Old 01-24-2016, 11:30 AM   #4701
SRGW
SRGW is on a distinguished road
1997 SL1
Post Re: What did you do to your S-Series today...
Dug the 95 out of 24 inches[2 feet ] of snow!!
1995 SL1 220,650 Well Oiled!!
1997 SL1 53,100 Just A Teenager!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
Old 01-25-2016, 12:09 AM   #4702
SL2Hawaii
SL2Hawaii is on a distinguished road
Default Re: What did you do to your S-Series today...
Changed my manual transmission fluid, can feel the difference in the shifter.
Add to SL2Hawaii's Reputation
Rate the quality of this post and help SL2Hawaii reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2Hawaii is offline   Reply With Quote
Old 01-25-2016, 05:21 PM   #4703
jhonky
jhonky is on a distinguished road
Did a kreen soak, oil is at about 8k miles, switching to amsoil 5w-30 hdd oil
New windshield wipers and coat of rain x
Got an inspection, tech gave the car a compliment
98 SL2
5th gear swap- .643 gear
239,000 miles
205/45 17"
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 01-25-2016, 05:27 PM   #4704
CheapRacer
CheapRacer is on a distinguished road
CheapRacer's Avatar
1996 SC1
1996 SC1
Still cutting, grinding and welding..........
Green 1996 SC-1, Stock, Sportsman class Drag Racer, 17.97 ET @ 75 MPH.
Green 1996 SC-1, 355 Chev, NHRA/IHRA 10.90 class.
1994 Chev ext cab short box 2WD Daily Driver
Add to CheapRacer's Reputation
Rate the quality of this post and help CheapRacer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CheapRacer is offline   Reply With Quote
Old 01-25-2016, 06:40 PM   #4705
NWSaturn247
NWSaturn247 is on a distinguished road
NWSaturn247's Avatar
1993 SL2
Added an entire can of LiquiMoly mos2 to the sump. Now I should get a million miles per gallon
1993 SL2 AT - 149k mi
running M1HM 5w-20+STPHM & FL400S
LM2009 ftw
TCW3 dosed fuel
Goldie: a dame to kill for...watch out squirrels!
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 01-31-2016, 03:55 PM   #4706
NWSaturn247
1993 SL2
Swapped out PCV valves. The valve looked great, I just wanted to put the fresh 99 cent one in. Funny thing, both have the exact same code stamped on the side? Added a pint of Mobil 1 High Mileage 5w-20 to the sump. Took a pic. Looks OK?
LM2009 ftw
TCW3 dosed fuel
Old 02-01-2016, 08:38 PM   #4707
NWSaturn247
1993 SL2
Performed D/F of the transmission, 13.5k miles since the last one.
Fluid looked great, but the supplies were super cheap and ATF is so much cheaper than R/R the transmission. 148k miles and no issues yet, knock on wood.
($1.58 X 3) + $0.80 = $5.54
LM2009 ftw
TCW3 dosed fuel
Old 02-02-2016, 12:09 AM   #4708
Cessna
Cessna is on a distinguished road
I accidentally broke the hinge off my console cover. I'm going to have to fix it somehow, as a unicorn horn would be easier to find than a new gen 2 console.
1997 SW2 Manual 140,000 km
Add to Cessna's Reputation
Rate the quality of this post and help Cessna reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cessna is offline   Reply With Quote
Old 02-03-2016, 08:38 PM   #4709
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Replaced the passenger side tail light bulb as it stopped lighting up when the brake pedal was depressed. Heading to Canadian Tire, I picked up the Sylvania 2057 LL bulbs but accidentally grabbed the amber bulbs instead. Oh well, that'll learn me... it still worked anyhow.
Add to Goggles Pisano's Reputation
Rate the quality of this post and help Goggles Pisano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Goggles Pisano is offline   Reply With Quote
Old 02-04-2016, 11:33 PM   #4710
NWSaturn247
1993 SL2
Gave Goldie some 3k therapy on the interstate. Mobil 1 doing magic.
LM2009 ftw
TCW3 dosed fuel
Old 02-06-2016, 11:36 AM   #4711
jsevinsk
jsevinsk is on a distinguished road
jsevinsk's Avatar
2004 VUE 3.5L
Here's what I did to my Saturn today. I'll get it back in the Spring. But at least the SC2 is still safe in the garage.
Add to jsevinsk's Reputation
Rate the quality of this post and help jsevinsk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jsevinsk is offline   Reply With Quote
Old 02-06-2016, 01:10 PM   #4712
BV22
BV22 has a spectacular aura aboutBV22 has a spectacular aura about
2002 SC1
Passed emissions and safety inspection. I can drive it legally until 30 April 2017!
BV22
2002 SC1 5M
260k 1/16
Add to BV22's Reputation
Old 02-06-2016, 03:08 PM   #4713
jhonky
Cleaned out the car today. Creeper, jack, etc etc etc. prob pulled out over 100lbs of crap
98 SL2
239,000 miles
205/45 17"
Old 02-07-2016, 11:57 AM   #4714
Steve44
Steve44 will become famous soon enough
Steve44's Avatar
1999 SL1
It was actually last Thursday, but I changed the water pump. On Wenesday, it was 58 degrees. On thursday, it was 35 degrees. Figures.
World's biggest fan of doing it the easy way.
Add to Steve44's Reputation
Rate the quality of this post and help Steve44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steve44 is offline   Reply With Quote
Old 02-07-2016, 12:46 PM   #4715
ratwhisperer
ratwhisperer is on a distinguished road
ratwhisperer's Avatar
1996 SL2
I feel like my Saturn is so boring - nothing ever goes really wrong with it. I guess that's a good thing!!
Once my husband gets back from drill (he's in the National Guard and takes Ursula up to Salem once a month) we're going to do transmission fluid and give her an oil change.
Will likely give her a wash and clean out all my husband's fast food wrappers (because I know he filled the passenger seat with them over the weekend)
Add to ratwhisperer's Reputation
Rate the quality of this post and help ratwhisperer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ratwhisperer is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 03:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 07:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 01:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 07:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 08:03 PM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
