Thread Tools | Display Modes |
#1 |
![]() Join Date: Dec 2005
Location: Norwich NY 1993 Sukuki GSX-R 750 2002 Kawasaki Ninja 250r
2000 SC2
Well, to make a long story short... When i start the car when the engine is cold, I have to hold the gas pedal down because the car has an irradic idle at first and will stall out. Once started, the pedal only has to be held down for about 10 seconds until the engine starts running smoothly and then the car runs perfectly fine.
The other day after this happened, the service engine soon light started flashing at me..... and then stayed on constantly... so i proceeded to autozone to get the codes read.... they are as follows: p0300 Random/Multiple cylinder misfire detected p1651 QDM B Quick Fault P1650 QDM B Fault P1599 Engine Stall or Near Stall Detected P0326 Knock Sensor 1 CKT Range/Perf Bank 1 or 1 sensor P0605 PCM Read Only Memory (ROM) Error All of this because of a crazy idle at first.... The autozone worker reset the computer and since then the Service Engine Soon light has not come on... The workers at Autozone said it sounds like it may be caused by an air flow sensor or a throttle sensor... something that will affect the mixture when i first start the car Any Ideas? Thank you for your help Robert |
#2 |
![]() Join Date: Nov 2005
2004 VUE 2.2L
2008 AURA XE
I'm sorry but you need to get to a saturn dealer and have them scan the engine for codes.
The guys at Autozone don't have the know how and with the codes they gave you you need to have the dealer diagnosis the car. Then you'll know for sure...
Previously Owned 98 SL2, Sold 98 SL, Sold When your Saturn is well kept YOU are well kept. Second Car: Buick LaCrosse 2006 |
#3 | |
![]() Quote:
Toyota: Moving Forward... off a cliff at a high rate of speed. |
Bookmarks |
SES AutoZone Codes | HubDadTim | S-Series Tech | 8 | 05-09-2008 02:06 AM |
Codes finally read. | RespectTheTeg | L-Series Tech | 7 | 10-24-2007 07:40 PM |
how do you read codes | drill_bit | S-Series Tech | 1 | 08-13-2007 11:35 PM |
codes read, now what? o2 | AltF4 | S-Series Tech | 8 | 04-25-2007 03:54 PM |
SES codes - different from AutoZone to dealer | javahle | S-Series General | 9 | 09-30-2005 03:22 PM |
