Old 11-24-2009, 01:03 PM   #1
lausch1973
lausch1973 is on a distinguished road
Default Backup lights don't work unless...
I have a 2002 SL1. About 9 months ago we had to change the switch for the backup lights. In the past 2 months I found the backup lights don't work unless I hold the shifter hard in reverse. Does anyone have any lay-man explainations on how to resolve this issue?
lausch1973 is offline   Reply With Quote
Old 11-24-2009, 01:10 PM   #2
TXSaturn02
TXSaturn02's Avatar
Default Re: Backup lights don't work unless...
auto or manual?
New owner report of 08/08/19: 234,408 Miles
As of 11/12/20: 78,895 Miles
Old 11-24-2009, 01:12 PM   #3
Originally Posted by TXSaturn02 View Post
auto or manual?
There's no holding an autotragic in reverse...hard or soft...
Dunno about the issue, I'd check the cables to see if the ends are frayed or stretched or something.
Old 11-24-2009, 01:16 PM   #4
lausch1973
It is a 5 speed standard.
Old 11-24-2009, 01:18 PM   #5
todd8
todd8 has a spectacular aura abouttodd8 has a spectacular aura about
Make sure that the opening where the back up switch threads into the shift tower is not stripped. I had the same problem, and some how the threads in the opening were pretty much gone. I ended up having to replace the entire shift tower cover with one from a JY - they are all the same from 91-02.
I tried JB weld, and rethreading, but that did not hold.
todd8 is offline   Reply With Quote
Old 11-24-2009, 01:20 PM   #6
lausch1973
todd8...what did you do to fix it if that ends up being my problem?
Old 11-24-2009, 01:22 PM   #7
todd8
See my thread above. I edited it to indicate the fix
Old 11-24-2009, 01:40 PM   #8
lausch1973
What is JY?
Old 11-24-2009, 02:15 PM   #9
Junk Yard
Tags
backup lights, reverse, tech
Backup lights not working. YourMainParadox Vue Tech 16 05-27-2017 02:38 PM
Backup lights don't work unless... lausch1973 L-Series Tech 1 11-24-2009 11:00 AM
No backup lights Spacepope Ion General 1 02-04-2007 01:24 PM
Backup Lights.... Fixed Daucsset S-Series Tech 1 01-23-2007 02:49 PM
Backup lights not working?!?! kirby2112 S-Series General 4 07-28-2005 05:46 PM
