Old 03-04-2020, 11:06 AM   #1
SaturnMinion
SaturnMinion has a spectacular aura aboutSaturnMinion has a spectacular aura aboutSaturnMinion has a spectacular aura about
SaturnMinion's Avatar
2007 ION-2 Sedan
Question Trunk leak
I'm getting a lot of water leakage in my right side trunk area especially after a strong rain. Is this a known problem?
2007 Saturn Ion 2 Sedan, 2.2L DOHC 16V with Duel Balanced Shafts. Automatic Transmission. 180,246K. One owner car.
Add to SaturnMinion's Reputation
Rate the quality of this post and help SaturnMinion reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnMinion is offline   Reply With Quote
Old 03-04-2020, 12:15 PM   #2
2Ion2_2007
2Ion2_2007 is on a distinguished road
2007 ION-2 Sedan
2007 ION-2 Sedan
Default Re: Trunk leak
Check the black gasket when the trunk is open. Maybe a tear or you have a rusted out spot
Previous Saturn SC1 1995
Previous log-in SC1_Oil_Burner
Current:
2007 Saturn Ion-2 (Silver) 314,378 km - My daily driver
2007 Saturn Ion-2 (Red) 38,000 km - Wife's grocery car
Add to 2Ion2_2007's Reputation
Rate the quality of this post and help 2Ion2_2007 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2Ion2_2007 is offline   Reply With Quote
Old 03-04-2020, 12:41 PM   #3
SaturnMinion
2007 ION-2 Sedan
Thumbs Up Re: Trunk leak
The rubber seal is brand spanking new. But I found a small rust spot that went through. Sure enough the culprit. I used to own a paint that turned rust into a black epoxy. Got it from Eastman I think. Shelf life was terrible, but once it hardened that stuff would need nitro glycerin to open it up, (that's what happened to the can it came in). Any suggestions short of body repair? It's too small for body work but it will only get bigger if I don't do something now.
Old 03-04-2020, 12:48 PM   #4
2Ion2_2007
2007 ION-2 Sedan
2007 ION-2 Sedan
Go to home depot and buy a product called OATEY FIX it STICK #31270. It is an all purpose bonding epoxy. Comes in an 8 inch cylinder. Outer core resin. Inner core hardener. Cut off a small piece, and kneed with fingers till uniform colour. Apply to a rust free dry surface. Will harden like steel. About $15 CAD. If you are american that will probably be like $8-9 usd.
Current:
Old 03-04-2020, 12:49 PM   #5
2Ion2_2007
2007 ION-2 Sedan
2007 ION-2 Sedan
Best to make sure you dry out the trunk as that is where the battery is any you don't want your spare and jack rusting in place. Good luck
Current:
Old 03-04-2020, 12:57 PM   #6
SaturnMinion
2007 ION-2 Sedan
Yeah I know, (Florida). Funny you mentioned the two part epoxy stick. That's the first thing that came to mind, but I have the Gorilla Glue version.
Update: The Oatey stick is not in Home Depot but at Lowes. $6.58 American...
Old 03-04-2020, 04:26 PM   #7
2Ion2_2007
2007 ION-2 Sedan
2007 ION-2 Sedan
I guess the Canadian dollar is like the peso these days. Anyways epoxy will work. There is also a plumbers version that can be applied when wet. Same price but smaller quantity by 60%.
Current:
Old 03-14-2020, 02:20 PM   #8
2Ion2_2007
2007 ION-2 Sedan
2007 ION-2 Sedan
How did the repair go
Current:
Trunk leak Jonasan308 S-Series Tech 10 04-06-2017 08:22 AM
Leak in the trunk (hopefully the LAST one) jsevinsk S-Series Tech 5 10-10-2013 01:13 PM
Trunk leak fix! MJD112379 Aura General 13 07-24-2008 01:58 PM
Trunk leak on an '02 Alex_SC2 S-Series General 3 03-21-2008 10:00 AM
Trunk leak patcal S-Series General 3 11-01-2005 09:40 PM
