Old 11-24-2007, 08:23 PM   #1
chrono111
chrono111 is on a distinguished road
Default XR gear ratios?
Anyone know what the XR's gear ratios are or the final gear ratio? Can't seem to find this info.
Add to chrono111's Reputation
Rate the quality of this post and help chrono111 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chrono111 is offline   Reply With Quote
Old 11-24-2007, 09:14 PM   #2
gbech
gbech is on a distinguished road
2007 AURA XR
2005
Default Re: XR gear ratios?
Transmission Hydra-Matic 6T70
Gear ratios:
First 4.48
Second 2.87
Third 1.84
Fourth 1.41
Fifth 1.00
Sixth 0.74
Reverse 2.88
Final drive ratio 2.77
Add to gbech's Reputation
Rate the quality of this post and help gbech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gbech is offline   Reply With Quote
Old 11-24-2007, 09:14 PM   #3
yug
yug is on a distinguished road
Is this what you are looking for ?
Maximum engine horsepower
315
Maximum engine torque:
280 lb-ft
Maximum gearbox torque:
380 lb-ft
Gear ratios:
First:
4.48
Second:
2.87
Third:
1.84
Fourth:
1.41
Fifth:
1.00
Sixth:
0.74
Reverse:
2.88
Maximum shift speed:
7000 rpm
5-position quadrant:
P, R, N, D, (M)
Case material:
die-cast aluminum
Shift pattern:
(2) three-way on/off solenoids
Shift quality:
five variable bleed solenoids
Torque converter clutch:
Converter size:
258 mm
Transmission weight (kg / lb):
102 / 273 (wet)
Fluid type:
DEXRONŽ VI
Fluid capacity (L / qt):
9.0 / 9.5
Assembly site:
Warren, Mich.
Additional features:
Clutch-to-clutch operation (except 1-2); integrated transmission electro-hydraulic control module with driver shift control and performance algorithm shifting
Add to yug's Reputation
Rate the quality of this post and help yug reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yug is offline   Reply With Quote
Old 11-26-2007, 03:23 PM   #4
chrono111
Thanks guys!
Old 05-15-2018, 12:27 AM   #5
Eddie&Aria_S
Eddie&Aria_S is on a distinguished road
2007 AURA XR
Devil Re: XR gear ratios?
So IDK if it's possible but I'm building the xr because everyone says it can't be done so when I have a new daily I'm going to pull the trans out and swap of all the gears for new shorter ratios, so I guess I'm just wondering what the final drive ratio is for the aura because I get 3 different ones for the same transmission code. I'll post the ones I found. And yes the attached ratios are from a 370z nismo and their Excel is impressive so is why I'm going with those for now.
Hope it helps someone and my question is answered.
-eddie_srt6
Add to Eddie&Aria_S's Reputation
Rate the quality of this post and help Eddie&Aria_S reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eddie&Aria_S is offline   Reply With Quote
Old 06-17-2018, 04:47 PM   #6
GR898SL2
GR898SL2 will become famous soon enoughGR898SL2 will become famous soon enough
GR898SL2's Avatar
Final drive ratio: 2.77:1, same as the V6 powered Malibu LT. That is the standard that is provided directly from GM.
As this transmission is shared with Ford, there were many applications, from passenger cars to large crossovers, and quite possibly different states of tune.
The 3.16:1 was optional for the Aura XR V6 and Malibu LT V6 at no cost.
I always believed the 3.39:1 was reserved exclusively for the Pontiac G6 GT/GXP coupe and sedan given their sporting aspirations but the G6 is basically an Epsilon under the skin, the same as the Aura and Malibu.
No more Saturns! :(
'11 & '15 Subaru Forester; '15 Nissan Altima
Add to GR898SL2's Reputation
Rate the quality of this post and help GR898SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GR898SL2 is offline   Reply With Quote
Gear Ratios ? jobberwalkie S-Series Tech 3 01-25-2006 11:17 AM
gear ratios bgsneeze Ion General 0 09-28-2005 08:26 PM
Gear ratios on the 97 SC 1 coupe? SC1-GTR S-Series Mods 4 10-27-2002 02:32 AM
Gear ratios? HumpMan Vue Tech 6 01-31-2002 11:29 PM
Gear Ratios - What do they really mean? Mr Mike S-Series Tech 4 11-06-2000 05:47 PM
