Old 03-02-2020, 04:59 PM   #1
eusjma
eusjma is on a distinguished road
Default Installed Tail Lamp Assembly with LED
I have a 2007 Saturn Aura XR.
The Right Tail Lamp Assembly got broken.
I purchased a used one that apparently came off a 2008 Saturn Aura.
The 2007 had a normal back up bulb. The 2008 assembly has an LED back up bulb.
So now the right side as LED back up bulb, the left side has a "normal" bulb.
Should I have any concern? Do I need some sort of equalizer for the LED light?
So far it all works without issue.
If I decide to replace the left side with a matching assembly would that be a problem (again wondering about an equalizer)?
Thanks
Add to eusjma's Reputation
Rate the quality of this post and help eusjma reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eusjma is offline   Reply With Quote
Old 03-02-2020, 10:04 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: Installed Tail Lamp Assembly with LED
Sounds like whoever owned the car that taillight came out of replaced the incandescent bulb with an LED bulb. You can just pick up a set of matching bulbs at the autoparts store so they both match. I believe they're 921's.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 03-03-2020, 01:41 AM   #3
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Yep, the original backup lamps are #921 incandescent bulbs.
Old 03-06-2020, 01:22 PM   #4
eusjma
oh ok
That makes sense. I thought maybe Saturn changed the design between 2007 and 2008
Thanks for the feedback!
Removing Headlight lamp assembly Russet L-Series Tech 12 10-31-2014 04:45 PM
Rear Right Lamp Assembly out YayForBeers Astra Tech 3 11-29-2013 08:08 PM
Finding replacement tail lamp assembly? vaska Astra General 6 04-17-2012 11:07 AM
Help Fog Lamp Assembly Replacement 2000sc2 S-Series Tech 0 08-26-2011 08:45 PM
tail lamp/bulbs Melissa_M S-Series General 3 11-07-2009 09:07 PM
