Old 03-26-2020, 04:39 PM   #1
PrestonIII
PrestonIII is a jewel in the roughPrestonIII is a jewel in the roughPrestonIII is a jewel in the rough
1994 SL2
1994 SL2
Default 94 SL2 HCE Power Steering Pump Growl
Since I purchased my car 3 years ago, the power steering pump has growled. The tone goes up as the RPM goes up. It's rather loud and it never stops.
I originally thought it was one of the pulleys (idler or tensioner), so I replaced them both along with the serpentine belt. It was an inexpensive fix, but it didn't help. I've topped of the fluid once (small amount: down about 1/2 inch), though I see no leaks.
I finally borrowed an engine stethoscope, and tracked it down to the power steering pump, thus eliminating the alternator. (I know; should have done that first.)
Is there a chance that a fluid flush might cure the noise? I'm not looking forward to the mess and the labor in removing lines up under the car.
Or am I looking at a mandatory pump replacement? The car has under 80K miles on it.
Preston
Add to PrestonIII's Reputation
Rate the quality of this post and help PrestonIII reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PrestonIII is offline   Reply With Quote
Old 03-27-2020, 08:05 AM   #2
Highmile
Highmile's Avatar
Default Re: 94 SL2 HCE Power Steering Pump Growl
I would definitely start with a fluid flush. It's really not that bad, Take the return line off the rack from above.
Be sure to refill it with the correct fluid. Spec's dextron III
Highmile
'95 SL1 705k and counting
Add to Highmile's Reputation
Rate the quality of this post and help Highmile reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-27-2020, 05:59 PM   #3
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
I took off the return line at the bottom, and installed a Wix 33033 15 micron fuel filter.
Major difference in noise....
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Power steering pump small leak - slow death, or change pump now? Upstate Saturn S-Series Tech 19 11-20-2014 05:08 PM
Photo of new power steering pump leaking from hole in casting. Bad pump? tgferg67global S-Series Tech 1 11-10-2010 06:11 PM
Power Steering Pump riggs S-Series Tech 0 01-07-2007 09:35 PM
Need quick help - replacing power steering pump and water pump on V6…. Emanresu2 L-Series General 6 05-18-2006 05:38 PM
More service problems - Power Steering Growl usa4624 L-Series General 6 11-14-2003 10:10 PM
