Old 01-06-2010, 02:25 PM   #1
93 SL1 Canada
93 SL1 Canada is on a distinguished road
93 SL1 Canada's Avatar
1993 SL1
Default Need good Toronto-area Saturn mechanic
My current mechanic won't talk technical with me. He will not listen to suggestions. If I have a transmission problem, he tells me I should get a new car.
I try to do some work on my own, being unemployed, but the snow and freezing temperatures get in the way.
If anyone out there knows of a scrupulous, knowledgeable Saturn mechanic in the greater Toronto area (Richmond Hill would be perfect), could you please send the contact info.
Thanks!!
Add to 93 SL1 Canada's Reputation
Rate the quality of this post and help 93 SL1 Canada reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
93 SL1 Canada is offline   Reply With Quote
Old 01-06-2010, 03:00 PM   #2
saturnsctwo
Default Re: Need good Toronto-area Saturn mechanic
Thanks!!
there's plenty of saturn mechanics right here on this site. sooner or later someone will ring in, but post your problem first....
Old 01-06-2010, 03:15 PM   #3
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
You could try Mike De Groot at De Groots Diagnostic Centre Ltd
4 Falaise Road, Scarborough, ON M1E 3B5 Kingston rd and Morningside, not richmond hill though.
He certified my SL recently on the advice of a very good friend. Honest clean shop nice to talk with. I also have a shop in Whitby I deal with but that might be out of your way.
I don't have much work done by others, I do everything myself. I Only use shops for inspections, drive cleans, and some tire changes. What are your issues? As said people here may be able to help.
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
Add to mattelderca's Reputation
Rate the quality of this post and help mattelderca reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattelderca is offline   Reply With Quote
Old 01-06-2010, 03:43 PM   #4
93 SL1 Canada
1993 SL1
I've posted the transaxle issue on:
SaturnFans Forums > Models > Saturn S-Series > S-Series General
> 93 SL1 Auto transaxle problems: what should I do?]
Here's my plan:
-Get computer code for problem (SAS light comes on).
-Load test battery. It's not old.
-Depending upon what the code is (and assuming battery is good), the alternator is the likely culprit. If so, Replace.
-Oil and filter.
-Tranny fluid and filter.
-Possibly change ECTS and connector.
-Put snow tires on.
The connector for the ECTS is not standard, so it may have already been replaced. But the connector boot seems hardened - I could not remove it - so maybe the contacts are corroded.
If the tranny is still a problem in the spring (when the weather is better!), I plan on replacing the solenoids and maybe the bus plate. These would seem the likeliest suspects.
Thanks!!
Old 01-06-2010, 03:45 PM   #5
93 SL1 Canada
1993 SL1
BTW, Whitby is not to far.
Looking for a good Saturn Mechanic in NY Mid-Hudson Valley Area tgparker S-Series General 0 08-25-2008 08:00 PM
Looking for good mechanic in NJ area for radiator work... sandybright S-Series Tech 8 01-09-2008 03:26 AM
Good Chicago area mechanic shop?? HomeComing99 General Saturn Discussion 1 04-26-2003 07:16 PM
Competent Saturn dealer in Mississauga/Toronto/Oakville area? FFWD General Saturn Discussion 10 10-23-2002 07:00 PM
Good Mechanic in MD/DC area The Nord General Saturn Discussion 0 01-30-2002 01:38 PM
