Old 01-01-2011, 01:23 PM   #1
jhonky
jhonky is on a distinguished road
Default MMO soak + seafoam + steam clean
is it ok to do all 3 of these at the same time? wanting to pour the MMO in the spark plug holes, seafoam where the oil goes, and do a steam clean and then change the oil in about 100 miles...is it ok to do all 3 at once?
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 01-01-2011, 01:34 PM   #2
Default Re: MMO soak + seafoam + steam clean
Don't put Seafoam in the crankcase; it's too thin. A little in the fuel tank _might_ help with the injectors, but Techron would be better.
You can't exactly do the MMO soak and the steam clean at the same time, because the MMO soak is an engine-off procedure and the steam clean is engine-running. But you could do the steam clean right after the MMO soak; wouldn't make any difference either way.
Add to madpogue's Reputation
Old 01-01-2011, 01:58 PM   #3
jhonky
or conversely, I could do the steam clean first, and then do he mmo soak later? j/w not trying to be disagreeable lol
98 SL2
245,000 miles
215/45 17"
Old 01-01-2011, 02:00 PM   #4
Yeah, either sequence is fine.
Old 01-03-2011, 01:08 PM   #5
cousinsaul
cousinsaul is on a distinguished road
cousinsaul's Avatar
Default
I agree with madpogue. I put a little seafoam in the oil thinking it woul clean out some gunk and ended up spinning a rod. Just use a good oil and change it often enough.
Add to cousinsaul's Reputation
Rate the quality of this post and help cousinsaul reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cousinsaul is offline   Reply With Quote
Piston Soak: MMO or SeaFoam? srl1104 S-Series Tech 44 02-01-2010 04:35 PM
seafoam soak bdobraj S-Series General 4 08-23-2009 01:50 PM
MMO/Seafoam soak- hot or cold engine? spencerforhire S-Series Tech 3 10-21-2007 12:02 PM
After Seafoam soak, very little smoke? MikeD2 S-Series Tech 23 09-20-2007 11:55 AM
Week long seafoam soak sl2clone S-Series Tech 14 04-16-2007 12:04 AM
