Old 08-27-2017, 01:00 PM   #5201
Default Re: What did you do to your S-Series today...
Had a little time this morning while getting ready to drive my son back to college.
So, installed this. Wasn't sure I was going to like it, but once I turned the lights on, I was hooked. Unfortunately, I already bought blue LEDs for the HVAC panel, and the stereo is blue, so I'll probably end up with a red IP and blue center stack, unless I decide to buy a bunch of red LEDs
I'll probably get a red LED for the cruise button on the steering wheel
An oddity - although the TC warning stayed on as expected, I did not get a CEL - I'd had one for a P0037 that I hadn't gotten around to doing anything with. I'll see if it comes back after driving a bit. The pics were just me checking the bulbs before putting it back together
File Type: jpg Pontiac Torrent IP lights on closer.jpg (111.0 KB, 92 views)
Old 08-28-2017, 08:39 AM   #5202
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
I love my soccer ball wheel covers, but I wanted to try these out and mannn they're slick. Also heatguned and treated my front bumper, it should actually fix it this time.
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
Old 08-28-2017, 09:13 AM   #5203
bumpdraft
bumpdraft's Avatar
1998 SW2
^Looks new!^
On the SC2,
>Installed a new shift cable assembly and cleaned the interior.
>POR15'ed some surface rust under the "running board" plastic snap-in thing and on the engine cradle in the usual places.
>Found that the source of a faint clunk was the forward splash shield on the driver's side where I'd broken the tabs removing it in cold, cold weather.
Add to bumpdraft's Reputation
Old 08-28-2017, 04:59 PM   #5204
A2Saturn
A2Saturn is on a distinguished road
A2Saturn's Avatar
1994 SL1
Changed my oil today, and finally switched over to the true synthetic Amsoil Signature Series 5w30. Sent out a sample to Blackstone Labs for them to analyye the Royal Purple 5w30 that was drained out.
Add to A2Saturn's Reputation
Rate the quality of this post and help A2Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
A2Saturn is offline   Reply With Quote
Old 08-28-2017, 11:07 PM   #5205
xSLx
xSLx is on a distinguished road
1996 SL1
Front rotors, pads, the works.
Then thermostat, coolant flush.
Still have wicked vibration ~ 65+ mph.
Hoping it just needs the wheels rebalanced.
Add to xSLx's Reputation
Rate the quality of this post and help xSLx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xSLx is offline   Reply With Quote
Old 08-28-2017, 11:34 PM   #5206
DavidBu
DavidBu is on a distinguished road
1998 SW2
Stuffed a wadded up paper napkin between the bottom edge of the largest plastic interior panel and the metal frame on the tailgate of my 1998 SW2 and stopped a 20 year old rattle. Finally.
Usually I ride a bike, but when I drive my 1998 DOHC SW2 5 spd Saturn, I get 44+ MPG at 55 MPH
Add to DavidBu's Reputation
Rate the quality of this post and help DavidBu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DavidBu is offline   Reply With Quote
Old 08-29-2017, 03:51 AM   #5207
saturnhusker
saturnhusker is on a distinguished road
saturnhusker's Avatar
2000 SL
changed oil, replaced drivers side wheel bearing, new drums and shoes for the rear, tightened up E-Brake.
Add to saturnhusker's Reputation
Rate the quality of this post and help saturnhusker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnhusker is offline   Reply With Quote
Old 08-29-2017, 08:44 AM   #5208
Did a couple commutes with the Torrent gauge set, am a little less enamored of it.
I still really like the needles that light up when the lights are on and prefer this IP at night. And I generally like the chrome rings and color scheme.
What I don't like:
  • Speedo is marked in multiples of 20mph.
    There is a large hash mark to denote the odd multiples of 10mph (30 mph, 50 mph, etc). However, most of the roads I drive are in multiples of 5 mph (35 mph, 45 mph, 55 mph) and these speeds aren't clearly distinct on the speedo, requiring me to pay a little more attention to the speedo.
  • The red needle is harder to see during daytime, on the black/gray speedo or tach background. There's not as much contrast between the colors as the black/white OEM speedo & tach. With the old IP, it was distinct enough that I could monitor speed from peripheral vision or quick glance; here, it takes a second to focus and find the needle
  • With the lights on, there is bleed over of backlight to the turn signal and high beam indicators. So the effect is a very dim glow of these lights.
Not enough to make me want to swap back yet. I'll change over the old IP to blue LEDs sometime, then swap back to see which I like better
I might open up the Torrent set and look at painting the edges or tips of the needles white, to give it some more daytime contrast.
Old 08-29-2017, 08:44 AM   #5209
Nekomimi
Nekomimi's Avatar
1996 SL1
After two of those black wheel covers flying off somewhere, I decided Zip-ties were the solution x)
Old 08-30-2017, 09:01 PM   #5210
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
347 mile road trip, almost 38 mpg. Not bad.
4,100 miles into my OCI and consumption is at least 2300 miles per quart. Pretty good for all original internals.
1999 SL2 A4 -85k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 08-31-2017, 10:50 AM   #5211
Nekomimi
Nekomimi's Avatar
1996 SL1
Found out that the oem lug nuts were too tall/ new and not allowing proper clearance, still keeping the zipties as a safety link.
I changed my blackend Mobile1Advanced oil and refilled with Schaeffer's full synthetic 5-30 + new M1209a filter. One of the notible things is the oil is green x) Plus their standalone additives are mixed in. So first impression is everything seems smooth and effortless.
Also thoes silly door trim mounted cup holders actually work....
Old 08-31-2017, 05:35 PM   #5212
NWSaturn247
My cup holder
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 09-01-2017, 12:01 AM   #5213
Nekomimi
Nekomimi's Avatar
1996 SL1
Originally Posted by NWSaturn247 View Post
My cup holder
1st Gen came in Biscuit interior? I've only seen grey out of the few that I've come across o .o
Old 09-01-2017, 08:41 AM   #5214
Confirmed taht is a "feature" by doing some research here - the Saturn's pinouts are a little different than the Torrent and will never show a CEL. Confirmed with reader that I still have P0037
Yesterday, two coats of Black Velvet on the new muffler and JY strap.
Put in the blue LEDs in the old dash, swapped dashes, but one of the theater LEDs did not light up, did some swapping and neither one lights up now, wonder if I wore out the copper contacts on the ribbon. Will look for somehthing conductive and play with it.
Old 09-02-2017, 10:17 PM   #5215
macbox
macbox will become famous soon enough
macbox's Avatar
Starter on the 98 SW2 finally failed this week, had the usual symptom of a no start when hot that the falling starters create. Replaced it with the starter that was sitting in a box in the garage from when I took apart the 95SC2 a few years ago. Was going to do the replacement yesterday, then remembered I used my second set of jackstands for the rear end of the SC2. Bought a new set this morning, I now own three sets of jackstands, and the SW2 now starts when hot.
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 09-03-2017, 10:55 PM   #5216
NWSaturn247
Rotated my Sumic GTA 195/60R15 wheels one last time @ 90k miles.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 09-04-2017, 12:01 AM   #5217
Installed new muffler with jy hanger on the SC2. Much quieter now
Found my opened tubes of JB Weld, literally 24 hours after giving up on finding any of the several tubes I know that I have, somewhere, and buying more JB Weld. Used the opened tube to fix a crack on one of the clips that hold up the rear brake light housing, will see how strong it is tomorrow
Redid the headliner, the JoAnn fabric gray is darker than the OEM coler, an is a smooth textured cloth where the OEM is a nappy, bumpy fabric. Headliner will go back in tomorrow.
Old 09-04-2017, 12:33 AM   #5218
Waiex191
Waiex191's Avatar
What did I do to my S series today? Nothing - first time in 4 months!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 09-06-2017, 08:58 AM   #5219
That's a well-deserved break!
Today, had an exciting (for me) commute to work.
I was the third car heading towards a traffic light when it turned yellow. The leading minivan was going to go through the yellow, when he must have noticed the police SUV stopped in the opposite direction in the turn lane.
So minivan hits the brakes, and the Buick right behind him, who had hit the gas thinking he would tailgate the minivan through the yellow, slammed into the minivan pushing it forward partway into the intersection.
Buick driver must have been stunned a bit, because he left his foot on the gas and hit the minivan a second time.
Light turned green so I went around, saw two officers getting out of the SUV. For some reason, they were pulling a ladder out.
then, on my way out of town, saw one gas station that still had gas at $2.53 (other stations had jumped up to $2.79 or so), so I turned around (safely, into a business driveway) and filled up, plus put about 4 gallons into the red plastic spare gas tank
Old 09-06-2017, 01:33 PM   #5220
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
I had an exciting experience about a month ago. We were on the 401 westbound near the exit to the 403 and the traffic was stop and go, with emphasis on stop. I was watching this box truck looming towards my back bumper in my rear-view mirror, and it didn't look like he intended to stop. My options were to either dodge onto the shoulder or to get right on the bumper of the SUV in front in the hopes that he had room to slam on his brakes or swerve around me and dive onto the shoulder.
When he finally realized that traffic wasn't moving, he slammed on his brakes, and so I got to watch this diving box truck getting bigger and bigger in my mirror until it stopped literally an inch off my bumper. I was just about tucked under the SUV in front, giving the box truck juuuuuuust enough room to stop without hitting me.
He took about an extra twenty seconds to get going again, probably to catch his breath and assess the state of his underwear after that near-miss. Good times on the 401.
Add to Goggles Pisano's Reputation
Rate the quality of this post and help Goggles Pisano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Goggles Pisano is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
