Old 03-23-2003, 05:35 PM   #1
jgr00
jgr00 is on a distinguished road
2008 VUE 2.4L
1999 SL1
Mad BIG problems with Adv Sound System
I am having big problems with my 6 CD Adv. Audio system in my LW300. The dealer has replaced the system twice and it just went out again after only working a few days. The symptoms of the problem is at first (when it starting to go bad) you hit a bump and there will be a crackling sound in the right rear speaker (the problem is not the speaker) and after a while there you will eventually get a load crackling sound/pop and then the system stops putting out ANY sound at all (no matter how much you turn it up). If you push on the face plate (it takes varying amounts of force) of the unit just under where you insert the CD's you will get the crackle again and the sound comes on. Some times it will stay on for a few seconds to a few minutes but eventually goes out again. ALL THREE units (the original and the two replacements) have done exactly the same thing. The first replacement lasted all of about 10 minutes after I left the dealer, and the last one lasted a few days. I really am upset, the dealer has called Saturn and they are telling him to just replace the unit. This hasn't worked obviously. Has ANYONE else had any problems with their Adv. Audio units. BTW after the dealer replaced the last one we noticed (after we left the dealership) that the DVD unit was completely DEAD...can not eject or load any DVD's and when you hit the button to turn on the DVD the radio does not switch to AUX so it looks like the DVD is not powering on at ALL. Can anyone help me?????
Add to jgr00's Reputation
Rate the quality of this post and help jgr00 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jgr00 is offline
Old 03-23-2003, 05:47 PM   #2
Dj_Xao
Dj_Xao is on a distinguished road
Default
u might have a lose connection some where
Add to Dj_Xao's Reputation
Rate the quality of this post and help Dj_Xao reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dj_Xao is offline
Old 03-23-2003, 05:56 PM   #3
jgr00
2008 VUE 2.4L
1999 SL1
Default
You'd think that since the dealer has been in there at least twice that the loose connection would have been fixed by now. They have replaced the entire head twice already......AND if it was a loose connection why pushing on the face place of the radio does it start working again...and pushing on it did this on all three units.
jgr00 is offline
Old 03-23-2003, 08:13 PM   #4
Dj_Xao
Default
i'm talking about ur wiring harnest
Dj_Xao is offline
Old 03-24-2003, 08:31 AM   #5
2003LW300
2003LW300 is on a distinguished road
Default Re: BIG problems with Adv Sound System
Originally posted by jgr00
BTW after the dealer replaced the last one we noticed (after we left the dealership) that the DVD unit was completely DEAD...can not eject or load any DVD's and when you hit the button to turn on the DVD the radio does not switch to AUX so it looks like the DVD is not powering on at ALL. Can anyone help me????? [/B]
I had my radio replaced due to a different issue. However, The DVD issue was the same when they replaced the unit. Replacing the head unit causes a spike that locks the DVD software. I have a copy of the service release that resets the software. I will post it tomorrow.
Add to 2003LW300's Reputation
Rate the quality of this post and help 2003LW300 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2003LW300 is offline
Old 03-24-2003, 10:17 AM   #6
jgr00
2008 VUE 2.4L
1999 SL1
Default
If it is the wiring harness why would pressing on the face plate make it work and when you release it, it again goes out?
jgr00 is offline
Old 03-25-2003, 12:46 AM   #7
malbojah
malbojah is on a distinguished road
Default
Almost sounds like a lose ground wire. But that should only blow out a fuse
Add to malbojah's Reputation
Rate the quality of this post and help malbojah reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
malbojah is offline
Old 03-25-2003, 05:35 PM   #8
silverplum
silverplum is on a distinguished road
Default
Talk about fixing the sympton and not the cause. It certainly sounds like a wiring problem.
Add to silverplum's Reputation
Rate the quality of this post and help silverplum reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverplum is offline
Old 03-26-2003, 03:17 PM   #9
1993SC2
1993SC2 is on a distinguished road
1993SC2's Avatar
1993 SC2
Default
maybe it's some sort if internal problem; if they use the same deck/head in the VUE, and that has problems (does it?), then it's probably something within the radio. Otherwise, it 's prolly the car.
Then: 1993SC2m
Now: 1996 Jeep XJ, 2007 Kawasaki Ninja 650
Add to 1993SC2's Reputation
Rate the quality of this post and help 1993SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1993SC2 is offline
Old 04-01-2003, 10:48 PM   #10
jgr00
2008 VUE 2.4L
1999 SL1
Default
Got the car back from the dealer yesterday. After contacting Saturn through their website and having them talk with the Dealer service manager. They gave me free loaner and took the car to go over. After showing the dealer my latest find with the radio, it would work pushing in on the right hand side of the entire dash trim ring (the one that goes all the way around the radio, middle dash vents and the heater/AC controls). The dealer found that the right front speaker wire went over a metal dash support and it had a sharp edge and had worn a VERY small hole in the wire insulation and it would ground the speakers out and when you pushed on the radio/dash ring it would cause the wire to me just enough for it to not ground out. They fixed the wire and put a protector in where the wire went over the support. The really funny thing is that the Service manage said that he has a 2000 L and that it is doing exactly the same thing. He said that he will have to tear into his car because he thought the radio was bad. Thanks to everyone for their input... Problem solved. I'm glad that I complained to Saturn themselves, I think it did a lot to get the attention of the dealer and the factory guys to try to fix the problem instead of just throwing parts at it.
jgr00 is offline
Old 04-02-2003, 12:19 AM   #11
silverplum
Default
This really goes to show you how important input from the customer is when it comes to solving a difficult problem.
HELP! Replacing Adv. Audio System radio in 2003 247jamz Vue General 0 12-30-2006 11:18 PM
New sound system (adding a amp and sub to a factory system) QuadKewl Ion General 9 10-29-2004 03:03 AM
big problems dru95sc2 S-Series Tech 4 07-01-2003 06:21 PM
96' SL2 Sound system STORY and new system ideaR jace3971 S-Series General 3 08-06-2002 06:44 PM
Big THUD sound jwdobbs Miscellaneous Tech 1 04-11-2002 05:16 PM
