Old 10-12-2018, 01:18 AM   #1
Elow
Elow is on a distinguished road
Default 2002 Saturn sl2 crank nonstart
I have a 2002 Saturn sl2 that will crank but won’t start. Had the error code U1301 and found I had a short (open) on my positive battery terminal replaced the wire and it also has a new battery. Now it still won’t start. It cranks just doesn’t start. also I have found that when the key is in the run position and if you turn the a/c fan off all of the lights flash rapidly. Any ideas of what to look at
Add to Elow's Reputation
Rate the quality of this post and help Elow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Elow is offline   Reply With Quote
Old 10-12-2018, 01:45 AM   #2
Default Re: 2002 Saturn sl2 crank nonstart
The engine turning over but not firing up usually means one of two issues, fuel or spark. Be sure security is OFF during starting. If security is flashing, injectors are disabled - Passlock security.
Did you check for blown fuses in the engine fuse box?
Spark check; remove plugs wires (after noting firing order) and have someone start up while you observe for spark across both ignition coil towers.
Fuel check for pressure to injectors; with ignition turned on, the fuel pump runs for two seconds, enough to pressurize fuel rail to injectors. Remove fuel test valve cap, loosely cover the schrader valve while depressing the valve stem - fuel should spray with force.
2002 Saturn Sl1 No Crank/No start jlangille S-Series Tech 5 05-09-2018 10:28 PM
2002 Saturn SL2 Yes Crank/No Start Saturn2002SL2 S-Series Tech 9 05-09-2018 01:33 AM
2002 SL1 no crank annaleigh S-Series General 15 11-09-2016 11:46 PM
2002 Vue 3.0 crank will not start CAPOHIO Vue Tech 7 03-04-2012 07:17 AM
2002 vue crank sensor svphelps Vue General 1 12-19-2006 03:11 AM
