Old 05-11-2009, 09:56 PM   #1
michael1944
michael1944 is on a distinguished road
Default Headlights won`t turn off
My 2001 L200 has headlight issues. If the headlights are turned on, the only way to turn them off is to disconnect the battery. If the turn signals are turned on the headlights come on and won`t go off. The headlights will sometimes come on by themselves, even with the car not running and the key
off. Again the only way to turn them off is to disconnect the battery or pull the fuses. When they come on it is always in high beams and I can`t dim them. Anyone know what could be causing this?
Add to michael1944's Reputation
Rate the quality of this post and help michael1944 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
michael1944 is offline   Reply With Quote
Old 05-12-2009, 08:51 AM   #2
s3nfo
s3nfo has a spectacular aura abouts3nfo has a spectacular aura abouts3nfo has a spectacular aura about
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: Headlights won`t turn off
Couple of common failure items that can cause this. The stalk switch for headlights and turn signals is a known high failure item. Less than $50 for parts and an easy half hour DIY job. Next would be BCM failure which can cause lights to be possesed. $400 - 700 and can only be done by the dealer as the new BCM needs to be programmed for the car.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Turn on headlights and radio scrambles?? Project 50MPG S-Series General 3 08-18-2009 04:53 AM
Headlights keep going off, and need to tap lens to turn on... Kristine S-Series General 5 12-29-2008 10:27 AM
Headlights/Turn Signal ?s (n00b questions?) tehSaturn S-Series Mods 3 11-18-2008 09:47 AM
Headlights won't turn off cruzr S-Series General 10 07-11-2006 06:04 PM
Headlights (How do I turn the darn things off) stormcrow Vue General 57 05-05-2005 06:11 PM
