Old 09-22-2009, 09:50 PM   #21
PanVet
PanVet is on a distinguished road
2008 Astra XE
2004 VUE 3.6L
Default Re: Pulling slightly right
Originally Posted by marx404 View Post
I just noticed that my XE is pulling very slightly to the right when I accelerate, but not when I am coasting. Is this normal? The tires seem to be balanced, no wobbling or shaking, car drives just fine otherwise.
Mine will do that also if I accelerate fast from a dead stop.
Add to PanVet's Reputation
Rate the quality of this post and help PanVet reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PanVet is offline   Reply With Quote
Old 07-02-2019, 03:02 PM   #22
Ecomike
Did any one ever figure this out?
2003 Saturn Ion 3, Manual 5 speed is doing this only when accelerating from a stop or while cruising. No pull while cruising.
Could bad engine mounts or Tranny mount cause this?
Add to Ecomike's Reputation
Rate the quality of this post and help Ecomike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-06-2019, 08:30 AM   #23
David R
2009 Astra XE
1997 SW2
Hum... posting to the wrong forum for a Saturn Ion, and its a very old thread.
That said...
Assuming this a new issue, and your vehicle is high mileage. I'd be looking at a host of things in the suspension and steering. Struts aging, worn tie-rod ends, control arm bushing. There may also be other contributing factors as well.
2009 Astra XE 5sp 225K km
1997 SW2 DOHC Auto 330K km - Parked, waiting for the value of scrape to go up
Add to David R's Reputation
Rate the quality of this post and help David R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-06-2019, 05:03 PM   #24
Ecomike
The sight search engine dropped me here, and since this thread was about the same topic, and ion is also a Saturn with front wheel drive and Saturn suspension I started here.
Tires, rim and struts were already new. That got rid of a steady pull (curb attack on the un armed Ion bent a wheel, murdered a tire, LOL).
It had been aligned before and after the new struts were installed.
New tie rods and new sway bar links and SBL bushings added, not yet aligned but replacing the worn ones helped.
I had never heard of heard of loose tie rods causing a pull ONLY when accelerating.
I am still leaning towards possible engine mount/Tranny mount being bad???
In fact all the steering pull issues I ever worked on or had in 45 years were continuous, even while cruising and were almost always bad/new or worn tires.
I will have them recheck the strut caliper bolts and make sure the bottom ones are not moving!!! I agree on that one possibly being cause.
I am 1500 miles from the car, helping my daughter debug the cause.
Thanks for the reply!!!
That said...
Old 07-06-2019, 07:00 PM   #25
Originally Posted by Ecomike View Post
...In fact all the steering pull issues I ever worked on or had in 45 years were continuous, even while cruising and were almost always bad/new or worn tires...
A possibility of one tire having internal layers separating (probably at the right side) could account for the pulling which is being experienced.
329,000 miles - Holy canolli!
A leftist, deep-stater will get the nomination for POTUS. What follows if he gets his way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Add to pierrot's Reputation
pierrot is online now   Reply With Quote
Old 07-07-2019, 04:13 PM   #26
Ecomike
I have never experienced, nor heard of, nor could I find any online claims that a tire issue (of any kind) would only pull to the side during acceleration. This a pull that is only during acceleration, from a dead stop or from any initial speed.
The pull stops while cruising at a steady speed.
Are you saying a tire issue can cause a pull only while accelerating?
Just to be clear.
Old 07-07-2019, 05:46 PM   #27
I intentionally highlighted the words possibility and could for a reason: I may be wrong (and I probably am - that's okay, it's not a personal thing). I believed it was something to be considered.
Old 07-07-2019, 06:20 PM   #28
Ecomike
My original post considered it and discounted it, but was asking for any out in left field experiences with odd causes..... In 47 years I have never seen or felt this exact issue, and I have had bad tires, new and old, bent frames, Cracked frame near where the steering hardware connects to the car, worn front end parts, busted engine and trany mounts, and even what we call death wobble on Jeeps (I also own jeeps LOL) and never had this issue before.
But thanks for the feedback!!!
Right now I am waiting for more feedback from the driver/owner (1500 miles away) as to whether the new tie rods ends and Sway bar links stopped it. It needs to be realigned first this week. I have also asked he to check for a busted engine or tranny mount.
Old 07-08-2019, 08:26 AM   #29
maschinenbauer
maschinenbauer will become famous soon enough
maschinenbauer's Avatar
2008 Astra XE
I had a tire issue last year that seemed impossible to diagnose. The car pulled slightly to one side and drove me crazy. I noticed it more while accelerating, but it was definitely always there at cruising speed. If I let go of the wheel on a highway, it would veer to one side.
Mileage was only 100k so nothing is too worn out or sloppy. The alignment shop kept saying everything is straight and within spec. They even tried to compensate for it with extra camber on one side. It started getting worse and developed a slight vibration. Eventually the tire started to visibly bulge from an outer band that had let loose. The bulge was very subtle and hard to see, but with all 4 tires off the car and lying on the ground, you could just barely see that one was slightly more oblong. Just a slight difference in tire diameter across the tread width, due to the loose band, caused the steering to do weird, unexplainable things.
It was time to replace tires anyway, and doing so 100% cleared up the issue.
'08 Astra XE 5-speed
'72 Chevrolet El Camino
'31 Ford Model A pickup
Add to maschinenbauer's Reputation
Rate the quality of this post and help maschinenbauer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
maschinenbauer is offline   Reply With Quote
Old 07-08-2019, 01:31 PM   #30
Ecomike
Thanks!!!!
The tires are new, so I will add them back to the maybe causing it list!!!
Old 07-08-2019, 01:58 PM   #31
AstraFasta
I had some cheap tires on the back of the Astra which made some noise and vibration. The shop rebalanced the tires and in the process discovered some delamination.
Tech said not uncommon on cheap tires these days. I didn't see the issue on visual inspection so am not sure if the tech figured it out with balancing results, better visual inspection, dismounting or what.
Old 08-12-2019, 08:24 AM   #32
juvanta
juvanta is on a distinguished road
Good article. Really intersting
Add to juvanta's Reputation
Rate the quality of this post and help juvanta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
juvanta is offline   Reply With Quote
SL2 pulling left slightly nuheriot S-Series Tech 10 01-31-2009 01:41 AM
A slightly different vibration question sl2gold S-Series Tech 9 11-17-2008 08:57 AM
Slightly Moody Transmission CND_SC1 S-Series Tech 1 06-30-2006 12:10 PM
slightly confused Saturnaddict S-Series Mods 32 01-17-2005 11:09 PM
Portable refrigerator (slightly o/t) gaf3 Vue General 18 07-21-2003 11:46 PM
