Old 09-30-2018, 09:58 PM   #1
Rochester
Rochester is a name known to allRochester is a name known to allRochester is a name known to allRochester is a name known to allRochester is a name known to allRochester is a name known to all
Default Replaced Clutch Cylinders
I've noticed recently that I had to push the clutch in harder and harder in order to get it to work, as in not more force, but more distance - at least until this week when I found myself practically standing on the clutch to get that last little quarter-inch needed to be able to shift gears smoothly. The clutch fluid was low and topping it up did not help. The cylinders must have been bad or leaking somewhere. Time to replace them!
I did that today. The book said the two cylinders had to be replaced as a single unit. Getting the old ones out was easier than I thought it would be - the hardest part was removing the clip on the top of the pedal, the one that holds the end of the bar that comes out of the master cylinder. I had to lie with my back on the door sill and my butt on a folding chair outside the car in order to both see and reach the clip at the same time!
Getting the new one in was a bit harder, as threading it between all the cables and hoses under there and especially getting it around the brake cylinders was difficult, and I didn't dare be rough with it lest I kink or break the hoses on the new cylinder set that I paid almost a hundred bucks for! But I got it in, and got the clip back on, and in a few minutes I'm going to go drive it (if I did everything right and it works!)
I wonder if this might also fix another problem I've been having, when the clutch "sticks" in the down position, usually when I start using it after a long continuous drive, as when I leave an expressway and resume stop and go driving. The problem seemed worse on hot days. If the clutch did get stuck, a short, sharp kick straight down would free it, sometimes after two or three tries, and the problem happened more often on hot days. Only allowing the car to cool off for a couple hours would cure it completely when it happened.
Does anyone else have the latter problem? If so, did it turn out to be the cylinders?
Add to Rochester's Reputation
Rate the quality of this post and help Rochester reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rochester is offline   Reply With Quote
Old 09-30-2018, 10:16 PM   #2
Waiex191
Waiex191's Avatar
Default Re: Replaced Clutch Cylinders
The only issue I've had is the cylinder goes too far to the floor to disengage. Also, you can buy the hydraulics for like $30.
http://www.saturnfans.com/forums/sho...d.php?t=233551
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-02-2018, 06:30 PM   #3
hholbein
1997 SW2
Did your sticking problem after a heat soak/long drive on an 80F+ degree day also include a squeaking sound???
Anyway, glad to hear the swap out went fairly smoothly. I agree, working on the clutch pedal is no fun ergonomically!
Add to hholbein's Reputation
Old 10-03-2018, 12:08 AM   #4
Rochester
It did! Usually the squeaking started before the sticking.
Thanks! It's worked so far, the clutch works great!
Old 10-03-2018, 01:43 PM   #5
hholbein
1997 SW2
Interesting. I recently injected some Sylglide into my Clutch master piston assembly from under the steering wheel assembly (jasenpeters post a few months ago) and that stopped the squeak. Perhaps it will prolong the clutch master cylinder from wearing out like yours did for another 5+ years!
Mine would reliably squeak above 85F. Super annoying.
Replaced clutch - Now clutch pedal too light and engagement not correct jk3006 S-Series Tech 23 07-21-2013 07:49 AM
Filling the Clutch Master/Slave Cylinders without 'Bleeding' mavmav How-To Library 19 05-16-2013 04:35 PM
Replaced clutch hydraulics now clutch pedal won't depress - Help GPCBAKER S-Series General 17 03-13-2012 01:01 PM
Ques re: clutch kit & slave/master cylinders dnta11 S-Series Tech 10 10-27-2011 02:42 PM
replaced spark plugs now cylinders misfire BGroth S-Series Tech 1 10-31-2009 01:34 PM
