed and the fluid definitely improved the shifting characteristics. The shifts in full auto mode are much smoother and the manual downshifts have also improved(not as jerky on engagement).
I recommend this as an easy and inexpensive way to keep the car feeling "like-new". The total cost was about $25 using Wal-Mart's Super Tech Dexron 6 fluid. The dealer estimate was around $125 for this service!
location of transmission fluid drain plug on 03 ION ASIN? sgb Ion Tech 2 10-18-2008 04:57 PM
Location of oil drain plug on 2004 Ion 2 Rocky0529 Ion Tech 6 10-27-2007 11:50 AM
Manual Transmission fluid change - plug issue AJT_Leo S-Series Tech 4 08-25-2007 03:02 PM
Transmission Drain Plug? Jy's97sc2 S-Series Tech 11 01-23-2006 07:34 AM
Transaxle drain plug location pjpcvp S-Series Tech 3 01-10-2005 01:04 AM
