Old 09-23-2008, 11:39 AM   #1
nuheriot
nuheriot is on a distinguished road
Default SL2 pulling left slightly
I changed out all four struts this weekend and had an alignment done this morning. On top of the alignment I had a new driver's side front tire mounted (previous one had a nail in it). The existing tires were just put on the car 2 months ago so they are hardly worn.
While driving into work (highway) I noticed that the car was pulling very slightly to the left. When turning to the left on the highway if I let go of the wheel it tends to stay partially to the left. When turning to the right if I let go of the wheel it tends to straighten itself out. I called Goodyear and they said that a bad alignment won't cause that to happen and said that it sounds like a bad strut mount bearing. I replaced all 4 strut mounts when I changed the struts. Anyone have any ideas? Should I post my alignment results? Would a new drivers side front tire cause this to happen?
Add to nuheriot's Reputation
Rate the quality of this post and help nuheriot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nuheriot is offline   Reply With Quote
Old 09-23-2008, 11:57 AM   #2
Default Re: SL2 pulling left slightly
A new tire and a slightly used tire can cause things like that. As will a dorked up alignment.
So, switch the 2 front tires left to right and see if the problem moves to the right side.
Are the rear tires the same age and brand/type as teh slightly used front one?
Old 09-23-2008, 12:04 PM   #3
nuheriot
Yup, all tires are the same; 3 are 2 months old and then the front left is brand new. The tires are directional, should I still swap the tires, temporarily, to see if that is the cause?
Is it easy to dork up an alignment using the fancy reflector alignment system most shops use? What are the recommended ranges for a 96 SL2 alignment? I have the printout but it is only partial and I am not sure I am reading it correctly. It only printed the numbers, not titles, headings, descriptions, etc. Just numbers.
Old 09-24-2008, 07:40 AM   #4
72gssaturn
72gssaturn will become famous soon enough72gssaturn will become famous soon enough
72gssaturn's Avatar
2008 Astra XR
if the aligment is up to spec, then u may have a rack (rack & pinion) problem. a seal or o-ring may be failing causing the rack to want to steer left. souunds more like a caster problem with the left strut alignment.
Gerry
72 Buick GS red
2008 Astra XR black 3dr
99 SL1
Add to 72gssaturn's Reputation
Rate the quality of this post and help 72gssaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
72gssaturn is offline   Reply With Quote
Old 09-24-2008, 10:59 AM   #5
2003MercMaraude
2003MercMaraude is on a distinguished road
You are more likely than not, NOT going to get an alignment right on the first try. Most consumers will just 'live with' a slight pull and expect it, so shops rush. If you don't have a print out of your alignment, you have no idea what they did or did not set properly. Get a print out next time. And bring the car back to have the alignment re checked and explain the pull-- they are responsible for the work within the period that the shop warrantees it.
Rides:
2004 Ford Taurus SEL
2003 Mercury Marauder
1988 Chevy K1500
1976 Pontiac Firebird
Add to 2003MercMaraude's Reputation
Rate the quality of this post and help 2003MercMaraude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2003MercMaraude is offline   Reply With Quote
Old 09-24-2008, 11:10 AM   #6
nuheriot
I plan on going back to the shop to have them check it just to make sure it is all good.
Here is what they gave me as my alignment results. Without the full printout I am not sure what numbers mean what.
Old 09-24-2008, 12:19 PM   #7
You can put the new tire on the rear and one of the rears on the front. Be sure that they still rotate in the proper direction.
These are the real alignment specifications. Print them out for show and tell.
If an Alignment Is Performed
Front
Camber:
Preferred Setting -0.50
Minimum -1.20
Maximum +0.20
Cross Camber:
Preferred Setting 0.00
Minimum -0.40
Maximum +0.40
Caster:
Preferred Setting +1.70
Minimum +1.10
Maximum +2.30
Cross Caster:
Minimum -0.40
Maximum +0.40
Toe (Per Wheel):
Preferred Setting +0.10
Minimum 0.05
Maximum +0.15
Total Toe:
Preferred Setting +0.20
Minimum +0.10
Maximum +0.30
Rear
Camber:
Preferred Setting -0.70
Minimum -1.40
Maximum 0.00
Cross Camber:
Minimum -1.00
Maximum +1.00
Toe (Per Wheel):
Minimum +0.05
Maximum +0.15
Total Toe:
Minimum +0.10
Maximum +0.30
Old 01-28-2009, 03:07 AM   #8
curls
curls is on a distinguished road
1992 SC2
Front
Camber:
Minimum -1.20
Maximum +0.20
Caster:
Minimum +1.10
Maximum +2.30
Rear
Camber:
Minimum -1.40
Maximum 0.00
Are these the same for 92 SC DOHC?
TiresPlus is using different specs for camber. --JustTires matches these specs.
TiresPlus (vs. JustTires):
Front
Camber:
Minimum -0.9 -1.20
Maximum +0.5 +0.20
Rear
Camber:
Minimum -1.70 -1.40
Maximum +0.3 0.00
For Caster they are using the same slightly different numbers than here:
Caster:
Minimum +1.20 +1.10
Maximum +2.20 +2.30
My car is outside range of one's camber but not the other's. Also the numbers they read are quite different in some cases. TiresPlus where I have the warranty is the one that said the camber & caster can't be adjusted.
Add to curls's Reputation
Rate the quality of this post and help curls reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
curls is offline   Reply With Quote
Old 01-28-2009, 07:37 AM   #9
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
If I'm not mistaken isn't the car suppose to pull slightly to the right? This is in case you fall asleep driving you don't veer into on coming traffic?
Add to Fox Slaughter's Reputation
Rate the quality of this post and help Fox Slaughter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fox Slaughter is offline   Reply With Quote
Old 01-28-2009, 11:40 AM   #10
nuheriot
I think the issue is the slope of the section of highway that I notice the pull on. All road drains are in the median, between E and W lanes so either side of the highway slopes to the left. On open sections of what appears to be flat, straight highway the steering stays true.
Old 01-31-2009, 01:41 AM   #11
curls
1992 SC2
The numbers OldNuc posted & JustTires uses are correct. Another TiresPlus also uses those numbers. So I hit an error in a specific shop. Saturn dealer gave me matching numbers pulling them from ALLDATA database. TiresPlus uses Hunter equip & they provide the specs.
So now I have an appt at a different TiresPlus...with the tech who went out of his way to answer my specs questions. Fingers crossed.
Pulling slightly right marx404 Astra General 31 08-12-2019 08:24 AM
Noisey Aura and pulling to the left. Oceanmist07 Aura General 7 08-03-2007 05:07 PM
Pulling to the left karinhesed86 S-Series General 4 12-16-2006 01:33 AM
right side of car is slightly higher than left now justbob150 S-Series Tech 4 10-17-2005 09:52 PM
Slightly bent left front wheel SJGSilverSL Miscellaneous Tech 6 05-23-2001 01:52 PM
